Stupid C question
Why does this not work...
case 'R': {
        char resolution[12] = {'\0'};  // no "R"
        for (int i = 0 ;Serial.available() > 0 ;i++ ){
          resolution[i] = Serial.read();
        Serial.println(resolution);
        // tab in [5]
        resolution[5] =  '\0';
        resolution[11] =  '\0';
        for (int x = 0;x<11;x++){
           Serial.println(resolution[x], BYTE);
        DECSteps = atoi((char*)resolution);
        RASteps = atoi((char*)(resolution[6]));
        Serial.println(DECSteps); //debug out
        Serial.println(RASteps); //debug out
        //respond to command
        Serial.write("R");
        Serial.flush();  // one can never be too sure...
On an input of "R12345x67890" I get:
number of characters in buffer:1
12345x67890
1
2
3
4
5
null
6
7
8
9
0
12345
0
R
At the end I'm expecting
12345
67890
R
Is this not valid?
I'm thrashing here, help appreciated!
If you change to
DECSteps = atoi((char*)resolution[0]);
does that one fail as well?
Yes - hmmm....
I get:
0
0
R
Also, this
        char* raString = &resolution[6];
        RASteps = atoi((char*)(raString));
Gives
12345
2354
R
I think your problem is earlier up:
I think that's only ever going to get 1 character at a time because the loop operates much faster than characters can arrive.
This seems to work:
char resolution[12] = {'1','2','3','4','5',0,'3','2','1','2','3',0};
int DECSteps = atoi(&resolution[0]);
int RASteps = atoi(&resolution[6]);
But I'm getting them all as per the output in the original:
12345x67890
1
2
3
4
5
null
6
7
8
9
0
My K & R second edition is failing me on pointers and char[]!
P.
Note that
2354 is 0x932
and
67890 is 0x10932
This:
case 'R': {
        for (int i = 0 ;i < 12 ;i++ ){
        // tab in [5]
        resolution[5] =  0;
        resolution[11] =  0;
Gives me:
12345x67890ÿÂ
1
2
3
4
5
null
6
7
8
9
0
12345
2345
R
Note that
2354 is 0x932
and
67890 is 0x10932
Yep - that was it - overflow...
It does work as expected with smaller numbers, thank you!
