Hello,
I have been trying to write a program which prints the contents of an SD card (able to do that from the examples given). After printing the card contents, I am want for the user to be able to type in a directory on the card within the serial monitor. Then the contents of the Sd card should be searched, if there is a match between what the user typed and a file on the card - this should then open that directory into a sub directory, the user then being able to select one of the specific files in that sub-directory.
This is what I have so far, I am able to type in the initial directory. I think the problem lies within the line
File userInput = printSound.openNextFile();
As it always opens the first directory on the card and not the one the user has typed in.
here is the rest of the code:
#include <Arduino.h>
#include <SD.h>
#include <SdFat.h>
#include <Audio.h>
#include <String.h>
//#define _SD_DAT3 46
#define numSampleFiles 12
//File root;
File currentDirectory;
File soundDirectory;
String fileExtension = ".wav";
String userInput;
char dataChar[16] = {'\0'};
char fileNameBuff[80]; //Vector<string> filenames;
char newfileNameBuff[80];
char rootSampleDir[25];
samples samps [numSampleFiles];
const long maxSampleLength = 1200000;
int numItems;
void printDir(File currentDirectory, int numTabs);
void scanFile(File printSound);
#define MOSI_PIN 11
#define SCK_PIN 13
#define CS_PIN = BUILTIN_SDCARD
//SPI.setMOSI(MOSI_PIN);
//SPI.setSCK(SCK_PIN);
while(!Serial);
Serial.println("Initializing MicroSD"); // Message whilst waiting for the SD card to be inserted
if (!SD.begin(BUILTIN_SDCARD)) // If not inserted
Serial.println("MicroSD card not initialized"); // Infinite Loop so that it is clear no SD card has been inserted
while (1);
Serial.println("MicroSD card initialized!"); // otherwise print message to show it has been inserted
currentDirectory = SD.open("/");
soundDirectory = SD.open("/");
printDir(currentDirectory, 0);
scanFile(soundDirectory);
for (int i = 0; i < numSampleFiles; i++)
sprintf(samps[i].fileName, "S%d.wav", i+1);
if (!SerialFlash.exists(samps[i].fileName)){
SerialFlash.createErasable(samps[i].fileName, maxSampleLength);
//See what's in our root Sample directory
sprintf(fileNameBuff, "/");
sprintf(rootSampleDir, "/");
//currentDirectory = SD.open(rootSampleDir);
//printDir(currentDirectory, 0);
Serial.println("contents printed");
void printDir(File dir, int numTabs)
//Serial.println("TESTING");
while(true)
File entry = dir.openNextFile();
if (!entry)
//currentDirectory.rewindDirectory(); //This gets stick in a constant loop?
numItems = numItems+1;
for(uint8_t i = 0; i < numTabs; i++)
Serial.print('\t');
Serial.print(entry.name());
if(entry.isDirectory())
Serial.println("/");
printDir(entry, numTabs + 1);
Serial.print("\t\t");
delay(1);
entry.close();
Serial.println("\nPlease type in a directory: ");
while(Serial.available()==0)
//This keeps the serial looped until something is typed
while(1)
userInput = Serial.readString(); //Takes user input
Serial.println(userInput); //prints user input
//File select = printSound.openNextFile();
File userInput = printSound.openNextFile(); //Maybe this should be open SELECT file - not just next?
Serial.println(userInput.name());
if(userInput.isDirectory())
scanFile(userInput);
Serial.println("selected directory is: " + userInput);
hope this makes sense. Thanks!
J
