Stuck in whileloop (again!!)
Hi Everyone,
I have the below code. What I want it to do at the very beginning is to move the stepper into one direction until it triggers an endstop, then move a few steps backwards so the endstop is disengaged and then wait for the Tur-Switch to give its first signal. But after it detects the endstop, reverses and just moves on happily...
I have tried so many things but really desperate now... (The serial prints are for debugging only... they will be commented out when running the code for real...)
Thanks a lot..
Code is on teh reply to this post as I can't post more than 9000 chars...
#define EN          23
#define dirPin      25
#define Step        27
#define Tur_pin_Top         18           // RPM Sensor Top Roll Tur-Switch
#define Tur_pin_Bottom      19        // RPM Sensor Bottom Roll Tur-Switch
#define Right_pin           21               // Proximity Switch for Right and Park/Load position
#define Left_pin            3                // Proximity Switch for Left Return position
#define Load_pin            2                // PushButton to move the carriage to Park/Load position
#define PotTurPin           A1
//#define PotDelayPin         A3
#define Distance            1.75 //Filament Diameter
#define interruptors        2// number of interruptors on opto wheel for Speed calculation
#define Pitch               4 // pitch of leadscrew
#define Resolution          200 // step motor resolution for 1.8deg step angle
#define Microsteps          8 //settings on Step driver
#define spoolWidth          60
long int AutonomousSteps   = Microsteps / Pitch  * Resolution * spoolWidth;// steps in the loop for movement
unsigned long startTime;
unsigned long endTime;
boolean right = LOW, hall = LOW, left = HIGH, load = LOW;
unsigned long duration = 0;
int Speed = 0;
int dirChangeDelay = 0;
//float delayAdjust = 1;
float speedAdjust = 1;
int c = 0;
float setupNumber = Distance / (Pitch) * Resolution;
//-----SETUP----------------------
  delay(2000);
  delay(200);
  Serial.println("System Initialized....");
  initPins();
//-----LOOP----------------------
  //delayAdjust = analogRead (PotDelayPin) / 1023.0 + 0.5;
  speedAdjust = analogRead (PotTurPin) / 1023.0 + 0.5;
  Serial.println (speedAdjust);
  if (load)
    loadProcedure();
    //  Serial.println("load procedure initiated....");
    move();
//------INITIALIZE PINS---------------------
void initPins()
  pinMode(EN, OUTPUT);    // ENABLE AS OUTPUT
  pinMode(Step, OUTPUT);  // STEP AS OUTPUT
  pinMode(dirPin, OUTPUT); // DIRECTION AS OUTPUT
  digitalWrite(EN, HIGH);  // SET ENABLE TO HIGH FOR EXTERNAL DRIVER, LOW FOR STEPSTICKS
  pinMode(Tur_pin_Top , INPUT_PULLUP);
  pinMode(Tur_pin_Bottom , INPUT_PULLUP);
  pinMode(Right_pin, INPUT_PULLUP);
  pinMode(Left_pin, INPUT_PULLUP);
  pinMode(Load_pin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Top ), firstMovementAfterEndstopHit, FALLING);
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Bottom ), firstMovementAfterEndstopHit, FALLING);
  attachInterrupt(digitalPinToInterrupt(Right_pin), rightBut, FALLING);
  attachInterrupt(digitalPinToInterrupt(Left_pin), leftBut, FALLING);
  attachInterrupt(digitalPinToInterrupt(Load_pin), loadBut, RISING);
  if (digitalRead(Right_pin) == LOW)
  { digitalWrite(dirPin, HIGH);
    // Serial.println("HIGH 84");
    firstMovementAfterEndstopHit();
    Serial.println("System is on RIGHT side initally ");
    Serial.println (" waiting for signal...");
  else  //digitalRead(Left_pin) == LOW)
    Serial.println("System is on LEFT side initally ");
    Serial.println ("going right for start...");
    loadProcedure();
void firstMovementAfterEndstopHit()
{ Serial.println ("firstMovementAfterEndstopHit()");
  digitalWrite (EN, HIGH);
  digitalWrite (dirPin, HIGH);
  Serial.println("HIGH 102");
  move();
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Top), hallButTop, FALLING);
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Bottom), hallButBottom, FALLING);
//------DETECT ROTATION/SPEED SIGNAL -------------------
void hallButTop()// ISR
{ Serial.println ("hallButTop()");
  hall = HIGH;
  c++;
  if (c == 1)
    startTime = millis();
  else if (c == 2)
    endTime = millis();
    duration = endTime - startTime;
    Speed = (1000000.0 / (Microsteps * (1000.0 / (duration * interruptors)) * setupNumber)) * speedAdjust; //FORMULA //FORMULA
    c = 0;
void hallButBottom()// ISR
{// Serial.println ("hallButBottom()");
  hall = HIGH;
  c++;
  if (c == 1)
  else if (c == 2)
    endTime = millis();
    Speed = (1000000.0 / (Microsteps * (1000.0 / (duration * interruptors)) * setupNumber))/2 * speedAdjust; //FORMULA //FORMULA
    //dirChangeDelay = duration * interruptors * 1000.0 / 4.0 * delayAdjust;
    //    Serial.print("Duration : "); Serial.println(duration);
    //    dirChangeDelay = Resolution / Pitch * Microsteps * Distance * Speed * 2 / 1000.0;
    //    Serial.print("dCD: "); Serial.println(dirChangeDelay);
    //    float RPS = 1000.0 / (duration * interruptors);
    //    Serial.print("Speed "); Serial.println(Speed);
    //    Serial.print("Speed RPS: "); Serial.println(RPS);
    c = 0;
void rightBut()// ISR
{ Serial.println("Right EndStop Detected...");
  left = HIGH;
  right = LOW;
  hall = LOW;
  // delay(dirChangeDelay);
void leftBut()// ISR
{ Serial.println("Left EndStop Detected...");
  left = LOW;
  right = HIGH;
  hall = LOW;
//--------When Park-Load Buttun triggers-------------------
void loadBut()// ISR
  Serial.println("Load Button Pressed..");
  Serial.println("Move to Right-EndStop and Wait");
  left = LOW;
  right = HIGH;
  hall = LOW;
  load = HIGH;
  //  delay(100);
//------PROCEDURE when PARK-Load button is pressed
void loadProcedure()//no ISR
  detachInterrupt(digitalPinToInterrupt(Tur_pin_Top));
  detachInterrupt(digitalPinToInterrupt(Tur_pin_Bottom));
  if (!left)
    digitalWrite(dirPin, LOW);
    Serial.println("LOW 169");
    movLoad();
  else if (left)
  { movLoad();
    Serial.println("System should Wait unless Tur-Switch is detected ...");
    Serial.println("HIGH 175");
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Bottom), hallButTop, FALLING);
//---------PARKING MOVE----- Go Right and wait
void movLoad()//no ISR
{ //digitalWrite(dirPin, LOW);
  //  Serial.println("Load pressed");
  if (Right_pin)
  { digitalWrite(dirPin, LOW);
    Speed = (1000000.0 / (Microsteps * (1000.0 / (180)) * setupNumber)) / 2;
    attachInterrupt(digitalPinToInterrupt(Right_pin), hitRightEndstop, FALLING);
    delay (500);
    Serial.println("attached right endstop");
    while (digitalRead, Right_pin)
      for (int i = 0; i < 20; i++)//ACT
        digitalWrite(Step, HIGH);
        delayMicroseconds(Speed);
        digitalWrite(Step, LOW);
  { Serial.println("movLoad Else");
    Serial.println("HIGH 204");
    move();
//------When it hits right Enstop during Park/load-----
void hitRightEndstop()    //ISR
  //digitalWrite (EN, LOW);
  Serial.println("Right Endstop hit,  disabling motor!!");
  Serial.println("219");
  for (int i = 0; i < (15); i++) //ACT
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Top), firstMovementAfterEndstopHit, FALLING);
  attachInterrupt(digitalPinToInterrupt(Tur_pin_Bottom), firstMovementAfterEndstopHit, FALLING);
  Serial.println("222");
//-----Main Movement procedure BOTH DIR---------------------
void move()
  Serial.println("233");
  for (int i = 0; i < (10); i++)//ACT
    delayMicroseconds(Speed * 4);
  for (int i = 0; i < (20); i++)//ACT
    delayMicroseconds(Speed * 3);
  for (int i = 0; i < (40); i++)//ACT
    delayMicroseconds(Speed * 2);
  for (int i = 0; i < (AutonomousSteps - 70); i++) //ACT
  digitalWrite (dirPin, !digitalRead(dirPin));// toggle direction
This is the loop part:
  Serial.println("LOW 179");
  if (Right_pin)
    Serial.println("LOW 183");
    delay (500);
    move();
What do you suppose this is doing ?
if (Right_pin)you gave Right_pin the value 21.
It will always be true.
You are attempting to write code that is beyond your current level of experience. Many of the lines make no sense at all. They compile because C assumes you as the programmer know what you are doing, it does not try to protect you from your own stupidity like many other languages do.
Spend some time working through basic Arduino tutorials to learn the basics.
It seemed that there was nothing else to do than loop. I made this change and it worked.
  for (int i = 0; i < endStopOffset ; i++) //ACT
  digitalWrite(EN, LOW);
PaulRB:
You are right, but that's the way I learn. Lots of trial and error. Actually I paid someone to write the basic code of and then started to tinker with it as the project needed changes. That was the code I received. I agreei it was much tidier but I will clean mine up too as soon as I got it working the way I need it..
#define EN          16
#define dirPin      17
#define Step        23
#define stepsPerRevolution 200
#define Tur_pin      3       // Hall Sensor
#define Right_pin    2      // MicroSwitch for right End
#define Left_pin     19    //MicroSwitch for Left End
#define Load_pin     18   // Button to pull the carriage
#define Distance            1.750 //Sure
#define Pitch               2.5
#define Microsteps          4
boolean right =LOW,hall =LOW,left =HIGH,load =LOW;
int Speed=0;
int c=0;
float setupNumber=Distance/(Pitch)*Resolution;
void initPins()
  pinMode(Tur_pin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(Tur_pin),hallBut,FALLING);
  attachInterrupt(digitalPinToInterrupt(Right_pin),rightBut,FALLING);
  attachInterrupt(digitalPinToInterrupt(Left_pin),leftBut,FALLING);
  attachInterrupt(digitalPinToInterrupt(Load_pin),loadBut,FALLING);
  if(digitalRead(Left_pin)==LOW)
    Serial.println("System is on left side initally ");
    left=LOW;
    right=HIGH;
   hall=LOW;
   delay(10);
    Serial.println("Move  Right on swatch...");
void hallBut()
  hall=HIGH;
  Serial.println("Swatch Change");
  c++;
  if(c==1)
    startTime=millis();
  else if(c==2)
    endTime=millis();
    duration=endTime-startTime;
    Serial.print("Duration : ");Serial.println(duration);
    Speed=1000000.0/(Microsteps*(1000.0/(duration*interruptors))*setupNumber); //should be right.. but you get the idea.. okay upload and test
    Serial.print("Speed : ");Serial.println(Speed);
    c=0;
void rightBut()
  Serial.println("Right Detect.it .");
  right=LOW;
  hall=LOW;
  left=HIGH;
  delay(10);
  Serial.println("Moving Left...");
void leftBut()
  Serial.println("Left Detect..");
  left=LOW;
  right=HIGH;
  hall=LOW;
  delay(10);
  Serial.println("Moving Right...");
void loadBut()
   Serial.println("Load Triggered..");
   Serial.println("Move to right end and stop");
   load=HIGH;
   hall=LOW;
   left=LOW;
   right=HIGH;
  delay(200);
  Serial.println("System Started....");
  initPins();
  if(load)
    if(!left)
      mov();
    else if(left)
      Serial.println("System should Stop unless Swatch is detected ...");
      load=LOW;
      hall=LOW;
      left=HIGH;
      right=LOW;
    if (!right && left && hall ) //When Hall triggered go to the Left endstop Position
      mov();
    else if (right && !left && hall)
      mov();
void mov()
  for (int i = 0; i < stepsPerRevolution; i++)
Here, introducing, for the first time ever . . . "endStopOffset" !
...apart from the stuff about "don't do serial I/O in interrupt context'
UKHeliBob:
Uuups, it should be of course like
while (digitalRead(Right_pin) == HIGH)
And of course all the Serial IO's are only there so I can follow the code execution. They will be removed at the end.
İt was the slogan of the Carter era, when they reduced speed limit from 75 to 55...
quote from fb: The National Maximum Speed Law was passed in 1974 and repealed in 1995. The 55 mph highway limit was a brilliant idea in response to the 1973 oil crisis. The goal was to achieve 4% fuel savings and prevent millions of crashes and thousands of traffic deaths. Unfortunately it was hugely unpopular and compliance was low. Still there was some fuel benefit and traffic crashes and deaths increased by a third after it's repeal.
action68:
Stay Alive - Drive 55
You're replying to the wrong post. Badly.
