Hi..
Hope someone can explain something to me, I'm certain it's a nuance of the language...
Running this code on a UNO.
I have a couple of globals declared thus..
long runMillis = 0;
long timerA = 0;
In one of my methods I declare a local longs thus..
long millisNow = millis();
long delta = millisNow - timerA; // delta = how long since the timer was reset
long timeToRun = runMillis - delta; // How many more millis left for the lights to run
runMillis = runMillis - delta; // Load runMillis with the new value
Issue is that the last statement runMillis = runMillis etc... sets runMillis to a weird value (a small negative one)
to be a little more verbose, timerA is set a value in another method by..
timerA = millis();
timeToRun is set correctly, why isn't runMillis??
Thanks in advance
Dave
PS, full sketch below...
// Declare pin assignments
const int tButton = 2;
const int runLed = 8;
const int HrLed1 = 9;
const int HrLed2 = 10;
const int HrLed3 = 11;
const int HrLed4 = 12;
// const long OneHour = 3600000; //Milliseconds in an hour
const long OneHour = 5000; //Milliseconds in 10 secs (Testing)
//Declare variables
boolean lightsOn = false;
int runHours = 0; // How many periods(Hrs??) the lights have to run for
long runMillis = 0; // How many actual milliseconds the lights have to be on for
long timerA = 0; // Used to count how long between button presses
// Declared methods
void adjustTimer()
if(runHours ==4) // Max time reached, we need to roll over to zero and turn off everything
runHours = 0;
runMillis = 0;
lightsOn = false;
digitalWrite(runLed, LOW);
runHours +=1;
runMillis += OneHour;
lightsOn = true;
digitalWrite(runLed, HIGH);
Serial.print("runHours :");
Serial.print(runHours);
Serial.print(" runMillis :");
Serial.println(runMillis);
void decTimer() //Count lights on timer down
// Check how long the lights have been on since last key press..
// runMillis = runMillis - delta; // Load runMillis with the new value
if(timeToRun <=0) // Timer has counted down to zero - turn off everything
Serial.println("*** Timer Expired ***");
Serial.print(" delta :");
Serial.print(delta);
Serial.print(" millisNow :");
Serial.print(millisNow);
Serial.print(" timerA :");
Serial.print(timerA);
Serial.print (" runMillis :");
runHours = 0;
runMillis = 0;
lightsOn = false;
//Set pinmode for all pins...
pinMode(tButton, INPUT);
digitalWrite(tButton, HIGH);
pinMode(HrLed1, OUTPUT);
digitalWrite(HrLed1, LOW);
pinMode(HrLed2, OUTPUT);
digitalWrite(HrLed2, LOW);
pinMode(HrLed3, OUTPUT);
digitalWrite(HrLed3, LOW);
pinMode(HrLed4, OUTPUT);
digitalWrite(HrLed4, LOW);
pinMode(runLed, OUTPUT);
// Get button event and act accordingly
int b = checkButton();
if (b == 1) clickEvent();
if(lightsOn)
decTimer();
void clickEvent()
// Button has been clicked, so do the following..
timerA = millis(); // restart the timer
adjustTimer();
