Stuck on counting people with two arduino sensors (Ultrasonic Sensor HC-SR04)
Hello, I have been working on a project for about two weeks now and I am stuck on the most important part: the bi-directional counting. Any advice is more than helpful.
This is my project (arduino uno):
Wiring:
This is what i managed to program so far:
const int trigPin1 = 7;
const int echoPin1 = 8;
const int trigPin2 = 2;
const int echoPin2 = 4;
double duration1;
double distance1;
double duration2;
double distance2;
int people = 0;
int delaytime = 20;
double doorWidth = 20;
boolean in;
boolean out;
int sens1;
int sens2;
  Serial.begin(9600); // starts the serial communication
  pinMode(trigPin1, OUTPUT); // sets the trigPin1 as an Output
  pinMode(echoPin1, INPUT); // sets the echoPin1 as an Input
  pinMode(trigPin2, OUTPUT); // sets the trigPin2 as an Output
  pinMode(echoPin2, INPUT); // sets the echoPin2 as an Input
double Sensor1() {
  digitalWrite(trigPin1, LOW);   // clears the trigPin1
  delayMicroseconds(2);
  digitalWrite(trigPin1, HIGH);    // sets the trigPin1 on HIGH state for 10 micro seconds
  delayMicroseconds(10);
  duration1 = pulseIn(echoPin1, HIGH);  // reads the echoPin1, returns the sound wave travel time in microseconds
  distance1 = duration1 * 0.034 / 2;    // calculating the distance
  if (distance1 < doorWidth) {
    sens1 = 1;
    sens1 = 0;
  return distance1;
  return sens1;
void Sensor1Display() {
  Serial.print("Distance1: ");
  Serial.print(distance1);
  Serial.print(" cm ");
  Serial.print("sens1: ");
  Serial.print(sens1);
  Serial.print("\t");
  delay(delaytime);
double Sensor2() {
  digitalWrite(trigPin2, LOW);   // clears the trigPin2
  digitalWrite(trigPin2, HIGH);    // sets the trigPin2 on HIGH state for 10 micro seconds
  duration2 = pulseIn(echoPin2, HIGH);  // reads the echoPin2, returns the sound wave travel time in microseconds
  distance2 = duration2 * 0.034 / 2;    // calculating the distance
  if (distance2 < doorWidth) {
    sens2 = 1;
    sens2 = 0;
  return distance2;
  return sens2;
void Sensor2Display() {
  Serial.print("Distance2: ");
  Serial.print(distance2);
  Serial.print("sens2: ");
  Serial.print(sens2);
  Serial.print("\t");
  delay(delaytime);
double CountPeople() {
    if (in == true) {
      if ((sens1 == 1) && (sens2 <= 1)) {
        people ++;
        in = false;
    if (sens1 == 0) {
      in = true;
   /* if (out == true && in == false) {
      if ((sens2 == 1) && (sens1 <= 1)) {
        people --;
        out = false;
    if (sens2 == 0) {
      out = true;
  return people;
void DisplayPeople() {
  Serial.print("People count: ");
  Serial.println(people);
  Sensor1();
  Sensor2();
  Sensor1Display();
  Sensor2Display();
  CountPeople();
  DisplayPeople();
  return distance2;
  return sens2;
I have not looked at your program in detail but this stands out as a mistake. Only one variable can be returned from a function. As soon as the return statement is encountered within a function the function ends.
In your case, however, as both variables are globals there is no need to return either of them anyway.
You can do bidirectional counting by noting the time from millis() when one sensor becomes active and comparing it with the time from millis() when the second sensor becomes active. Subtract one time from the other and you can not only count the number of people passing the sensors but also their direction.
double duration1;
pulseIn() does not return a double. Why store the unsigned long that it returns in a float?
You only assign sens2 a value of 0 or 1. Of course it will be less than or equal to 1.
You need ONE variable that holds direction. Someone is entering or someone is leaving. A person can not be doing both at the same time.
You currently have 4 variables that are trying to define whether a person is entering or leaving. No wonder you can't tell which way they are going.
Thanks :slight_smile: ill try to implement this in my code.
I have removed the unnecessary returns, changed the double function to void and took only one variable for keeping directions (people walking in or else - out) as suggested. Though it still seems like I am stuck on some simple task which I can't find the solution to. I manage to add the people coming in and change the boolean variable to false so it doesn't continue adding up but then get stuck on the other direction. And if I try the other way then the boolean value's meaning messes up and it adds one when someone crosses and subtracts when someone leaves but doesn't do it continuously. Again any suggestions or comments would help me immensely.
double duration1;
double distance1;
double duration2;
double distance2;
int people = 0;
int delaytime = 20;
boolean in = true;
double time1;
double time2;
void Sensor1() {
    time1 = millis();
  Serial.print("time1: ");
  Serial.print(time1);
  Serial.print("\t");
  delay(delaytime);
void Sensor2() {
    time2 = millis();
  Serial.print("time2: ");
  Serial.print(time2);
  Serial.print("\t");
  delay(delaytime);
void CountPeople() {
   /*if (in == true) {
     if (((time1 - time2) < 0)) {
       people ++;
       in = false;
    if (((time2 - time1) < 0)) {
     in = true;
  if (in == true) {
      people++;
      in = false;
  if (in == false) {
    if (((time1 - time2) > 0)) {
      people--;
      in = true;
  Sensor1();
  Sensor2();
  Sensor1Display();
  Sensor2Display();
  CountPeople();
  DisplayPeople();
I have not looked in detail, but I think that you need to wait until both sensors have been passed before deciding the direction.
Exactly.
Ok I got it to work, i had to reset my time variables and I kept sens1 and sens2. Anyways thanks and good night :slight_smile:
