I've managed to get 2 7 segment displays working with 2 4511 decoders and can display numbers up to 99.
I want to add a third display and read numbers up to 150 and display them.
I cant for the life of me work out how to pick out the 100's and write to the 3rd display.... As you can guess I am new to all this.......
// the start of the BCD pins used for ABCD must be sequential
int BCDStart = 43;
// the start of the common pins - must be sequential
int commonStart = 47;
// this code can use either polarity of display.
// true if common is high when ON, otherwise false. Using common cathode = false
boolean commonHigh = false;
// the analog input for the potentiometer
int analogIn = A4;
// Enable all bcd outputs,
// set them to OFF
for(int i=0;i<4;++i) {
pinMode(BCDStart + i, OUTPUT);// set each binary pin to be an output.
digitalWrite(BCDStart + i, commonHigh?1:0);// If commonHigh is true (its false) set all pins to 1 else set to 0. Common cathode needs 0 (1 fires segment).
// Setup all the common pins, initially OFF.
for(int i=0;i<3;++i) {
pinMode(commonStart + i, OUTPUT);// set each LED common pin to be an output.
digitalWrite(commonStart + i, commonHigh?0:1); //If commonHigh is true (its false) set to 0 else set to 1. Common cathode needs 1 (0 turns on display).
// read the analog input voltage
int amount = analogRead(analogIn)/7.86; // scaled at 150
Serial.println (amount);
for(int i=(2-1);i>=0;--i) {
// find the current digit, which is in the low 4 bits. first pass is right display on, second pass swithches to left display.
int digit = amount % 10;
Serial.println (digit);
// and write out the representation of the voltage
writeDigitToDisplay(digit);// first send remainder to function then 2nd pass send 10's to function
// enable the correct digit for display
digitalWrite(commonStart + i, commonHigh?1:0);//writes each returned bit of remainder to right display.
// short delay between changes.
delay(1);
// Turn off the correct digit for display
// get the next digit.
amount = amount / 10;// finds 10's value and rerun For to initiate middle display
// Serial.println (amount);
delay(1);
// Now we define the bits that are on and off
// for ABCD output, These are used in the
// function below to generate the BCD for the 4511.
int dig[10] = {
0b0000,//0
0b0001,//1
0b0010,//2
0b0011,//3
0b0100,//4
0b0101,//5
0b0110,//6
0b0111,//7
0b1000,//8
0b1001,//9
void writeDigitToDisplay(int digit) {
// iterate through each bit
// isolate the current bit in the loop.
int currentBit = (1<<(i)); //shifts binary 0001 by 3-i. CurrentBit is 4 new combinations (as i changes)or reverse LSB read as (1<<(i))
// check if the bit is on, and invert for
// commonhigh if needed.
int bitOn = (currentBit&digit)!=0;//if currentBit & digit then 3-1 is 1
if(commonHigh) {//is false
bitOn = !bitOn;//so bitOn stays at 1
// and lastly set the bit
digitalWrite(BCDStart+i, bitOn); //writes bitOn to each BCD pin
Serial.println (bitOn);
