I need help modifying an existing LoRa-based code setup. Currently, the code is designed to send data to a local server, but I would like to change it so that the data is instead sent to the Datacake cloud platform. Also, instead of reading data from only one sensor, the new setup should handle two sensors: the ENS160 air quality sensor and the BME280 atmospheric sensor.
Here is a quick overview of my setup:
Sender Node (no internet connection):
Raspberry Pi Pico connected to:
- ENS160 and BME280 sensors (via I2C, connected in series)
- Makerverse Nano Power Timer HAT
- Wio-E5 LE Mini (Seeed Studio) LoRa module (connected through UART)
Receiver Node (connected to the internet):
- LILYGO® TTGO LoRa32 868MHz (Banggood)
- This LoRa module receives data from the first module via LoRa radio
- It then forwards the received sensor data to Datacake over Wi-Fi
The code I need should:
- Collect data from both sensors using the Raspberry Pi Pico.
- Send this data via UART to the Wio-E5 Mini LoRa module.
- The second LoRa module (LILYGO TTGO LoRa32) should receive the LoRa message and upload it to the Datacake server via HTTP or MQTT.
Any help in adapting the code for this setup would be greatly appreciated.
Thank you!
Rui Santos & Sara Santos - Random Nerd Tutorials
Complete project details at ESP32 LoRa Sensor Monitoring with Web Server (Long Range Communication) | Random Nerd Tutorials
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
// Import Wi-Fi library
#include <WiFi.h>
#include "ESPAsyncWebServer.h"
#include <LittleFS.h>
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Libraries to get time from NTP Server
#include <NTPClient.h>
#include <WiFiUdp.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
#define BAND 866E6
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Variables to save date and time
String formattedDate;
String day;
String hour;
String timestamp;
// Initialize variables to get and save LoRa data
int rssi;
String loRaMessage;
String temperature;
String humidity;
String pressure;
String readingID;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
// Replaces placeholder with DHT values
String processor(const String& var){
//Serial.println(var);
if(var == "TEMPERATURE"){
return temperature;
else if(var == "HUMIDITY"){
return humidity;
else if(var == "PRESSURE"){
return pressure;
else if(var == "TIMESTAMP"){
return timestamp;
else if (var == "RRSI"){
return String(rssi);
return String();
//Initialize OLED display
void startOLED(){
//reset OLED display via software
pinMode(OLED_RST, OUTPUT);
digitalWrite(OLED_RST, LOW);
delay(20);
digitalWrite(OLED_RST, HIGH);
//initialize OLED
Wire.begin(OLED_SDA, OLED_SCL);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0,0);
display.print("LORA SENDER");
//Initialize LoRa module
void startLoRA(){
int counter;
//SPI LoRa pins
SPI.begin(SCK, MISO, MOSI, SS);
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
while (!LoRa.begin(BAND) && counter < 10) {
Serial.print(".");
counter++;
if (counter == 10) {
// Increment readingID on every new reading
Serial.println("Starting LoRa failed!");
Serial.println("LoRa Initialization OK!");
display.setCursor(0,10);
display.print("LoRa Initializing OK!");
display.display();
delay(2000);
void connectWiFi(){
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
display.setCursor(0,20);
display.print("Access web server at: ");
display.setCursor(0,30);
display.print(WiFi.localIP());
display.display();
// Read LoRa packet and get the sensor readings
void getLoRaData() {
Serial.print("Lora packet received: ");
// Read packet
while (LoRa.available()) {
String LoRaData = LoRa.readString();
// LoRaData format: readingID/temperature&soilMoisture#batterylevel
// String example: 1/27.43&654#95.34
Serial.print(LoRaData);
// Get readingID, temperature and soil moisture
int pos1 = LoRaData.indexOf('/');
int pos2 = LoRaData.indexOf('&');
int pos3 = LoRaData.indexOf('#');
readingID = LoRaData.substring(0, pos1);
temperature = LoRaData.substring(pos1 +1, pos2);
humidity = LoRaData.substring(pos2+1, pos3);
pressure = LoRaData.substring(pos3+1, LoRaData.length());
// Get RSSI
rssi = LoRa.packetRssi();
Serial.print(" with RSSI ");
Serial.println(rssi);
// Function to get date and time from NTPClient
void getTimeStamp() {
while(!timeClient.update()) {
timeClient.forceUpdate();
// The formattedDate comes with the following format:
// 2018-05-28T16:00:13Z
// We need to extract date and time
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
// Extract date
int splitT = formattedDate.indexOf("T");
day = formattedDate.substring(0, splitT);
Serial.println(day);
// Extract time
hour = formattedDate.substring(splitT+1, formattedDate.length()-1);
Serial.println(hour);
timestamp = day + " " + hour;
// Initialize Serial Monitor
startOLED();
startLoRA();
connectWiFi();
if(!LittleFS.begin()){
Serial.println("An Error has occurred while mounting LittleFS");
return;
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(LittleFS, "/index.html", String(), false, processor);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", temperature.c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", humidity.c_str());
server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", pressure.c_str());
server.on("/timestamp", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", timestamp.c_str());
server.on("/rssi", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", String(rssi).c_str());
server.on("/winter", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(LittleFS, "/winter.jpg", "image/jpg");
// Start server
server.begin();
// Initialize a NTPClient to get time
timeClient.begin();
// Set offset time in seconds to adjust for your timezone, for example:
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
timeClient.setTimeOffset(0);
// Check if there are LoRa packets available
int packetSize = LoRa.parsePacket();
if (packetSize) {
getLoRaData();
getTimeStamp();
This image shows the hardware setup for collecting sensor data:
Raspberry Pi Pico is mounted on a Power HAT (Makerverse Nano Power Timer), which provides power and can turn the system on/off to save energy.
Two sensors are connected in series using PiicoDev cables:
- ENS160 – Air Quality Sensor
- BME280 – Temperature, Humidity, and Pressure Sensor
The sensors use I2C communication, sharing the same SDA and SCL lines with the Pico.
Note:
The LoRa modules are not shown in the image. The Raspberry Pi Pico will send the sensor data via UART to the Wio-E5 Mini (LoRa module), which will transmit it to another LoRa board (LILYGO TTGO LoRa32) that uploads the data to Datacake via Wi-Fi.Use code tags to format code for the forum
