Subtraction of temperature values
I am printing a temperature difference to the lcd.
When the diff becomes larger than 10 and then goes below 10 there is a lingering value in the one's digit. The ten's digit contains the new temp(single digit).
I know the bulk of the code is not very elegant or efficient. That is for another day.
Can you help me with the subtraction code.
#include <RTClib.h>    //include necessary libraries
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2     //data line is plugged into pin 2
OneWire oneWire(ONE_WIRE_BUS); //set up a oneWire instance to communicate with oneWie device(s)
DallasTemperature sensors(&oneWire); //pass oneWire reference to DallasTemperature library
RTC_DS3231 rtc; //initialize the DS3231
LiquidCrystal_I2C lcd(0x27,20,4);  //set the address and size of the LCD display
File myFile;  //name an instance of the SD module myFile
const unsigned long eventTime_1_Serial = 5000;  //define numerical format of the three time counters
const unsigned long eventTime_2_SD = 60000;     //and set the lendths of the three time delays
const unsigned long eventTime_3_LCD = 1000;
unsigned long previousTime_1 = 0;  //set the initial count of the timer to zero
unsigned long previousTime_2 = 0;
unsigned long previousTime_3 = 0;
int difference = 0;
  Serial.begin(9600);  //open the serial port
    delay(3000); //wait 6 secs for the serial port to open
  sensors.begin();  //open the sensors
  sensors.setResolution(12);  //set the sensor resolution to 12
  lcd.init();  //open the lcd
  lcd.backlight();
  rtc.begin();  //open the RTC
  while (!Serial) {         //check that sd card is present
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
    if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower()) {     //check that sd card hasn't lost power or battery is dead
    Serial.println("RTC lost power, lets set the time!");
  SD.remove("today.txt");  //clear the sc card of previous recordings
  myFile = SD.open("today.txt", FILE_WRITE);  //create and open an sd file named today.txt
  if (myFile) {   //getting ready to print column headers in sd file
    Serial.print("Writing to today.txt...");
    myFile.print("Year/Month/Day");
    myFile.print(" ");
    myFile.print("Hour");
    myFile.print(':');
    myFile.print("Minute");
    myFile.print(",");
    myFile.print("Temp In");
    myFile.print(",");
    myFile.print("Temp Out");
    myFile.println();
    myFile.close();
  unsigned long currentTime = millis();   //defining numeric format and setting current time to millis time
  DateTime now = rtc.now();   //get real current time and date from RTC
if( currentTime - previousTime_1 >= eventTime_1_Serial ){   //tests if millis time is ready for first event, serial print
  Serial.print(now.year(), DEC);  //serial print date, time, and two temps
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(",");
  Serial.print(now.hour(),DEC);
  Serial.print(':');
  if(now.minute() < 10){  //puts a leading zero to single digit minutes
      Serial.print("0");
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  if(now.second() < 10){   //puts a leading zero to single digit secs
      Serial.print("0");
  Serial.print(now.second(), DEC);
  Serial.print("...");
  Serial.println("DONE");
    Serial.print(" Requesting temperatures...");
 sensors.requestTemperatures();
 Serial.print("Temperatures are: ");
  Serial.print(sensors.getTempFByIndex(0));
  Serial.println(sensors.getTempFByIndex(1));
  previousTime_1 = currentTime;  //first timed event completed and counter1 reset
 if( currentTime - previousTime_2 >= eventTime_2_SD ){   //tests if millis time is ready for second event, sd write
   myFile = SD.open("today.txt", FILE_WRITE);  //opens the file and gets ready to write
if (myFile) {   //if file is open, write year, month, day, hour, min, and two temps
   myFile.print(now.year(), DEC);
    myFile.print('/');
    myFile.print(now.month(), DEC);
    myFile.print('/');
    myFile.print(now.day(), DEC);
    //myFile.print(",");
    myFile.print(now.hour(), DEC);
    myFile.print(':');
    myFile.print(now.minute(), DEC);
    myFile.print(",");
    myFile.print(sensors.getTempFByIndex(0));
    myFile.print(",");
    myFile.println(sensors.getTempFByIndex(1));
    myFile.close();
    previousTime_2 = currentTime;  //second timed event completed and counter2 reset
 if( currentTime - previousTime_3 >= eventTime_3_LCD ){   //tests if millis time is ready for third event, lcd display
    lcd.setCursor (0, 0 );  //display two temps, month, day, year, hour, min, sec
    lcd.print(" TIn:");
    lcd.print(sensors.getTempFByIndex(0),0);
    lcd.print("F  ");
    lcd.print(" TOut:");
    lcd.print(sensors.getTempFByIndex(1),0);
    lcd.print("F");
    lcd.setCursor(4,1);
    lcd.print("Temp Diff:");
    difference = (sensors.getTempFByIndex(0))-(sensors.getTempFByIndex(1));
    lcd.print(difference);
    lcd.setCursor (5, 2 );
    lcd.print(now.month(), DEC);
    lcd.print('/');
    lcd.print(now.day(), DEC);
    lcd.print('/');
    lcd.print(now.year(), DEC);
    lcd.print(" ");
    lcd.setCursor (6,3);
    lcd.print(now.hour(),DEC);
    lcd.print(':');
      lcd.print("0");
    lcd.print(now.minute(), DEC);
    lcd.print(':');
    lcd.print("0");
    lcd.print(now.second(), DEC);
    previousTime_3 = currentTime; //third timed event completed and counter3 reset
The LCD does not forget what was previously written. This will overwrite characters left at the end of the line, from the previous print statement.
    lcd.setCursor(4,1);
   lcd.print("  ");  //erase last two characters
or if you really want to clean up, just write enough spaces to the end of the line before updating the value
(the risk with writing 2 spaces is that it might not be enough or be too much if you are getting close to the end of the line)
Thank you both.
JML's solution has the difference flashing on/off very quickly. More than once/sec. Is there a way to prevent that?
Yes. Always write out every value you print, including all the spaces.
To overwrite with blanks, followed by overwriting with digits, produces flashing. If you don't like the effect, don't do that.
Check if the value is the same, in that case don’t redraw
I added a check if value the same, only then overwrite.
Thanks for your help.
