stuck with my project please help
i am using raspberry pi and arduino to create a project on iot. now when i make a gpio pin of pi high it also make a pin of arduino low....which is connected to the 4 channel relay board. now the problem is...i am using 3 of 4 relays. but cant on the 3 relays at a time...to on the third one i need to keep one of the 3 relays off...i am using external power supply for relay...
fan_light.ino (1.48 KB)
Your thoughts are hard to follow. Care to slow down, show more information in the post, give a clearer description of your circuit, and don't attach a short sketch. Read the post called How to use this forum - please read. It will help you get the best possible help from the crowd here.
    if(state_gpio1==HIGH)
        if(f1==0)
          digitalWrite(9,LOW);
          f1=1;
    else if(state_gpio1==LOW)
        digitalWrite (9,HIGH);
        f1=0;
Empty else blocks are useless. Exercise your right to delete them.
What this code is doing is setting f1 to state_gpio1 and writing the opposite state to pin 9.
It would require a lot less code to just do that.
   f1 = state_gpio1;
   digitalWrite(9, !f1);
Of course, it is not clear why you need two copies of the state of a pin, when both go out of scope at the end of loop(), so that snippet of your code could really be:
   digitalWrite(9, !digitalRead(4));
In fact, your whole loop function could be:
   digitalWrite(10, !digitalRead(5));
   digitalWrite(11, !digitalRead(6));
We really do need to see a schematic, because it appears that you have a hardware problem in addition to way too much code.
