stuck situation
hi there i have a problem with my code. it is a statement that never seems to be fulfuilled
my settup is 2 push buttons 3 leds and one IR led the ir led is only to transmit information and this is working.
the higlighted part is the on that seems to never end
if ( rod < 1800 ){Serial.println(" if rod statment");
while( rod != 1800 ){Serial.println(" while rod statment"); delay(500);
Serial.print(rod);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin3, LOW);
if(rod == 1799){
int death = 0;
while(death != 500){
delay(50);
digitalWrite(ledPin, LOW);
delay(50);
delay(50);
death = death++;
sendOver = sendOver + 1;
if (sendOver == 15){
dataOut = timesDied;
int key = 0;
for (int j = 0; j<10; j++) {
key = sendIRKey(dataOut);
Serial.print(“Key Sent: “);
Serial.println(key);
sendOver = 0;
if(death == 500){
gron = 0;
gul = 1800;
rod = 1799;
timesDied = timesDied + 1;
rod = rod + 1;
if (sendOver == timeToSend){
int key = 0;
sendOver = 0;
if( sendOver > timeToSend){
sendOver = timeToSend -1;
if (rod > 1800){
rod = 1799;
val = (digitalRead(inPin));
if (val == LOW){Serial.println(” if val statment”);
rod = rod + 50;
if(rod > 100 && rod < 2000){
rod = 1799;
gul = 1800;
gron = 1800;
val2 = (digitalRead(inPin2));
if (val2 == LOW){Serial.println(” if val2 statment”);
rod = rod + 50;
if(rod > 1675 && rod < 2000){
gul = 0;
rod = 1800;
gron = 1800;} }
Hi.
I don't know if this will solve your problem, but I suspect this line:
death = death++;
is not incrementing the variable as you expect. Either use "death++" or "death += 1" or "death = death + 1". I tested this idea in a compiler other than Arduino's and found that in fact "death = death++; " does not increment the value of death. Should be some compiler workings of the post-increment.
Anyway, try it and let me know if this helps.
Oscar
TRy to closely follow the value of the variable rod.
If it never becomes exactly 1800 then the while loop starting at the very top
will go on forever.
