Hi! Can you please help me with my code? I attach a copy below. Sorry, I unintentionally made it hard to read.``
Firstly, I understand that this is not how code should work.
code concept:
beforeshuffle[] = (1,2,3,4,5,6,7,8)
aftershuffle[] = (5,2,4,1,3,7,6,8)
A = aftershuffle[0,1] = {5,2}
B = aftershuffle[2,3] = {4,1}
C = aftershuffle[4,5] = {3,7}
D = aftershuffle[6,7] = {6,8}
executecode[] = {B,A,C,B,A,D,C,D}
A rotates motor 1 clockwise
B rotates motor 1 anticlockwise
C rotates motor 2 clockwise
D rotates motor 2 anticlockwise
There are problems that I want to avoid or unsure of how to solve:
- motors that rotate at irregular timings
- checking if the elements is in the array of A,B,C or D. (I would avoid 'if' function if it is possible to substitute like in the picture)
- reading executecode "from bottom to top"
- confusion of how Arduino interact with circuit
void setup(){}
void loop(){
int executecode[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51};
int questionNumberArray[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51};
int A; int B; int C; int D;
int y;
const size_t n = sizeof(questionNumberArray) / sizeof(questionNumberArray[0]);
for (size_t i = 0; i < n - 1; i++)
size_t j = random(0, n - i);
int t = questionNumberArray*;*
_ questionNumberArray = questionNumberArray[j];_
* questionNumberArray[j] = t;*
questionNumberArray[0,1,2,3,4,5,6,7,8,9,10,11,12] = A;
questionNumberArray[13,14,15,16,17,18,19,20,21,22,23,24,25] = B;
questionNumberArray[26,27,28,29,30,31,32,33,34,35,36,37,38] = C;
questionNumberArray[39,40,41,42,43,44,45,46,47,48,49,50,51] = D;
for (y = -1;y <52; y= y + 1){
if (executecode[y]== A);
{pinMode(10,OUTPUT);
pinMode(12,INPUT);
digitalWrite(10,HIGH);
digitalWrite(12,HIGH);}
{pinMode(12,OUTPUT);
pinMode(10,INPUT);
digitalWrite(10,HIGH);}
{pinMode(6,OUTPUT);
pinMode(8,INPUT);
digitalWrite(6,HIGH);
digitalWrite(8,HIGH);}
{pinMode(8,OUTPUT);
pinMode(6,INPUT);
digitalWrite(6,HIGH);}
[code]
[/code]
