I have 8 inputs thru a shift register (4021) the shift in part works fine. I only want to send out a midi control change if the contact inputs have changed from the previous state, but it continues to send midi CC. Stuck in a loop. can anyone make some suggestions. here is the code
#include <MIDI.h>
// Variables definitions
int volume;
byte stage;
// Buttons Multiplexing Variables
// Definition of pins
int buttonsMuxClockPin = 7;
int buttonsMuxLatchPin = 8;
int buttonsMuxDataPin = 9;
// Define variables to hold the data
// for each shift register.
byte muxexpression1;
// Midi channel where to send notes for each mux
int MidiChannel1 = 1;
// Set up application
// Standard serial begin
// Serial.begin(9600);
// Midi serial begin
Serial.begin(31250);
// Buttons Mux
// Define pin modes
pinMode(buttonsMuxLatchPin, OUTPUT);
pinMode(buttonsMuxClockPin, OUTPUT);
pinMode(buttonsMuxDataPin, INPUT);
// Main Loop
// Butons Mux
// Function that handles digital mux for buttons
startReadingButtonMux();
// Buttons Mux
// Activate Digital Mux for Buttons
void startReadingButtonMux() {
// Pulse the latch pin:
// Set it to 1 to collect parallel data
digitalWrite(buttonsMuxLatchPin, HIGH);
// .... collecting data from digital inputs of MUX ... wait ...
delayMicroseconds(20);
// Set it to 0 to transmit data serially
digitalWrite(buttonsMuxLatchPin, LOW);
// While the shift register is in serial mode
//collect each shift register into a byte
//the register attached to the chip comes in first
muxexpression1 = shiftIn(buttonsMuxDataPin, buttonsMuxClockPin);
analyzeexpressionMux(muxexpression1, MidiChannel1);
// ShiftIn function
// Just needs the location of the data pin and the clock pin
// it returns a byte with each bit in the byte corresponding
// to a pin on the shift register. leftBit 7 = Pin 7 / Bit 0= Pin 0
byte shiftIn(int myDataPin, int myClockPin) {
int i;
int temp = 0;
// int pinState;
byte myDataIn = 0;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, INPUT);
// we will be holding the clock pin high 8 times (0,..,7) at the
// end of each time through the for loop
// at the begining of each loop when we set the clock low, it will
// be doing the necessary low to high drop to cause the shift
// register's DataPin to change state based on the value
// of the next bit in its serial information flow.
// The register transmits the information about the pins from pin 7 to pin 0
// so that is why our function counts down
// Loop for all the pins of the shift reg.
for (i=7; i>=0; i--)
digitalWrite(myClockPin, LOW);
delayMicroseconds(2);
temp = digitalRead(myDataPin);
if (temp) {
// pinState = 1;
// Set the bit to 1 no matter what
myDataIn = myDataIn | (1 << i);
else {
//turn it off -- only necessary for debuging
//print statement since myDataIn starts as 0
// pinState = 0;
digitalWrite(myClockPin, HIGH);
//debuging print statements whitespace
//Serial.println();
//Serial.println(myDataIn, BIN);
return myDataIn;
void analyzeexpressionMux(byte muxexpression1, int midiChannel) {
if (stage != muxexpression1){ //only send midi if input has changed
switch (muxexpression1){
case B00000000:
volume = 20 ;
case B00000001:
volume = 33 ;
case B00000011:
volume = 46 ;
case B00000111:
volume = 59 ;
case B00001111:
volume = 72 ;
case B00011111:
volume = 85 ;
case B00111111:
volume = 98 ;
case B01111111:
volume = 111 ;
case B11111111:
volume = 127 ;
default:
stage = muxexpression1;
sendMidi(CC , volume, 7, midiChannel);
stage = muxexpression1; //set current stage
else{ //input the same as before then do nothing
if(stage == muxexpression1){
//void controlChange(byte channel, byte controller, byte value)
// MIDI Functions
// Send a MIDI note-on/off message.
void sendMidi(char cmd, char data1, char data2, int midiChannel) {
// Based on midi library
MIDI.send(cmd, data1, data2, midiChannel);
