Sub-menu not working correctly
In the "Menu1" sub-menu, not able to rotate the knob to select different options and press the knob to confirm my selection, "case 0;" is start working as we inter the "Menu1" sub-menu"
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // Initialize the I2C LCD with the address 0x27 and size 16x2
const int encoderCLK = 7; // CLK pin of the rotary encoder
const int encoderDT = 6;  // DT pin of the rotary encoder
const int encoderSW = 5;  // SW pin of the rotary encoder (push button)
const int ledPin = 13;     // Pin for the LED
int lastEncoderCLKState = HIGH;
int currentEncoderCLKState;
int menuIndex = 0;
int subMenuIndex = 0;
bool inSubMenu = false; // To track whether in sub-menu A or not
// Define the menu structure
const char mainMenuItems[3][10] = {"Menu1", "Menu2", "Menu3"};
const char subMenuAItems[4][10] = {"SubMenu1", "SubMenu2", "SubMenu3", "SubMenu4"};
  lcd.init();
  lcd.backlight();  // Turn on the backlight
  lcd.print("Main Menu:");
  lcd.setCursor(0, 1);
  lcd.print(mainMenuItems[menuIndex]); // Display the current main menu item
  pinMode(encoderCLK, INPUT_PULLUP); // Set CLK pin as input with internal pull-up resistor
  pinMode(encoderDT, INPUT_PULLUP);  // Set DT pin as input with internal pull-up resistor
  pinMode(encoderSW, INPUT_PULLUP);  // Set SW pin as input with internal pull-up resistor
  pinMode(ledPin, OUTPUT); // Set LED pin as output
  // Read the state of the rotary encoder
  currentEncoderCLKState = digitalRead(encoderCLK);
  // Check if the encoder has been rotated
  if (currentEncoderCLKState != lastEncoderCLKState) {
    if (digitalRead(encoderDT) != currentEncoderCLKState) {
      menuIndex = (menuIndex - 1 + 3) % 3; // Move to the previous main menu item
      menuIndex = (menuIndex + 1) % 3; // Move to the next main menu item
    displayMainMenu();
  // Check if the push button on the rotary encoder is pressed
  if (digitalRead(encoderSW) == LOW) {
    if (!inSubMenu) {
      if (menuIndex == 0) {
        inSubMenu = true;
        displaySubMenuA();
      } else if (menuIndex == 1) {
        lcd.clear();
        lcd.print("Menu2");
        lcd.clear();
      } else if (menuIndex == 2) {
        lcd.clear();
        lcd.print("Menu3");
        lcd.clear();
void displayMainMenu() {
  lcd.print("                "); // Clear the current line
void displaySubMenuA() {
  lcd.clear();
  lcd.print("Menu1:");
  lcd.print(subMenuAItems[subMenuIndex]); // Display the current sub-menu A item
  while (inSubMenu) {
        subMenuIndex = (subMenuIndex + 1) % 4; // Move to the next sub-menu A item
         subMenuIndex = (subMenuIndex - 1 + 4) % 4; // Move to the previous sub-menu A item
      switch (subMenuIndex) {
        case 0:
         lcd.clear();
          lcd.print("5");
          inSubMenu = false;
          subMenuIndex = 0;
      delay(5000);
      lcd.clear();
        case 1:
          lcd.clear();
          lcd.print("15");
          inSubMenu = false;
          subMenuIndex = 0;
      delay(5000);
      lcd.clear();
        case 2:
          lcd.clear();
          lcd.print("20");
          inSubMenu = false;
          subMenuIndex = 0;
      delay(5000);
      lcd.clear();
        case 3:
          lcd.clear();
          lcd.print("30");
          inSubMenu = false;
          subMenuIndex = 0;
      delay(5000);
      lcd.clear();
    lastEncoderCLKState = currentEncoderCLKState;
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Hello abhixs
If you expect a realtime behaiviour of the program you have to get rid of the delay() function. This function blocks the execution.
	Line  59:         delay(1000);
	Line  67:         delay(1000);
	Line 111:       delay(5000);
	Line 127:       delay(5000);
	Line 138:       delay(5000);
	Line 149:       delay(5000);
Design and code your own none-blocking timer function by using the BlinkWithoutOut example of the IDE.
i removed delay but its not working, my only issue is that "case 0;" is start working as we inter the "Menu1" sub-menu" it should work after pressing the knob.
Next step for debugging:
Use a logic analyzer to see what happens.
Insert Serial.println()´s at points of interrest and analyze the test results.
Please post your revised code as a new message.
