Stucks in controlling Output use Ethernet Shield with SD card
Hi everyone, i’m working on a project use Ethernet Shield for reading and writing digital data. I’m using SD card to store my web page, my proplem is about control an pin 6 output with virtual button on web page. When i click on the button, nothing is happen.
In my case, i use PWR function to switch on/off an output.
Can anyone help me ? I’m on my deadline
Ethernet Shield.txt (6.09 KB)
HTML.txt (3.26 KB)
What investigation have you already done to isolate the problem ?
Is it clear to you if the problem is on the HTML side or the Web Server side ?
What happens if you issue this command in a web browser in the same network as the web server:
http:///ajax_inputs?PWR1=1
Does the Led light ?
Do you see the text “Serial check!” in the serial console of the Arduino ?
Why do you have two serial ports? Are you not using an Arduino UNO?:
#include "UART_ARDUINO.h"
UART Nhan;
  Nhan.begin(9600);
  Serial.println("Initializing SD card..."); // c√†i ƒë·∫∑t th·∫ª SD
  c1.print("<distance>");
  if(Serial.available())
    d = Nhan.read_uint8_t();
    c1.print(d,DEC);
  c1.println("</distance>");
