In my continuing quest to build a valve control device for water drop
photography I am once again battling C++. this time it is program
logic. I have the following code that is supposed to allow me
to change the number of drops that I am going to release.
The outloop does what it is supposed to do based on the number
of drops I select. What happens is when I enter the main loop
I can select 1, 2 or 3 drops by pushing the up and down keys on
the DFRobot LCD shield. I have logic in the loop to force no
more than 3 drops or less than 1 drop. That works.
What fails is the call to the outloop. When the outloop runs
it outputs pulses that Ii can see on the board LED. When the outloop
completes it does not go back to the top of the main loop. It appears
to be running over and over with getting back to the while (key != 4) statement.
I put a couple of diagnostic counters in the program to try and help me diagnose
the failure. loopcount increments very fast while doing the drop select logic
which is what I would expect. loopcount1 is doing nothing when I am selecting
drops, also expected results. When I push the select button (Key = 4) that changes.
loopcount stops incrementing and loopcount1 increments each time the outloop runs.
My code is obviously flawed because I do not understand returning from the outloop and what is
wrong with my code that it does NOT go to the while (key != 4) statement when I return from
outloop.
Thanks in advance for any and all help!!!!
RWW
Here is the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
char msgs[5][15] = {
"Right Key OK ", // Value = 0
"Up Key OK ", // Value = 1
"Down Key OK ", // Value = 2
"Left Key OK ", // Value = 3
"Select Key OK" }; // Value = 4
int adc_key_val[5] ={
30, 150, 360, 535, 760 };
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int oldkey=-1;
int DropCount = 2; // default Starting point
int pulseWidth0 = 1000; //Valve ON Time (Drop Size)
int pulseWidth1 = 1000; //Valve ON Time (Drop Size)
int pulseWidth2 = 1000; //Valve ON Time (Drop Size)
int pulseSep0 = 300; // Drop Seperation time (Time Between Drops), valve off time
int pulseSep1 = 350; // Drop Seperation time (Time Between Drops), valve off time
int pulseSep2 = 400; // Drop Seperation time (Time Between Drops), valve off time
int sensorValue =0;
int reading = 0;
int backLight = 10;
int selectPin = 6;
int valveControl =11; // Output pin to turn valve ON & OFF
int ledpin = 13;
int loopcount = 0;
int loopcount1 = 0;
pinMode(13, OUTPUT); //we'll use the debug LED to output a heartbeat
pinMode(11,OUTPUT);
pinMode(10,OUTPUT);
lcd.begin(16,2);
//optionally, now set up our application-specific display settings, overriding whatever the lcd did in lcd.init()
digitalWrite(13, LOW); // Turn OFF board LED
digitalWrite(backLight,HIGH); // Turn ON LCD Backlight
lcd.clear();
lcd.print("Drop Count");
lcd.setCursor(13,0);
lcd.print(DropCount);
//lcd.cursor(); //Turn on the cursor
while (key != 4)
adc_key_in = analogRead(0); // read the value from the sensor
loopcount = loopcount++;
lcd.setCursor(0,1);
lcd.print(loopcount);
lcd.setCursor(8,1);
lcd.print(loopcount1);
//digitalWrite(13, HIGH);
key = get_key(adc_key_in); // convert into key press
if (key != oldkey) // if keypress is detected
delay(50); // wait for debounce time
if (key != oldkey)
oldkey = key;
if (key >=0)
lcd.setCursor(13, 0); //line=1, pos 13
lcd.setCursor(0,1);
lcd.print(" "); // erase error message
lcd.setCursor(0,0);
if (key == 1)
DropCount = DropCount++;
if (DropCount == 4)
DropCount = 3;
lcd.setCursor(0,1);
lcd.print("Max Drops = 3");
else if (key == 2)
DropCount = DropCount--;
if (DropCount == 0)
DropCount = 1;
lcd.setCursor(0,1);
lcd.print("Min Drops = 1");
outloop();
// Convert ADC value to key number
int get_key(unsigned int input)
int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
if (k >= NUM_KEYS)
k = -1; // No valid key pressed
return k;
void outloop()
loopcount1 = loopcount1++;
lcd.setCursor(8,1);
lcd.setCursor(0,1);
if (DropCount == 1)
digitalWrite(backLight,LOW); //Backlight OFF
digitalWrite(13,HIGH);
digitalWrite(valveControl,LOW); //Valve ON
delay (pulseWidth0);
digitalWrite(valveControl,HIGH);
digitalWrite(13,LOW);
delay(2000); // Make sure Camera is done
digitalWrite(backLight,HIGH); //Backlight ON
else if (DropCount == 2)
digitalWrite(valveControl,HIGH); //Valve OFF
delay(pulseSep0);
delay (pulseWidth1);
else if (DropCount == 3)
delay(pulseSep0);
delay(pulseSep1);
delay (pulseWidth2);
return;
