Stuck beginner- LCD screens
I’ve only started playing around with the Arduino yesterday and I was following tutorials on LCDs after playing around with LEDs.
I’ve entered the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16,2);
lcd.print(“Hello, World!”);
void loop(){
and whenever I upload any sketch it would only show:
Sketch uses 1662 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variable use 59 bytes (2%) of dynamic memory, leaving 1989 bytes for local variables. Maximum is 2048 bytes
and nothing would be displayed on the LCD screen. Whenever I clicked on the Serial Monitor nothing appears as well
Most LCDs have a contrast adjustment. See if that needs to be changed. Beyond that we would need you to show how you have the LCD connected to the Arduino.
kaori21: Whenever I clicked on the Serial Monitor nothing appears as well
None of your code writes anything to Serial so that's to be expected. See: https://www.arduino.cc/en/Reference/Serial
That is because you haven't used the Serial class at all.
