Successfully enable the fuse of CLKOUT, but can not program Nano anymore.
I try to enable the fuse of CLKOUT in Arduino Nano, so I setup ArduinoISP with an Uno with Arduino IDE and change the board.txt of low fuses of arduino nano from 0xFF to 0x3F (divided by 8 clock out from PB0), then program the new bootloader into the arduino nano. I saw the 2MHz clock out from PB0. (This part is correct.)
But I used to program the arduino nano with the following command in Windows
avrdude -c arduino -p atmega328p -C ../avrdude.conf -b 115200 -P COM6 -U flash:w:blink.hex
now it doesn't work. The error messages are
avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x12 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x12 . . .
If I change the low fuses back to 0xFF, everything is working again (except no CLKOUT).
If programming through Arduino is not a good idea, I am willing to change to other methods (I am buying a USBasp programmer). But I am suspicious that the problem is something else. Suggestions are welcome.
You lowered the system clock rate, so I'm pretty sure you need to lower this to match: 115200
Thanks for the suggestion.
I think I tested 9600 too. But let me setup and retest again.
CrossRoads: You lowered the system clock rate, so I'm pretty sure you need to lower this to match: 115200
I reconstruct the setup and duplicate the problem. Then I try
avrdude -c arduino -p atmega328p -C ../avrdude.conf -b 9600 -P COM6 -U flash:w:blink.hex
the same problem.
I saw a puzzle in the process, maybe I should clarify this symptom first. After burn the new bootloader, I tried to upload a blink sketch from Arduino IDE, it seems to success. But now both Uno and Nano are both flash with the blink speed. However if I detached the Uno and power up the Nano alone, the Nano didn't blink. So it seems that the upload is not go to Nano? (If I leave the connect wire of Uno and Nano there, both boards will still blink with the earlier upload speed.)
I try to program the low fuse without divided clock by 8, then everything works good (great!). So the problem is indeed somehow related to the divided by 8 fuse bit.
I can work on the clock without divided by 8, but it will be nice to know how to fix the original problem. (Now I think about it, it indeed is confusing whether the system clock is now crystal's 16MHz, or 2MHz if the divided by 8 fuse is programmed.)
3F programs both the CLKOUT and the DIV8 fuses, so you need bootload and core adjusted for the new (2MHz) clock speed.
Then I try avrdude -c arduino -p atmega328p -C ../avrdude.conf -b 9600 -P COM6 -U flash:w:blink.hex [and it doesn't work.]
The normal rate is 115200. If you divide the clock by 8, you need to use a bitrate of 115200/8, which is 14400; not 9600. (that's if you haven't used a special bootloader set up for a different clock/bitrate. The bootloader runs at a fixed bitrate proportional to the clockrate, without any sort of autobaud that would allow it to operate at other bitrates. The "-b 115200" has to exactly match the speed the bootloader and clock that is expected.
Thanks for information.
westfw: The normal rate is 115200. If you divide the clock by 8, you need to use a bitrate of 115200/8, which is 14400; not 9600.
That sounds very reasonable. But I try it few times with "-b 14400" and burn few times of bootloaders, it just doesn't work. Should be something still not set right.
Maybe with bare chip it will work, but this seems to be a problematical setting that I will avoid to work with Arduino boards.
You could also just program it with an ISP programmer and not use a bootloader? But timekeeping would be off by factor of 8 unless you use a board def with F_CPU=2MHz.
Or, if you just need a 2 MHz clock output you could run it at the full 16 like normal,and just reconfigure Timer1 or Timer2 to give you a 2 MHz clock output on one of it's PWM pins (and you lose PWM on another pin)
Timer2, TCCR2A=0x23, TCCR2B=0x01, OCR2A=0x07, OCR2B=0x04 (7 + 1 = 8 clock per cycle, no prescale (so 16MHz/8=2MHz), clear OC2B on match set at BOTTOM, compare match on OC2B (arduino pin 3, PD3) at 0x04 for 50% duty cycle. Takes out Pin 11 PWM too.
Timer1, TCCR1A=0x82, TCCR1B=0x19, OCR1A=0x04, ICR1=0x07 (as above, output on OC1A, swap OCR1B and change TCCR1A to 0x22 for output on OC1B) (1A, 1B are PB1, PB2, arduino pins 9 and 10, takes out PWM on the other pin too)
(off the top of my head. Pin has to be set output)
DrAzzy: You could also just program it with an ISP programmer and not use a bootloader? But timekeeping would be off by factor of 8 unless you use a board def with F_CPU=2MHz.
The problem seems to be on UART. I use Uno to program bootloader to Nano to output 2MHz clock, then I can upload blink sketch through Uno as ISP to Nano, that is no problem. The clock is now 8 times slower as I can tell from the blink speed. But I just can not upload program using COM port though my Nano board's CH340G.
I also play around F_CPU, but still can not make it right.
DrAzzy: Or, if you just need a 2 MHz clock output you could run it at the full 16 like normal,and just reconfigure Timer1 or Timer2 to give you a 2 MHz clock output on one of it's PWM pins (and you lose PWM on another pin)
This is what I did, so there is no reason I have to use the fuse approach to generate 2MHz clock. I came back to problem because I want to use full 16MHz clock on the CLKO pin by programming lower fuse to 0xBF. That part is working fully though.
I will close this issue now, thank you all for the valuable information.
