Hi! I'm stuck in my RFID program. It doesn't move on when I pressed the setButton after I incremented/decremented the addbal variable using also 2 if statements. I am not pro in handling Arduino UNO. What am I doing wrong?
//LCD
#include <Wire.h>
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
//LCD library
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int decrementButton = 2;
int incrementButton = 3;
int setButton = 4;
int decButtonState = 0;
int incButtonState = 0;
int setButtonState = 0;
int addbal = 0;
int prestate = 0;
//LCD
lcd.begin(16,2); //16x2
lcd.clear();
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Beep Card Rebalance"));
lcd.clear();
lcd.print("Beep Card Reload");
lcd.setCursor(0,1);
lcd.print("Input balance...");
delay(2000);
pinMode(decrementButton, INPUT);
pinMode(incrementButton, INPUT);
pinMode(setButton, INPUT);
decButtonState = digitalRead(decrementButton);
incButtonState = digitalRead(incrementButton);
setButtonState = digitalRead(setButton);
lcd.clear();
lcd.print("Input balance: ");
if(incButtonState == HIGH && prestate == 0)
addbal = addbal + 10;
lcd.setCursor(0,1);
lcd.print("> ");
lcd.print(addbal);
lcd.print(" ");
delay(100);
prestate = 1;
else if(decButtonState == HIGH && prestate == 0)
if(addbal <= 0)
addbal = 0;
addbal = addbal - 10;
lcd.setCursor(0,1);
lcd.print("> ");
lcd.print(addbal);
lcd.print(" ");
prestate = 1;
delay(100);
else if(incButtonState == LOW && decButtonState == LOW)
prestate = 0;
else if(setButtonState == HIGH)
byte block;
MFRC522::StatusCode status;
byte len;
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
Serial.println(F("**Card Detected:**"));
byte buffer1[18];
block = 4;
len = 18;
//--- GET BALANCE ---//
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
if (status != MFRC522::STATUS_OK)
Serial.print(F("Authentication failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
status = mfrc522.MIFARE_Read(block, buffer1, &len);
Serial.print(F("Reading failed: "));
return;
//---PRINT BALANCE---//
String balance="";
for (uint8_t i = 0; i < 16; i++)
if (buffer1[i] != 32)
balance+=(char)buffer1[i];
//--- checking and deducting balance ---//
int balanceInt=balance.toInt();
Serial.print("Balance: ");
Serial.println(balanceInt);
////////////////////////////////////////////////ADDED//////////////////////////
byte buffer[34];
byte bal;
bal = Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
for (byte i = bal; i < 20; i++) buffer[i] = ' '; // pad with spaces
String addedBalance="";
addedBalance+=(char)buffer[i];
addbal = addedBalance.toInt();
balanceInt = balanceInt + addbal;
byte buffer3[18];
for (int i=0;i<balance.length();i++)
buffer3[i]=String(balanceInt)[i];
block = 4;
//Serial.println(F("Authenticating using key A..."));
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
Serial.print(F("PCD_Authenticate() failed: "));
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Put back card..");
lcd.clear();
return;
// Write block
status = mfrc522.MIFARE_Write(block, buffer3, 16);
Serial.print(F("MIFARE_Write() failed: "));
lcd.clear();
lcd.setCursor(0,0);
lcd.clear();
return;
else Serial.println(F("MIFARE_Write() success: "));
block = 5;
lcd.clear();
lcd.setCursor(0,0);
lcd.clear();
return;
// Write block
status = mfrc522.MIFARE_Write(block, &buffer3[16], 16);
lcd.clear();
lcd.setCursor(0,0);
lcd.clear();
return;
lcd.clear();
lcd.print("Transaction done!");
lcd.clear();
lcd.print("Balance:Php");
lcd.print(balanceInt);
lcd.clear();
lcd.print("Please remove");
delay(2000);
lcd.clear();
Serial.println(" ");
mfrc522.PICC_HaltA(); // Halt PICC
mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
delay(100);
