Stuck in whileloop
Hi Everyone,
I am a newbie and have following problem:
I somehow get stuck in a while loop.
Can You help me out?
#include <TimerOne.h>
#include <SoftwareSerial.h>
//Board and Pin Config
//STEPPER Pins
const int EN = 16; //56;         //ENABLE PIN  Y axıs
const int dirPin = 17; //61;        // DIRECTION PIN
const int Step = 23; //60;       // STEP PIN
//Switch pins
const int buttonPinTur = 3;    // Hall Sensor The number of the pushbutton pin
const int buttonPinSag = 2;    // MicroSwitch the number of the pushbutton pin
const int buttonPinSol = 14;   //MicroSwitch the number of the pushbutton pin
const int buttonPinLoad = 18;  // Taster zmin
// Fixed Variables
float Pitch = 2.5; // vidanın hatvesi
float Ilerleme = 2.5; //filament çapı
int StepsPerRev = 200; //Motorun Step sayısı
int Microsteps = 4; // Mikrostep Ayarı
double rev = 2; //R/sec
int Delay = 1000000 / (rev * 2 * StepsPerRev);
int Speed = Delay / Microsteps; //(mikrosaniye cinsinden step hızı (küçüldükçe hızlanır)
float Mesafe = Ilerleme / Pitch * StepsPerRev / 2 * Microsteps;
  pinMode(EN, OUTPUT);    // ENABLE AS OUTPUT
  pinMode(Step, OUTPUT);  // STEP AS OUTPUT
  pinMode(dirPin, OUTPUT); // DIRECTION AS OUTPUT
  digitalWrite(EN, HIGH);  // SET ENABLE TO HIGH FOR EXTERNAL DRIVER, LOW FOR STEPSTICKS
  pinMode(buttonPinTur, INPUT);
  pinMode(buttonPinSag, INPUT);
  pinMode(buttonPinSol, INPUT);
  pinMode(buttonPinLoad, INPUT);
  digitalWrite(dirPin, HIGH);
  Timer1.initialize(Speed);
  Timer1.attachInterrupt(makeStep);
  byte readingSag = digitalRead(buttonPinSag);
  byte readingSol = digitalRead(buttonPinSol);
  byte readingLoad = digitalRead(buttonPinLoad);
  byte readingTur = digitalRead(buttonPinTur);
  //loadFilament(readingLoad, readingSag);
  checkEndstop(readingSag, readingSol, readingLoad);
void makeStep ()
  digitalWrite(Step, HIGH);   // STEP HIGH
  delayMicroseconds(Speed);                   // WAIT
  digitalWrite(Step, LOW);    // STEP LOW
void checkEndstop(byte readingSag, byte readingSol, byte readingLoad)
  if (readingLoad == LOW && readingSag == HIGH)
    digitalWrite(dirPin, LOW); // LOAd pozisyonun hangi istikamette olduğuna bağlı
    while (readingLoad == LOW && readingSag == HIGH)
      makeStep();
  if (readingLoad == LOW && readingSag == LOW)  //at load position, load and right switch pressed
    delay(10);
  if (readingSag == LOW) //LOW microswitch HIGH REED
  if (readingSol == LOW) //LOW microswitch HIGH REED
The while loop is checking for the condition of 2 switches, if only one of them is LOW then it "steps" if both get LOW then it should stop stepping and wait...
Also there are some more variables in the code that I haven't used yet but thats for the next steps.
Thanks in advance.
Not INPUT_PULLUP?
The only while loop I can see is this
so to exit the loop you need to have ReadingLoad == HIGH AND OR readingSag == LOW. Why is this not happening?
EDIT: Corrected logic
marco_c:
so to exit the loop you need to have ReadingLoad == HIGH AND readingSag == LOW. Why is this not happening?
No. To exit the loop, he needs to have readingLoad == HIGH OR readingSag == LOW.
I've never used the TimerOne library, so not familiar with it, but it appears you are setting up a timer to interrupt at an interval (set by the constant speed), then delaying twice that amount inside the interrupt service routine (ISR).
void makeStep ()
This would result in the interrupt condition being met while you are still in the ISR, and as soon as you exit the ISR and interrupts are re-enabled the code would immediately execute the ISR again.
@RayLivingStone - you know, that's what I had in my head but that's not what came out. Thanks for the correction. I edited to correct for future generations.
david_2018:
void makeStep ()
Good Point. Thanks
int InterruptTiming = 10;
int Delay = 1000000 / (rev * StepsPerRev)/2;
Timer1.initialize(InterruptTiming);
void makeStep ()
