Stupid PIR Sensor
Hello, I have been trying for a while to get a RIP motion sensor to work. This is the sensor https://www.sparkfun.com/products/8630 I have wired it exactly as in this picture. http://bildr.org/blog/wp-content/uploads/2011/06/PIR-Arduino_hookup.png Here is my code:
int pirPin = 2; //digital 2
void setup(){
 pinMode(pirPin, INPUT);
void loop(){
  int pirVal = digitalRead(pirPin);
  if(pirVal == LOW){ //was motion detected
    Serial.println("Motion Detected");
    delay(150);
Can someone please help me? Thanks!!
Sure. What is the problem?
Sparkfun says that it is a 12V sensor. You are powering it from 5V.
Have you verified the value of the resistor you are using?
Yes, I do have a 10K ohm resistor, I will try powering it with 12V. It is not returning any data, and it quite frustrating, as it is a remarkably simple device.
No data? Or, not the data you want?
After fiddling some more, I get it saying there is motion even when it is in a dark box. Here is my new code. The data I want is pin 2 to go LOW if there is motion, and HIGH if there is not. Here is my slightly updated code:
void setup(){
void loop(){
    delay(150);
  }else{
    Serial.println("No Motion");
And I am now using a Ni-MH 12V battery.
For what? A schematic is essential.
