Hi, I'm very new to Arduino and I'm trying to get a project working.
I have a 0.96" OLED module with an Arduino Nano. When I use the screen with a resolution of 128x32, my project works fine. But if I change #define SCREEN_HEIGHT 32 to 64, it stops working.
I tried finding the address, and it is 0x3C. When I try a different project, the screen works fine with a resolution of 128x64.
This is the code where the screen stops working when I change #define SCREEN_HEIGHT 32 to 64.
// Program made/put together by
// Marcus Svensson aka Fishy
// https://www.printables.com/@Fishy_377550
// https://cults3d.com/en/users/FishyAirsoftCreations
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Versatile_RotaryEncoder.h>
//Screen Stuff
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//Rotary encoder -------------------------------------------------------------------
// Set here your encoder reading pins (Ex.: EC11 with breakout board)
#define clk 4 // (d4)
#define dt 3 // (d3)
#define sw 5 // (d5)
// Functions prototyping to be handled on each Encoder Event
void handleRotate(int8_t rotation);
void handlePressRotate(int8_t rotation);
void handleHeldRotate(int8_t rotation);
void handlePress();
void handlePressRelease();
void handleLongPress();
void handleLongPressRelease();
void handlePressRotateRelease();
void handleHeldRotateRelease();
// Create a global pointer for the encoder object
Versatile_RotaryEncoder *versatile_encoder;
//data för programmet
char *myPresets[] = {"Free Mode",
"Custom:",
"Preset:120",
"Preset:60",
"Preset:250",
"Preset:29",
"Preset:420",
"Preset:30",
"Preset:100",
"Preset:200",
int MaxPresetRows=9;
int CurrentTextScroll = 0;
int CustomBBQuantity = 1;
int CurrentCount = -2;
int BBTarget = 0;
int myPresetsValue[] = {-1,
CustomBBQuantity,
120,
60,
250,
29,
420,
30,
100,
200
bool currentlyLoading = false;
unsigned long passedTimeSinceLastCountedBB = 0; //Will check the time of millis when a BB is counted
unsigned long passedTimeForReset = 2000; //Max allowed time before reset of screen, in millis. (1000 = 1s)
int pushButton = 6; // (d6) pushbutton
int motorOn = 7; // (d7) relay to motor
//Photomicrosensor -------------------------------------
const int PhotoIn = 2; //input pin for Photomicrosensor
int sensorState = 0; // current state of the button //a variable to read the sensor state
int lastSensorState = 0; // previous state of the button
//OLED stuff -----------------------------------------
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
static const unsigned char PROGMEM logo_bmp[] =
{ 0b00000000, 0b11000000,
0b00000001, 0b11000000,
0b00000011, 0b11100000,
0b11110011, 0b11100000,
0b11111110, 0b11111000,
0b01111110, 0b11111111,
0b00110011, 0b10011111,
0b00011111, 0b11111100,
0b00001101, 0b01110000,
0b00011011, 0b10100000,
0b00111111, 0b11100000,
0b00111111, 0b11110000,
0b01111100, 0b11110000,
0b01110000, 0b01110000,
0b00000000, 0b00110000 };
#define Bullet_hole_HEIGHT 4
#define Bullet_hole_WIDTH 4
// 'Bullet_hole', 4x4px
const unsigned char Bullet_hole [] PROGMEM = {
0x60, 0xf0, 0xf0, 0x60
Serial.println("Starting up");
pinMode(PhotoIn, INPUT); //set pin 2 as input
pinMode(pushButton,INPUT_PULLUP); // sets the digital pin 6 to input button
pinMode(motorOn, OUTPUT);
versatile_encoder = new Versatile_RotaryEncoder(clk, dt, sw);
// Load to the encoder all nedded handle functions here (up to 9 functions)
versatile_encoder->setHandleRotate(handleRotate);
versatile_encoder->setHandlePressRotate(handlePressRotate);
versatile_encoder->setHandleHeldRotate(handleHeldRotate);
versatile_encoder->setHandlePress(handlePress);
versatile_encoder->setHandlePressRelease(handlePressRelease);
versatile_encoder->setHandleLongPress(handleLongPress);
versatile_encoder->setHandleLongPressRelease(handleLongPressRelease);
versatile_encoder->setHandlePressRotateRelease(handlePressRotateRelease);
versatile_encoder->setHandleHeldRotateRelease(handleHeldRotateRelease);
// set your own defualt values (optional)
// versatile_encoder->setInvertedSwitch(true); // inverts the switch behaviour from HIGH to LOW to LOW to HIGH
// versatile_encoder->setReadIntervalDuration(1); // set 2ms as long press duration (default is 1ms)
// versatile_encoder->setShortPressDuration(35); // set 35ms as short press duration (default is 50ms)
// versatile_encoder->setLongPressDuration(550); // set 550ms as long press duration (default is 1000ms)
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
drawNameTag();
//drawFishyTear();
// Clear the buffer
display.clearDisplay();
//AnimationTest(Bullet_hole, Bullet_hole_WIDTH, Bullet_hole_HEIGHT);
Serial.println("Starting up done");
UpdateDisplay();
// Do the encoder reading and processing
if(currentlyLoading==false){
if (versatile_encoder->ReadEncoder()) {
// Do something here whenever an encoder action is read
//2023-10-25 behövde något extra på vanlig uno. vetefan varför
//Hitta även små buggar jag kunde fixa.
if (digitalRead(pushButton)==LOW){
Serial.println("Yep, den trycks ner");
Serial.println(currentlyLoading);
Serial.println(CurrentCount);
Serial.println(BBTarget);
if (currentlyLoading==true){
currentlyLoading=false;
// if (CurrentCount == BBTarget){
// CurrentCount=-2;
//Load
if (digitalRead(pushButton)==LOW && (CurrentCount != BBTarget) && currentlyLoading==false){
//check selection and set target
if (CustomBBQuantity == 0){
CustomBBQuantity=1;
myPresetsValue[1]=CustomBBQuantity;
BBTarget=myPresetsValue[CurrentTextScroll];
Serial.print("Target is set to: ");
//start loading
if (CurrentCount<0){
CurrentCount=0;
currentlyLoading=true;
while (digitalRead(pushButton)==LOW && (CurrentCount != BBTarget) && (BBTarget != 0)){
//Serial.println("being pressed: ");
digitalWrite(motorOn, HIGH);
// read the photo sensor input pin: ---------------------------------------------------
sensorState = digitalRead(PhotoIn);
// compare the sensorState to its previous state
if (sensorState != lastSensorState) {
// if the state has changed, increment the counter
if (sensorState == HIGH) {
CurrentCount++;
Serial.println("High");
Serial.print("BB counted: ");
passedTimeSinceLastCountedBB = millis();
//Update Screen
NumberScreen();
Serial.println("LOW");
// save the current state as the last state, for next time through the loop
lastSensorState = sensorState;
digitalWrite(motorOn, LOW);
Serial.println("Turned off motor");
}else if (digitalRead(pushButton)==HIGH && currentlyLoading==true){
if (digitalRead(pushButton)==HIGH && currentlyLoading==false && CurrentCount>0 && ((millis() - passedTimeSinceLastCountedBB) >= passedTimeForReset)){
//Reset
Serial.println("Reseting");
CurrentCount=-2;
UpdateDisplay();
void UpdateDisplay(){
ChoiceScreen();
When I use this code, the screen resolution works just fine.
#include <Wire.h>
#define SCREEN_HEIGHT 64
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
for (;;);
display.display();
delay(2000);
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 10);
display.println("Hello, OLED!");
display.display();
void loop() {}
Can someone please help me out.
