Stuck on activating a relay
I am working on a simple code that uses 2 motion sensors. The first sensor lights a red led when it detects motion. The second sensor lights a blue led and it's supposed to trigger a relay that activates a spray switch on then off. The led lights are doing what they are supposed to do, but the relay is not. Everything is wired correctly and all components work. /*
Arduino with PIR motion sensor
For complete project details, visit: Arduino with PIR Motion Sensor | Random Nerd Tutorials
Modified by Rui Santos based on PIR sensor by Limor Fried
int led = 13; // the pin that the LED is atteched to
int sensor = 2; // the pin that the sensor is atteched to
int state = LOW; // by default, no motion detected
int val = 0; // variable to store the sensor status (value)
int ledblue = 10; // the pin that the LED is atteched to
int sensorblue = 5; // the pin that the sensor is atteched to
int stateblue = LOW; // by default, no motion detected
int valblue = 0; // variable to store the sensor status (value)
int spray = 8; // the pin that the spray bottle is atteched to
int valspray = 0; // by default, no motion detected
pinMode(led, OUTPUT); // initalize LED as an output
pinMode(sensor, INPUT); // initialize sensor as an input
pinMode(spray, OUTPUT); // initialize spray as an output
Serial.begin(9600); // initialize serial
pinMode(ledblue, OUTPUT); // initalize LED as an output
pinMode(sensorblue, INPUT); // initialize sensor as an input
void loop(){
val = digitalRead(sensor); // read sensor value
if (val == HIGH) { // check if the sensor is HIGH
digitalWrite(led, HIGH); // turn LED ON
delay(100);                // delay 100 milliseconds
if (state == LOW) {
  Serial.println("Motion detected!");
  state = HIGH;       // update variable state to HIGH
else {
digitalWrite(led, LOW); // turn LED OFF
  delay(200);             // delay 200 milliseconds
  if (state == HIGH){
    Serial.println("Motion stopped!");
    state = LOW;       // update variable state to LOW
valblue = digitalRead(sensorblue); // read sensor value
valspray = digitalRead(sensorblue);
if (valblue == HIGH) { // check if the sensor is HIGH
digitalWrite(ledblue, HIGH);   // turn LED ON
digitalWrite(spray, HIGH);   // turn spray ON
digitalWrite(spray, LOW);   // turn spray ON
delay(100);
if (stateblue == LOW) {
  stateblue = HIGH;       // update variable state to HIGH
else {
  digitalWrite(ledblue, LOW); // turn LED OFF
  if (state == HIGH){
Show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
LEDs require a series dropping resistor, try 220R,
It looks like the two wires connected to the spray switch are attached to different relays.
Read the forum guidelines to see how to properly post code and some hints on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
no they are both on relay 1
However much I zoom in, I can't convince myself that's correct. Perhaps another picture would help.
Hi @paulhook
This is very very very fast to use with relays.
RV - mineirin
  digitalWrite(spray, LOW);   // turn spray ON   <<<< ----- OFF?
  delay(100);
yes, the comment is wrong. It should be turn spray off
Powering your relay board from the Arduino is not recommended.
Suggest you get a separate 5V power supply.
Hi
It's not just the comment that's wrong.
Turning an output on and off immediately does not work with mechanical devices such as a relay.
  delay(100);
RV - mineirin
As stated by @ruilviana
How long do you think it stays HIGH ?
  delay(100);
1 millisecond?
Hi
relay Operate time(Under nominal voltage) .......... ≤10ms
Ref: http://www.songlerelay.com/Public/Uploads/20161104/581c81ac16e36.pdf
RV mineirin
Hi
I don't agree with this, It's much less than 1 mSec.
This time is <= 8 micros seconds
RV - mineirin
I tried delay(10); and it works 1 time, so it activates the switch once, but not again
Show the new code, but use </> to post it.
ArduinoForum
I added some code for a servo motor. So the led's work properly, the servo motor works properly but the relay just goes click click when activated
    For complete project details, visit: http://RandomNerdTutorials.com/pirsensor
// Include the Servo library
#include <Servo.h>
// Declare the Servo pin
int servoPin = 6;
// Create a servo object
Servo Servo1;
     // We need to attach the servo to the used pin number
   Servo1.attach(servoPin);
void loop(){
   // Make servo go to 0 degrees
   Servo1.write(0);
    if (state == LOW) {
   // Make servo go to 90 degrees
   Servo1.write(90);
  else {
      if (state == HIGH){
   // Make servo go to 180 degrees
   Servo1.write(180);
    delay(10);
    delay(10);
    delay(100);
    delay(10);
   delay(10);
   Servo1.write(90);
  else {
      if (state == HIGH){
Hi
It doesn't affect the functionality but you initialized the serial 2 times.
And has two unnecessary brackets " { and } " at end code.
RV mineirin
Hi
Increase the time from 10 to 100 for diagnostic purposes and see if it works 2 times.
RV - mineirin
