noiasca
January 21, 2023, 9:53am
21
mit meinen Annahmen:
ab einem interessanten Wert fallende Werte beobachten
wenn der neue Werte wieder steigt, den alten Wert als Tiefpunkt betrachten
Auswertung für eine bestimmte Zeit sperren
// https://forum.arduino.cc/t/suche-logik-zur-berechnung-taktdauer-heizung/1080005/
// ab einem interessanten Wert fallende Werte beobachten
// wenn der neue Werte wieder steigt, den alten Wert als Tiefpunkt betrachten
// Auswertung für eine bestimmte Zeit sperren
// unkommentiert vom TO
// to be deleted 2023-03
const byte potPin = A2;
float currentTemp;
uint32_t utc;
uint32_t getTime()
return (millis() / 1000);
void measure()
int raw = analogRead(potPin);
currentTemp = map(raw, 0, 1023, 0, 40);
bool checkMeasure() // check new measurement if criterion is fullfilled
const float threashold = 28;
const uint32_t minInterval = 10; // in the example ... 10 sec
static uint32_t lastTime = 0-minInterval; // last time of LOW value
static float lastTemp = 40; // last low value
static float previousTemp = 40; // previous temperature
static uint32_t previousTime = 0; // time of previous temperature
uint32_t currentTime = getTime();
byte result = false;
enum State{BLOCK, CHECK};
static State state = BLOCK;
switch (state)
case BLOCK:
if (currentTime - lastTime > minInterval)
Serial.println(F("--> CHECK"));
state = CHECK;
case CHECK:
if (currentTemp < threashold && currentTemp < previousTemp)
Serial.println(F(" new value is LOWER"));
if (currentTemp > previousTemp)
Serial.println(F(" new value is HIGHER")); // RAISING again
lastTemp = previousTemp;
lastTime = previousTime;
Serial.print(F("lowest value was")); Serial.print (lastTemp); Serial.print(F(" @ ")); Serial.println(lastTime);
Serial.println(F("fire"));
Serial.println(F("--> BLOCK"));
state = BLOCK;
result = true;
previousTemp = currentTemp;
previousTime = currentTime;
return result;
void timerMeasure(uint32_t currentMillis = millis())
static uint32_t previousMillis = 0;
if (currentMillis - previousMillis > 1000) // messinterval
measure();
Serial.print(F("currentTemp=")); Serial.println(currentTemp);
Serial.println(checkMeasure());
randomSeed(A5);
timerMeasure();
edit: nie ein Feedback vom TO erhalten, wokwi gelöscht.
progger
January 22, 2023, 6:49am
22
Danke für eure Vorschläge
Die helfen mir etwas!!! Danke nochmals.
Ich habe gestern intensiv meine Logs analysiert und stelle da nachher gleich mehr Infos rein
mit mehr Daten&Grafik.
Die Charakteristik der „Tiefpunkte“ ist nämlich bei Taktende zum neuen Takt und der WW Aufbereitung zwischendurch sehr, sehr ähnlich.
Da kann man (denke ich) nichts mit „Tiefpunkten“
errechnen, da sie einfach zu ähnlich sind…..
Vielleicht seht ihr ja noch eine Unterscheidungsmöglichkeit.
Ich kenne ja die WW Zeiten, die könnte ich dann ausklammern.
Oder die WW Aufbereitung einfach als Takt mitzählen… wäre jetzt auch nicht soooooo schlimm.
Ganz dumme Frage: Hast Du irgendwo eine LED oder sonstwas, wo Du erkennen kannst, ob der Heizkreis aktiv ist? (Alternativ die WW-Bereitung)
Da nen Fototran-/resisistor ran und erledigt das Teil.
Auf diese Weise hatte ich mal die Waschmaschine im Keller mit der Fertig-Meldung nachgerüstet....
Und wenn das gar nicht geht, hast Du für den Heizkreis eine eigene Pumpe, oder kannst an den Mischer ran und da die Verstellung elektrisch überwachen?
progger
January 22, 2023, 10:33am
24
Auch eine coole Idee Bei dieser geht das leider nicht, da nur ein Display verbaut ist...
Wenn alles scheitert, wäre das eine Möglichkeit Das behalte ich mal im Hinterkopf
Danke dir!
progger
January 22, 2023, 10:50am
25
Hier nochmal ein Diagramm mit zugehöriger Logdatei. Evtl. könnt ihr da ja noch etwas ableiten, wie man eine genaue Logik programmieren könnte
Die Heizung kommt aus einem langen Heiztakt in der Nacht, dann fährt der Mischer zu, Kesseltemp steigt und geht dann in die 20min Taktsperre.
Ein neuer Takt startet und wird um 7:30h morgen von der WW Aufbereitung unterbrochen.
Die läuft dann bis 8:30h (das ist der kleine Ausreißer nach unten)
Ich denke aber, dass das Absinken bei der WW Aufbereitung auch tiefer gehen könnte, wenn der Start WW zufällig in die Absinkende Flanke eines gerade beendeten Taktes fällt...
Also wohl doch diese Zeiten der Warmwasserbereitung "sperren" ..... ?
Evtl. kann man das softwaremäßig gar nicht lösen...
Log:
1674274455 21.01.2023 04:14:15 36.4
1674274475 21.01.2023 04:14:35 36.4
1674274495 21.01.2023 04:14:55 36.4
1674274515 21.01.2023 04:15:15 36.4
1674274535 21.01.2023 04:15:35 36.4
1674274555 21.01.2023 04:15:55 36.4
1674274575 21.01.2023 04:16:15 36.4
1674274595 21.01.2023 04:16:35 36.4
1674274615 21.01.2023 04:16:55 36.4
1674274635 21.01.2023 04:17:15 36.4
1674274655 21.01.2023 04:17:35 36.4
1674274675 21.01.2023 04:17:55 36.4
1674274695 21.01.2023 04:18:15 36.4
1674274715 21.01.2023 04:18:35 36.4
1674274735 21.01.2023 04:18:55 36.4
1674274755 21.01.2023 04:19:15 36.4
1674274775 21.01.2023 04:19:35 36.4
1674274795 21.01.2023 04:19:55 36.4
1674274815 21.01.2023 04:20:15 36.4
1674274835 21.01.2023 04:20:35 36.4
1674274855 21.01.2023 04:20:55 36.4
1674274875 21.01.2023 04:21:15 36.4
1674274895 21.01.2023 04:21:35 36.4
1674274915 21.01.2023 04:21:55 36.4
1674274935 21.01.2023 04:22:15 36.4
1674274955 21.01.2023 04:22:35 36.4
1674274975 21.01.2023 04:22:55 36.4
1674274995 21.01.2023 04:23:15 36.4
1674275015 21.01.2023 04:23:35 36.4
1674275035 21.01.2023 04:23:55 36.4
1674275055 21.01.2023 04:24:15 36.4
1674275075 21.01.2023 04:24:35 36.4
1674275095 21.01.2023 04:24:55 36.4
1674275115 21.01.2023 04:25:15 36.4
1674275135 21.01.2023 04:25:35 36.4
1674275155 21.01.2023 04:25:55 36.4
1674275175 21.01.2023 04:26:15 36.4
1674275195 21.01.2023 04:26:35 36.4
1674275215 21.01.2023 04:26:55 36.4
1674275235 21.01.2023 04:27:15 36.4
1674275255 21.01.2023 04:27:35 36.4
1674275275 21.01.2023 04:27:55 36.4
1674275295 21.01.2023 04:28:15 36.4
1674275315 21.01.2023 04:28:35 36.4
1674275335 21.01.2023 04:28:55 36.4
1674275355 21.01.2023 04:29:15 36.4
1674275375 21.01.2023 04:29:35 36.4
1674275395 21.01.2023 04:29:55 36.4
1674275415 21.01.2023 04:30:15 36.4
1674275435 21.01.2023 04:30:35 36.4
1674275455 21.01.2023 04:30:55 36.4
1674275475 21.01.2023 04:31:15 36.4
1674275495 21.01.2023 04:31:35 36.4
1674275515 21.01.2023 04:31:55 36.4
1674275535 21.01.2023 04:32:15 36.4
1674275555 21.01.2023 04:32:35 36.5
1674275575 21.01.2023 04:32:55 36.5
1674275595 21.01.2023 04:33:15 36.5
1674275615 21.01.2023 04:33:35 36.5
1674275635 21.01.2023 04:33:55 36.6
1674275655 21.01.2023 04:34:15 36.6
1674275675 21.01.2023 04:34:35 36.6
1674275695 21.01.2023 04:34:55 36.6
1674275715 21.01.2023 04:35:15 36.6
1674275735 21.01.2023 04:35:35 36.7
1674275755 21.01.2023 04:35:55 36.8
1674275775 21.01.2023 04:36:15 36.8
1674275795 21.01.2023 04:36:35 36.9
1674275815 21.01.2023 04:36:55 37.0
1674275835 21.01.2023 04:37:15 37.1
1674275855 21.01.2023 04:37:35 37.2
1674275875 21.01.2023 04:37:55 36.9
1674275895 21.01.2023 04:38:15 36.3
1674275915 21.01.2023 04:38:35 35.7
1674275935 21.01.2023 04:38:55 35.0
1674275955 21.01.2023 04:39:15 34.4
1674275975 21.01.2023 04:39:35 33.9
1674275995 21.01.2023 04:39:55 33.4
1674276015 21.01.2023 04:40:15 32.9
1674276035 21.01.2023 04:40:35 32.6
1674276055 21.01.2023 04:40:55 32.2
1674276075 21.01.2023 04:41:15 31.9
1674276095 21.01.2023 04:41:35 31.6
1674276115 21.01.2023 04:41:55 31.3
1674276135 21.01.2023 04:42:15 31.1
1674276155 21.01.2023 04:42:35 30.8
1674276175 21.01.2023 04:42:55 30.6
1674276195 21.01.2023 04:43:15 30.4
1674276215 21.01.2023 04:43:35 30.2
1674276235 21.01.2023 04:43:55 30.0
1674276255 21.01.2023 04:44:15 29.8
1674276275 21.01.2023 04:44:35 29.6
1674276295 21.01.2023 04:44:55 29.5
1674276315 21.01.2023 04:45:15 29.4
1674276335 21.01.2023 04:45:35 29.3
1674276355 21.01.2023 04:45:55 29.1
1674276375 21.01.2023 04:46:15 28.9
1674276395 21.01.2023 04:46:35 28.8
1674276415 21.01.2023 04:46:55 28.8
1674276435 21.01.2023 04:47:15 28.6
1674276455 21.01.2023 04:47:35 28.5
1674276475 21.01.2023 04:47:55 28.4
1674276495 21.01.2023 04:48:15 28.3
1674276515 21.01.2023 04:48:35 28.2
1674276535 21.01.2023 04:48:55 28.1
1674276555 21.01.2023 04:49:15 28.1
1674276575 21.01.2023 04:49:35 27.9
1674276595 21.01.2023 04:49:55 27.9
1674276615 21.01.2023 04:50:15 27.8
1674276635 21.01.2023 04:50:35 27.8
1674276655 21.01.2023 04:50:55 27.6
1674276675 21.01.2023 04:51:15 27.6
1674276695 21.01.2023 04:51:35 27.6
1674276715 21.01.2023 04:51:55 27.4
1674276735 21.01.2023 04:52:15 27.4
1674276755 21.01.2023 04:52:35 27.4
1674276775 21.01.2023 04:52:55 27.3
1674276795 21.01.2023 04:53:15 27.3
1674276815 21.01.2023 04:53:35 27.2
1674276835 21.01.2023 04:53:55 27.1
1674276855 21.01.2023 04:54:15 27.1
1674276875 21.01.2023 04:54:35 27.1
1674276895 21.01.2023 04:54:55 27.0
1674276915 21.01.2023 04:55:15 26.9
1674276935 21.01.2023 04:55:35 26.9
1674276955 21.01.2023 04:55:55 26.9
1674276975 21.01.2023 04:56:15 26.8
1674276995 21.01.2023 04:56:35 26.8
1674277015 21.01.2023 04:56:55 26.8
1674277035 21.01.2023 04:57:15 26.7
1674277055 21.01.2023 04:57:35 26.9
1674277075 21.01.2023 04:57:55 27.8
1674277095 21.01.2023 04:58:15 28.8
1674277115 21.01.2023 04:58:35 29.5
1674277135 21.01.2023 04:58:55 30.1
1674277155 21.01.2023 04:59:15 30.5
1674277175 21.01.2023 04:59:35 30.8
1674277195 21.01.2023 04:59:55 31.1
1674277215 21.01.2023 05:00:15 31.3
1674277235 21.01.2023 05:00:35 31.6
1674277255 21.01.2023 05:00:55 31.8
1674277275 21.01.2023 05:01:15 31.9
1674277295 21.01.2023 05:01:35 32.1
1674277315 21.01.2023 05:01:55 32.3
1674277335 21.01.2023 05:02:15 32.5
1674277355 21.01.2023 05:02:35 32.6
1674277375 21.01.2023 05:02:55 32.8
1674277395 21.01.2023 05:03:15 32.9
1674277415 21.01.2023 05:03:35 33.1
1674277435 21.01.2023 05:03:55 33.3
1674277455 21.01.2023 05:04:15 33.4
1674277475 21.01.2023 05:04:35 33.6
1674277495 21.01.2023 05:04:55 33.8
1674277515 21.01.2023 05:05:15 33.9
1674277535 21.01.2023 05:05:35 34.0
1674277555 21.01.2023 05:05:55 34.1
1674277575 21.01.2023 05:06:15 34.2
1674277595 21.01.2023 05:06:35 34.3
1674277615 21.01.2023 05:06:55 34.4
1674277635 21.01.2023 05:07:15 34.5
1674277655 21.01.2023 05:07:35 34.6
1674277675 21.01.2023 05:07:55 34.6
1674277695 21.01.2023 05:08:15 34.7
1674277715 21.01.2023 05:08:35 34.8
1674277735 21.01.2023 05:08:55 34.8
1674277755 21.01.2023 05:09:15 34.8
1674277775 21.01.2023 05:09:35 34.9
1674277795 21.01.2023 05:09:55 34.9
1674277815 21.01.2023 05:10:15 35.0
1674277835 21.01.2023 05:10:35 35.0
1674277855 21.01.2023 05:10:55 35.1
1674277875 21.01.2023 05:11:15 35.1
1674277895 21.01.2023 05:11:35 35.1
1674277915 21.01.2023 05:11:55 35.1
1674277935 21.01.2023 05:12:15 35.2
1674277955 21.01.2023 05:12:35 35.3
1674277975 21.01.2023 05:12:55 35.3
1674277995 21.01.2023 05:13:15 35.3
1674278015 21.01.2023 05:13:35 35.3
1674278035 21.01.2023 05:13:55 35.3
1674278055 21.01.2023 05:14:15 35.4
1674278075 21.01.2023 05:14:35 35.4
1674278095 21.01.2023 05:14:55 35.4
1674278115 21.01.2023 05:15:15 35.4
1674278135 21.01.2023 05:15:35 35.4
1674278155 21.01.2023 05:15:55 35.4
1674278175 21.01.2023 05:16:15 35.4
1674278195 21.01.2023 05:16:35 35.4
1674278215 21.01.2023 05:16:55 35.5
1674278235 21.01.2023 05:17:15 35.5
1674278255 21.01.2023 05:17:35 35.5
1674278275 21.01.2023 05:17:55 35.5
1674278295 21.01.2023 05:18:15 35.5
1674278315 21.01.2023 05:18:35 35.6
1674278335 21.01.2023 05:18:55 35.6
1674278355 21.01.2023 05:19:15 35.6
1674278375 21.01.2023 05:19:35 35.6
1674278395 21.01.2023 05:19:55 35.6
1674278415 21.01.2023 05:20:15 35.6
1674278435 21.01.2023 05:20:35 35.6
1674278455 21.01.2023 05:20:55 35.6
1674278475 21.01.2023 05:21:15 35.6
1674278495 21.01.2023 05:21:35 35.6
1674278515 21.01.2023 05:21:55 35.6
1674278535 21.01.2023 05:22:15 35.6
1674278555 21.01.2023 05:22:35 35.7
1674278575 21.01.2023 05:22:55 35.7
1674278595 21.01.2023 05:23:15 35.7
1674278615 21.01.2023 05:23:35 35.7
1674278635 21.01.2023 05:23:55 35.7
1674278655 21.01.2023 05:24:15 35.8
1674278675 21.01.2023 05:24:35 35.8
1674278695 21.01.2023 05:24:55 35.8
1674278715 21.01.2023 05:25:15 35.8
1674278735 21.01.2023 05:25:35 35.8
1674278755 21.01.2023 05:25:55 35.8
1674278775 21.01.2023 05:26:15 35.8
1674278795 21.01.2023 05:26:35 35.8
1674278815 21.01.2023 05:26:55 35.8
1674278835 21.01.2023 05:27:15 35.8
1674278855 21.01.2023 05:27:35 35.8
1674278875 21.01.2023 05:27:55 35.8
1674278895 21.01.2023 05:28:15 35.8
1674278915 21.01.2023 05:28:35 35.8
1674278935 21.01.2023 05:28:55 35.8
1674278955 21.01.2023 05:29:15 35.9
1674278975 21.01.2023 05:29:35 35.9
1674278995 21.01.2023 05:29:55 35.9
1674279015 21.01.2023 05:30:15 35.9
1674279035 21.01.2023 05:30:35 35.9
1674279055 21.01.2023 05:30:55 35.9
1674279075 21.01.2023 05:31:15 35.9
1674279095 21.01.2023 05:31:35 35.9
1674279115 21.01.2023 05:31:55 35.9
1674279135 21.01.2023 05:32:15 35.9
1674279155 21.01.2023 05:32:35 35.9
1674279175 21.01.2023 05:32:55 35.9
1674279195 21.01.2023 05:33:15 35.9
1674279215 21.01.2023 05:33:35 35.9
1674279235 21.01.2023 05:33:55 35.9
1674279255 21.01.2023 05:34:15 35.9
1674279275 21.01.2023 05:34:35 35.9
1674279295 21.01.2023 05:34:55 35.9
1674279315 21.01.2023 05:35:15 35.9
1674279335 21.01.2023 05:35:35 35.9
1674279355 21.01.2023 05:35:55 36.0
1674279375 21.01.2023 05:36:15 36.0
1674279395 21.01.2023 05:36:35 36.0
1674279415 21.01.2023 05:36:55 36.0
1674279435 21.01.2023 05:37:15 36.0
1674279455 21.01.2023 05:37:35 36.0
1674279475 21.01.2023 05:37:55 36.0
1674279495 21.01.2023 05:38:15 36.0
1674279515 21.01.2023 05:38:35 36.0
1674279535 21.01.2023 05:38:55 36.0
1674279555 21.01.2023 05:39:15 36.0
1674279575 21.01.2023 05:39:35 36.0
1674279595 21.01.2023 05:39:55 36.0
1674279615 21.01.2023 05:40:15 36.0
1674279635 21.01.2023 05:40:35 36.0
1674279655 21.01.2023 05:40:55 36.1
1674279675 21.01.2023 05:41:15 36.1
1674279695 21.01.2023 05:41:35 36.0
1674279715 21.01.2023 05:41:55 36.1
1674279735 21.01.2023 05:42:15 36.1
1674279755 21.01.2023 05:42:35 36.1
1674279775 21.01.2023 05:42:55 36.1
1674279795 21.01.2023 05:43:15 36.1
1674279815 21.01.2023 05:43:35 36.1
1674279835 21.01.2023 05:43:55 36.1
1674279855 21.01.2023 05:44:15 36.1
1674279875 21.01.2023 05:44:35 36.1
1674279895 21.01.2023 05:44:55 36.1
1674279915 21.01.2023 05:45:15 36.1
1674279935 21.01.2023 05:45:35 36.1
1674279955 21.01.2023 05:45:55 36.1
1674279975 21.01.2023 05:46:15 36.1
1674279995 21.01.2023 05:46:35 36.1
1674280015 21.01.2023 05:46:55 36.1
1674280035 21.01.2023 05:47:15 36.1
1674280055 21.01.2023 05:47:35 36.1
1674280075 21.01.2023 05:47:55 36.1
1674280095 21.01.2023 05:48:15 36.1
1674280115 21.01.2023 05:48:35 36.1
1674280135 21.01.2023 05:48:55 36.1
1674280155 21.01.2023 05:49:15 36.1
1674280175 21.01.2023 05:49:35 36.1
1674280195 21.01.2023 05:49:55 36.1
1674280215 21.01.2023 05:50:15 36.1
1674280235 21.01.2023 05:50:35 36.1
1674280255 21.01.2023 05:50:55 36.1
1674280275 21.01.2023 05:51:15 36.1
1674280295 21.01.2023 05:51:35 36.1
1674280315 21.01.2023 05:51:55 36.1
1674280335 21.01.2023 05:52:15 36.1
1674280355 21.01.2023 05:52:35 36.1
1674280375 21.01.2023 05:52:55 36.1
1674280395 21.01.2023 05:53:15 36.1
1674280415 21.01.2023 05:53:35 36.1
1674280435 21.01.2023 05:53:55 36.1
1674280455 21.01.2023 05:54:15 36.1
1674280475 21.01.2023 05:54:35 36.1
1674280495 21.01.2023 05:54:55 36.2
1674280515 21.01.2023 05:55:15 36.1
1674280535 21.01.2023 05:55:35 36.1
1674280555 21.01.2023 05:55:55 36.2
1674280575 21.01.2023 05:56:15 36.1
1674280595 21.01.2023 05:56:35 36.2
1674280615 21.01.2023 05:56:55 36.1
1674280635 21.01.2023 05:57:15 36.2
1674280655 21.01.2023 05:57:35 36.2
1674280675 21.01.2023 05:57:55 36.2
1674280695 21.01.2023 05:58:15 36.2
1674280715 21.01.2023 05:58:35 36.2
1674280735 21.01.2023 05:58:55 36.2
1674280755 21.01.2023 05:59:15 36.2
1674280775 21.01.2023 05:59:35 36.2
1674280795 21.01.2023 05:59:55 36.2
1674280815 21.01.2023 06:00:15 36.2
1674280835 21.01.2023 06:00:35 36.2
1674280855 21.01.2023 06:00:55 36.2
1674280875 21.01.2023 06:01:15 36.2
1674280895 21.01.2023 06:01:35 36.2
1674280915 21.01.2023 06:01:55 36.2
1674280935 21.01.2023 06:02:15 36.2
1674280955 21.01.2023 06:02:35 36.2
1674280975 21.01.2023 06:02:55 36.2
1674280995 21.01.2023 06:03:15 36.2
1674281015 21.01.2023 06:03:35 36.2
1674281035 21.01.2023 06:03:55 36.2
1674281055 21.01.2023 06:04:15 36.2
1674281075 21.01.2023 06:04:35 36.2
1674281095 21.01.2023 06:04:55 36.2
1674281115 21.01.2023 06:05:15 36.2
1674281135 21.01.2023 06:05:35 36.2
1674281155 21.01.2023 06:05:55 36.2
1674281175 21.01.2023 06:06:15 36.2
1674281195 21.01.2023 06:06:35 36.2
1674281215 21.01.2023 06:06:55 36.2
1674281235 21.01.2023 06:07:15 36.2
1674281255 21.01.2023 06:07:35 36.2
1674281275 21.01.2023 06:07:55 36.2
1674281295 21.01.2023 06:08:15 36.2
1674281315 21.01.2023 06:08:35 36.3
1674281335 21.01.2023 06:08:55 36.2
1674281355 21.01.2023 06:09:15 36.2
1674281375 21.01.2023 06:09:35 36.3
1674281395 21.01.2023 06:09:55 36.3
1674281415 21.01.2023 06:10:15 36.3
1674281435 21.01.2023 06:10:35 36.3
1674281455 21.01.2023 06:10:55 36.3
1674281475 21.01.2023 06:11:15 36.3
1674281495 21.01.2023 06:11:35 36.3
1674281515 21.01.2023 06:11:55 36.3
1674281535 21.01.2023 06:12:15 36.3
1674281555 21.01.2023 06:12:35 36.3
1674281575 21.01.2023 06:12:55 36.3
1674281595 21.01.2023 06:13:15 36.3
1674281615 21.01.2023 06:13:35 36.3
1674281635 21.01.2023 06:13:55 36.3
1674281655 21.01.2023 06:14:15 36.3
1674281675 21.01.2023 06:14:35 36.3
1674281695 21.01.2023 06:14:55 36.3
1674281715 21.01.2023 06:15:15 36.3
1674281735 21.01.2023 06:15:35 36.3
1674281755 21.01.2023 06:15:55 36.3
1674281775 21.01.2023 06:16:15 36.3
1674281795 21.01.2023 06:16:35 36.3
1674281815 21.01.2023 06:16:55 36.3
1674281835 21.01.2023 06:17:15 36.3
1674281855 21.01.2023 06:17:35 36.3
1674281875 21.01.2023 06:17:55 36.3
1674281895 21.01.2023 06:18:15 36.3
1674281915 21.01.2023 06:18:35 36.3
1674281935 21.01.2023 06:18:55 36.3
1674281955 21.01.2023 06:19:15 36.3
1674281975 21.01.2023 06:19:35 36.3
1674281995 21.01.2023 06:19:55 36.3
1674282015 21.01.2023 06:20:15 36.3
1674282035 21.01.2023 06:20:35 36.3
1674282055 21.01.2023 06:20:55 36.3
1674282075 21.01.2023 06:21:15 36.3
1674282095 21.01.2023 06:21:35 36.3
1674282115 21.01.2023 06:21:55 36.3
1674282135 21.01.2023 06:22:15 36.3
1674282155 21.01.2023 06:22:35 36.3
1674282175 21.01.2023 06:22:55 36.3
1674282195 21.01.2023 06:23:15 36.3
1674282215 21.01.2023 06:23:35 36.3
1674282235 21.01.2023 06:23:55 36.3
1674282255 21.01.2023 06:24:15 36.3
1674282275 21.01.2023 06:24:35 36.3
1674282295 21.01.2023 06:24:55 36.3
1674282315 21.01.2023 06:25:15 36.3
1674282335 21.01.2023 06:25:35 36.3
1674282355 21.01.2023 06:25:55 36.3
1674282375 21.01.2023 06:26:15 36.3
1674282395 21.01.2023 06:26:35 36.3
1674282415 21.01.2023 06:26:55 36.3
1674282435 21.01.2023 06:27:15 36.3
1674282455 21.01.2023 06:27:35 36.3
1674282475 21.01.2023 06:27:55 36.3
1674282495 21.01.2023 06:28:15 36.3
1674282515 21.01.2023 06:28:35 36.3
1674282535 21.01.2023 06:28:55 36.3
1674282555 21.01.2023 06:29:15 36.3
1674282575 21.01.2023 06:29:35 36.3
1674282595 21.01.2023 06:29:55 36.3
1674282615 21.01.2023 06:30:15 36.3
1674282635 21.01.2023 06:30:35 36.3
1674282655 21.01.2023 06:30:55 36.2
1674282675 21.01.2023 06:31:15 36.2
1674282695 21.01.2023 06:31:35 36.1
1674282715 21.01.2023 06:31:55 36.1
1674282735 21.01.2023 06:32:15 36.1
1674282755 21.01.2023 06:32:35 36.1
1674282775 21.01.2023 06:32:55 36.0
1674282795 21.01.2023 06:33:15 35.9
1674282815 21.01.2023 06:33:35 35.9
1674282835 21.01.2023 06:33:55 35.9
1674282855 21.01.2023 06:34:15 35.8
1674282875 21.01.2023 06:34:35 35.8
1674282895 21.01.2023 06:34:55 35.8
1674282915 21.01.2023 06:35:15 35.7
1674282935 21.01.2023 06:35:35 35.6
1674282955 21.01.2023 06:35:55 35.6
1674282975 21.01.2023 06:36:15 35.6
1674282995 21.01.2023 06:36:35 35.5
1674283015 21.01.2023 06:36:55 35.5
1674283035 21.01.2023 06:37:15 35.4
1674283055 21.01.2023 06:37:35 35.4
1674283075 21.01.2023 06:37:55 35.4
1674283095 21.01.2023 06:38:15 35.4
1674283115 21.01.2023 06:38:35 35.4
1674283135 21.01.2023 06:38:55 35.4
1674283155 21.01.2023 06:39:15 35.4
1674283175 21.01.2023 06:39:35 35.5
1674283195 21.01.2023 06:39:55 35.9
1674283215 21.01.2023 06:40:15 35.9
1674283235 21.01.2023 06:40:35 35.4
1674283255 21.01.2023 06:40:55 34.8
1674283275 21.01.2023 06:41:15 34.1
1674283295 21.01.2023 06:41:35 33.4
1674283315 21.01.2023 06:41:55 32.9
1674283335 21.01.2023 06:42:15 32.3
1674283355 21.01.2023 06:42:35 31.9
1674283375 21.01.2023 06:42:55 31.5
1674283395 21.01.2023 06:43:15 31.2
1674283415 21.01.2023 06:43:35 30.9
1674283435 21.01.2023 06:43:55 30.6
1674283455 21.01.2023 06:44:15 30.4
1674283475 21.01.2023 06:44:35 30.2
1674283495 21.01.2023 06:44:55 30.1
1674283515 21.01.2023 06:45:15 29.9
1674283535 21.01.2023 06:45:35 29.7
1674283555 21.01.2023 06:45:55 29.6
1674283575 21.01.2023 06:46:15 29.4
1674283595 21.01.2023 06:46:35 29.3
1674283615 21.01.2023 06:46:55 29.2
1674283635 21.01.2023 06:47:15 29.1
1674283655 21.01.2023 06:47:35 29.0
1674283675 21.01.2023 06:47:55 28.9
1674283695 21.01.2023 06:48:15 28.8
1674283715 21.01.2023 06:48:35 28.8
1674283735 21.01.2023 06:48:55 28.6
1674283755 21.01.2023 06:49:15 28.6
1674283775 21.01.2023 06:49:35 28.6
1674283795 21.01.2023 06:49:55 28.5
1674283815 21.01.2023 06:50:15 28.4
1674283835 21.01.2023 06:50:35 28.8
1674283855 21.01.2023 06:50:55 29.2
1674283875 21.01.2023 06:51:15 29.2
1674283895 21.01.2023 06:51:35 29.2
1674283915 21.01.2023 06:51:55 29.7
1674283935 21.01.2023 06:52:15 30.4
1674283955 21.01.2023 06:52:35 31.0
1674283975 21.01.2023 06:52:55 31.4
1674283995 21.01.2023 06:53:15 31.7
1674284015 21.01.2023 06:53:35 31.9
1674284035 21.01.2023 06:53:55 32.1
1674284055 21.01.2023 06:54:15 32.3
1674284075 21.01.2023 06:54:35 32.5
1674284095 21.01.2023 06:54:55 32.6
1674284115 21.01.2023 06:55:15 32.8
1674284135 21.01.2023 06:55:35 32.9
1674284155 21.01.2023 06:55:55 33.0
1674284175 21.01.2023 06:56:15 33.2
1674284195 21.01.2023 06:56:35 33.3
1674284215 21.01.2023 06:56:55 33.3
1674284235 21.01.2023 06:57:15 33.5
1674284255 21.01.2023 06:57:35 33.6
1674284275 21.01.2023 06:57:55 33.8
1674284295 21.01.2023 06:58:15 33.9
1674284315 21.01.2023 06:58:35 34.1
1674284335 21.01.2023 06:58:55 34.1
1674284355 21.01.2023 06:59:15 34.3
1674284375 21.01.2023 06:59:35 34.3
1674284395 21.01.2023 06:59:55 34.4
1674284415 21.01.2023 07:00:15 34.5
1674284435 21.01.2023 07:00:35 34.6
1674284455 21.01.2023 07:00:55 34.6
1674284475 21.01.2023 07:01:15 34.7
1674284495 21.01.2023 07:01:35 34.8
1674284515 21.01.2023 07:01:55 34.8
1674284535 21.01.2023 07:02:15 34.9
1674284555 21.01.2023 07:02:35 34.9
1674284575 21.01.2023 07:02:55 35.0
1674284595 21.01.2023 07:03:15 35.1
1674284615 21.01.2023 07:03:35 35.1
1674284635 21.01.2023 07:03:55 35.1
1674284655 21.01.2023 07:04:15 35.2
1674284675 21.01.2023 07:04:35 35.2
1674284695 21.01.2023 07:04:55 35.3
1674284715 21.01.2023 07:05:15 35.3
1674284735 21.01.2023 07:05:35 35.3
1674284755 21.01.2023 07:05:55 35.3
1674284775 21.01.2023 07:06:15 35.4
1674284795 21.01.2023 07:06:35 35.4
1674284815 21.01.2023 07:06:55 35.4
1674284835 21.01.2023 07:07:15 35.4
1674284855 21.01.2023 07:07:35 35.4
1674284875 21.01.2023 07:07:55 35.4
1674284895 21.01.2023 07:08:15 35.4
1674284915 21.01.2023 07:08:35 35.5
1674284935 21.01.2023 07:08:55 35.5
1674284955 21.01.2023 07:09:15 35.5
1674284975 21.01.2023 07:09:35 35.5
1674284995 21.01.2023 07:09:55 35.6
1674285015 21.01.2023 07:10:15 35.6
1674285035 21.01.2023 07:10:35 35.6
1674285055 21.01.2023 07:10:55 35.6
1674285075 21.01.2023 07:11:15 35.6
1674285095 21.01.2023 07:11:35 35.6
1674285115 21.01.2023 07:11:55 35.6
1674285135 21.01.2023 07:12:15 35.6
1674285155 21.01.2023 07:12:35 35.6
1674285175 21.01.2023 07:12:55 35.6
1674285195 21.01.2023 07:13:15 35.6
1674285215 21.01.2023 07:13:35 35.6
1674285235 21.01.2023 07:13:55 35.6
1674285255 21.01.2023 07:14:15 35.7
1674285275 21.01.2023 07:14:35 35.7
1674285295 21.01.2023 07:14:55 35.7
1674285315 21.01.2023 07:15:15 35.7
1674285335 21.01.2023 07:15:35 35.7
1674285355 21.01.2023 07:15:55 35.7
1674285375 21.01.2023 07:16:15 35.7
1674285395 21.01.2023 07:16:35 35.7
1674285415 21.01.2023 07:16:55 35.7
1674285435 21.01.2023 07:17:15 35.7
1674285455 21.01.2023 07:17:35 35.7
1674285475 21.01.2023 07:17:55 35.8
1674285495 21.01.2023 07:18:15 35.8
1674285515 21.01.2023 07:18:35 35.8
1674285535 21.01.2023 07:18:55 35.8
1674285555 21.01.2023 07:19:15 35.8
1674285575 21.01.2023 07:19:35 35.8
1674285595 21.01.2023 07:19:55 35.8
1674285615 21.01.2023 07:20:15 35.7
1674285635 21.01.2023 07:20:35 35.7
1674285655 21.01.2023 07:20:55 35.7
1674285675 21.01.2023 07:21:15 35.6
1674285695 21.01.2023 07:21:35 35.6
1674285715 21.01.2023 07:21:55 35.6
1674285735 21.01.2023 07:22:15 35.6
1674285755 21.01.2023 07:22:35 35.5
1674285775 21.01.2023 07:22:55 35.5
1674285795 21.01.2023 07:23:15 35.4
1674285815 21.01.2023 07:23:35 35.4
1674285835 21.01.2023 07:23:55 35.4
1674285855 21.01.2023 07:24:15 35.3
1674285875 21.01.2023 07:24:35 35.3
1674285895 21.01.2023 07:24:55 35.3
1674285915 21.01.2023 07:25:15 35.2
1674285935 21.01.2023 07:25:35 35.2
1674285955 21.01.2023 07:25:55 35.1
1674285975 21.01.2023 07:26:15 35.1
1674285995 21.01.2023 07:26:35 35.1
1674286015 21.01.2023 07:26:55 35.0
1674286035 21.01.2023 07:27:15 34.9
1674286055 21.01.2023 07:27:35 34.9
1674286075 21.01.2023 07:27:55 34.9
1674286095 21.01.2023 07:28:15 34.9
1674286115 21.01.2023 07:28:35 34.9
1674286135 21.01.2023 07:28:55 34.9
1674286155 21.01.2023 07:29:15 35.0
1674286175 21.01.2023 07:29:35 34.8
1674286195 21.01.2023 07:29:55 34.2
1674286215 21.01.2023 07:30:15 33.7
1674286235 21.01.2023 07:30:35 33.8
1674286255 21.01.2023 07:30:55 34.1
1674286275 21.01.2023 07:31:15 34.3
1674286295 21.01.2023 07:31:35 34.4
1674286315 21.01.2023 07:31:55 34.4
1674286335 21.01.2023 07:32:15 34.4
1674286355 21.01.2023 07:32:35 34.4
1674286375 21.01.2023 07:32:55 34.4
1674286395 21.01.2023 07:33:15 34.4
1674286415 21.01.2023 07:33:35 34.5
1674286435 21.01.2023 07:33:55 34.5
1674286455 21.01.2023 07:34:15 34.5
1674286475 21.01.2023 07:34:35 34.6
1674286495 21.01.2023 07:34:55 34.6
1674286515 21.01.2023 07:35:15 34.6
1674286535 21.01.2023 07:35:35 34.7
1674286555 21.01.2023 07:35:55 34.7
1674286575 21.01.2023 07:36:15 34.8
1674286595 21.01.2023 07:36:35 34.8
1674286615 21.01.2023 07:36:55 34.9
1674286635 21.01.2023 07:37:15 34.9
1674286655 21.01.2023 07:37:35 34.9
1674286675 21.01.2023 07:37:55 35.0
1674286695 21.01.2023 07:38:15 35.1
1674286715 21.01.2023 07:38:35 35.1
1674286735 21.01.2023 07:38:55 35.1
1674286755 21.01.2023 07:39:15 35.1
1674286775 21.01.2023 07:39:35 35.2
1674286795 21.01.2023 07:39:55 35.2
1674286815 21.01.2023 07:40:15 35.2
1674286835 21.01.2023 07:40:35 35.3
1674286855 21.01.2023 07:40:55 35.3
1674286875 21.01.2023 07:41:15 35.3
1674286895 21.01.2023 07:41:35 35.3
1674286915 21.01.2023 07:41:55 35.3
1674286935 21.01.2023 07:42:15 35.4
1674286955 21.01.2023 07:42:35 35.4
1674286975 21.01.2023 07:42:55 35.4
1674286995 21.01.2023 07:43:15 35.4
1674287015 21.01.2023 07:43:35 35.4
1674287035 21.01.2023 07:43:55 35.4
1674287055 21.01.2023 07:44:15 35.5
1674287075 21.01.2023 07:44:35 35.5
1674287095 21.01.2023 07:44:55 35.5
1674287115 21.01.2023 07:45:15 35.6
1674287135 21.01.2023 07:45:35 35.6
1674287155 21.01.2023 07:45:55 35.6
1674287175 21.01.2023 07:46:15 35.6
1674287195 21.01.2023 07:46:35 35.6
1674287215 21.01.2023 07:46:55 35.6
1674287235 21.01.2023 07:47:15 35.6
1674287255 21.01.2023 07:47:35 35.6
1674287275 21.01.2023 07:47:55 35.6
1674287295 21.01.2023 07:48:15 35.6
1674287315 21.01.2023 07:48:35 35.6
1674287335 21.01.2023 07:48:55 35.6
1674287355 21.01.2023 07:49:15 35.7
1674287375 21.01.2023 07:49:35 35.7
1674287395 21.01.2023 07:49:55 35.7
1674287415 21.01.2023 07:50:15 35.7
1674287435 21.01.2023 07:50:35 35.7
1674287455 21.01.2023 07:50:55 35.7
1674287475 21.01.2023 07:51:15 35.8
1674287495 21.01.2023 07:51:35 35.8
1674287515 21.01.2023 07:51:55 35.8
1674287535 21.01.2023 07:52:15 35.8
1674287555 21.01.2023 07:52:35 35.8
1674287575 21.01.2023 07:52:55 35.8
1674287595 21.01.2023 07:53:15 35.8
1674287615 21.01.2023 07:53:35 35.8
1674287635 21.01.2023 07:53:55 35.8
1674287655 21.01.2023 07:54:15 35.8
1674287675 21.01.2023 07:54:35 35.8
1674287695 21.01.2023 07:54:55 35.8
1674287715 21.01.2023 07:55:15 35.8
1674287735 21.01.2023 07:55:35 35.8
1674287755 21.01.2023 07:55:55 35.8
1674287775 21.01.2023 07:56:15 35.8
1674287795 21.01.2023 07:56:35 35.8
1674287815 21.01.2023 07:56:55 35.8
1674287835 21.01.2023 07:57:15 35.8
1674287855 21.01.2023 07:57:35 35.9
1674287875 21.01.2023 07:57:55 35.8
1674287895 21.01.2023 07:58:15 35.9
1674287915 21.01.2023 07:58:35 35.9
1674287935 21.01.2023 07:58:55 35.9
1674287955 21.01.2023 07:59:15 35.9
1674287975 21.01.2023 07:59:35 35.9
1674287995 21.01.2023 07:59:55 35.9
1674288015 21.01.2023 08:00:15 35.9
1674288035 21.01.2023 08:00:35 35.9
1674288055 21.01.2023 08:00:55 35.9
1674288075 21.01.2023 08:01:15 35.9
1674288095 21.01.2023 08:01:35 35.9
1674288115 21.01.2023 08:01:55 35.9
1674288135 21.01.2023 08:02:15 35.9
1674288155 21.01.2023 08:02:35 35.9
1674288175 21.01.2023 08:02:55 35.9
1674288195 21.01.2023 08:03:15 35.9
1674288215 21.01.2023 08:03:35 35.9
1674288235 21.01.2023 08:03:55 36.0
1674288255 21.01.2023 08:04:15 35.9
1674288275 21.01.2023 08:04:35 36.0
1674288295 21.01.2023 08:04:55 36.0
1674288315 21.01.2023 08:05:15 36.0
1674288335 21.01.2023 08:05:35 36.0
1674288355 21.01.2023 08:05:55 36.0
1674288375 21.01.2023 08:06:15 36.0
1674288395 21.01.2023 08:06:35 36.0
1674288415 21.01.2023 08:06:55 36.0
1674288435 21.01.2023 08:07:15 36.0
1674288455 21.01.2023 08:07:35 36.0
1674288475 21.01.2023 08:07:55 36.0
1674288495 21.01.2023 08:08:15 36.0
1674288515 21.01.2023 08:08:35 36.0
1674288535 21.01.2023 08:08:55 36.1
1674288555 21.01.2023 08:09:15 36.0
1674288575 21.01.2023 08:09:35 36.0
1674288595 21.01.2023 08:09:55 36.1
1674288615 21.01.2023 08:10:15 36.1
1674288635 21.01.2023 08:10:35 36.1
1674288655 21.01.2023 08:10:55 36.1
1674288675 21.01.2023 08:11:15 36.1
1674288695 21.01.2023 08:11:35 36.1
1674288715 21.01.2023 08:11:55 36.1
1674288735 21.01.2023 08:12:15 36.1
1674288755 21.01.2023 08:12:35 36.1
1674288775 21.01.2023 08:12:55 36.1
1674288795 21.01.2023 08:13:15 36.1
1674288815 21.01.2023 08:13:35 36.1
1674288835 21.01.2023 08:13:55 36.1
1674288855 21.01.2023 08:14:15 36.1
1674288875 21.01.2023 08:14:35 36.1
1674288895 21.01.2023 08:14:55 36.1
1674288915 21.01.2023 08:15:15 36.1
1674288935 21.01.2023 08:15:35 36.1
1674288955 21.01.2023 08:15:55 36.1
1674288975 21.01.2023 08:16:15 36.1
1674288995 21.01.2023 08:16:35 36.1
1674289015 21.01.2023 08:16:55 36.1
1674289035 21.01.2023 08:17:15 36.1
1674289055 21.01.2023 08:17:35 36.1
1674289075 21.01.2023 08:17:55 36.1
1674289095 21.01.2023 08:18:15 36.1
1674289115 21.01.2023 08:18:35 36.1
1674289135 21.01.2023 08:18:55 36.1
1674289155 21.01.2023 08:19:15 36.1
1674289175 21.01.2023 08:19:35 36.1
1674289195 21.01.2023 08:19:55 36.1
1674289215 21.01.2023 08:20:15 36.1
1674289235 21.01.2023 08:20:35 36.1
1674289255 21.01.2023 08:20:55 36.1
1674289275 21.01.2023 08:21:15 36.1
1674289295 21.01.2023 08:21:35 36.1
1674289315 21.01.2023 08:21:55 36.1
1674289335 21.01.2023 08:22:15 36.1
1674289355 21.01.2023 08:22:35 36.1
1674289375 21.01.2023 08:22:55 36.2
1674289395 21.01.2023 08:23:15 36.2
1674289415 21.01.2023 08:23:35 36.1
1674289435 21.01.2023 08:23:55 36.2
1674289455 21.01.2023 08:24:15 36.2
1674289475 21.01.2023 08:24:35 36.1
1674289495 21.01.2023 08:24:55 36.2
1674289515 21.01.2023 08:25:15 36.2
1674289535 21.01.2023 08:25:35 36.2
1674289555 21.01.2023 08:25:55 36.2
1674289575 21.01.2023 08:26:15 36.2
1674289595 21.01.2023 08:26:35 36.2
1674289615 21.01.2023 08:26:55 36.2
1674289635 21.01.2023 08:27:15 36.2
1674289655 21.01.2023 08:27:35 36.2
1674289675 21.01.2023 08:27:55 36.2
1674289695 21.01.2023 08:28:15 36.2
1674289715 21.01.2023 08:28:35 36.2
1674289735 21.01.2023 08:28:55 36.2
1674289755 21.01.2023 08:29:15 36.2
1674289775 21.01.2023 08:29:35 36.2
1674289795 21.01.2023 08:29:55 36.2
1674289815 21.01.2023 08:30:15 36.2
1674289835 21.01.2023 08:30:35 36.2
1674289855 21.01.2023 08:30:55 36.2
1674289875 21.01.2023 08:31:15 36.2
1674289895 21.01.2023 08:31:35 36.2
1674289915 21.01.2023 08:31:55 36.2
1674289935 21.01.2023 08:32:15 36.2
1674289955 21.01.2023 08:32:35 36.2
1674289975 21.01.2023 08:32:55 36.2
1674289995 21.01.2023 08:33:15 36.3
1674290015 21.01.2023 08:33:35 36.2
1674290035 21.01.2023 08:33:55 36.3
1674290055 21.01.2023 08:34:15 36.2
1674290075 21.01.2023 08:34:35 36.2
1674290095 21.01.2023 08:34:55 36.2
1674290115 21.01.2023 08:35:15 36.3
1674290135 21.01.2023 08:35:35 36.3
1674290155 21.01.2023 08:35:55 36.3
1674290175 21.01.2023 08:36:15 36.3
1674290195 21.01.2023 08:36:35 36.3
1674290215 21.01.2023 08:36:55 36.3
1674290235 21.01.2023 08:37:15 36.3
1674290255 21.01.2023 08:37:35 36.3
1674290275 21.01.2023 08:37:55 36.3
1674290295 21.01.2023 08:38:15 36.3
1674290315 21.01.2023 08:38:35 36.3
1674290335 21.01.2023 08:38:55 36.3
1674290355 21.01.2023 08:39:15 36.3
1674290375 21.01.2023 08:39:35 36.3
1674290395 21.01.2023 08:39:55 36.3
1674290415 21.01.2023 08:40:15 36.3
1674290435 21.01.2023 08:40:35 36.3
1674290455 21.01.2023 08:40:55 36.3
1674290475 21.01.2023 08:41:15 36.3
1674290495 21.01.2023 08:41:35 36.3
1674290515 21.01.2023 08:41:55 36.3
1674290535 21.01.2023 08:42:15 36.3
1674290555 21.01.2023 08:42:35 36.3
1674290575 21.01.2023 08:42:55 36.3
1674290595 21.01.2023 08:43:15 36.3
1674290615 21.01.2023 08:43:35 36.3
1674290635 21.01.2023 08:43:55 36.3
1674290655 21.01.2023 08:44:15 36.3
1674290675 21.01.2023 08:44:35 36.3
1674290695 21.01.2023 08:44:55 36.3
1674290715 21.01.2023 08:45:15 36.3
1674290735 21.01.2023 08:45:35 36.3
1674290755 21.01.2023 08:45:55 36.3
1674290775 21.01.2023 08:46:15 36.3
1674290795 21.01.2023 08:46:35 36.3
1674290815 21.01.2023 08:46:55 36.3
1674290835 21.01.2023 08:47:15 36.3
1674290855 21.01.2023 08:47:35 36.3
1674290875 21.01.2023 08:47:55 36.3
1674290895 21.01.2023 08:48:15 36.3
1674290915 21.01.2023 08:48:35 36.3
1674290935 21.01.2023 08:48:55 36.3
1674290955 21.01.2023 08:49:15 36.3
1674290975 21.01.2023 08:49:35 36.3
1674290995 21.01.2023 08:49:55 36.3
1674291015 21.01.2023 08:50:15 36.3
1674291035 21.01.2023 08:50:35 36.3
1674291055 21.01.2023 08:50:55 36.3
1674291075 21.01.2023 08:51:15 36.3
1674291095 21.01.2023 08:51:35 36.3
1674291115 21.01.2023 08:51:55 36.3
1674291135 21.01.2023 08:52:15 36.3
1674291155 21.01.2023 08:52:35 36.3
1674291175 21.01.2023 08:52:55 36.3
1674291195 21.01.2023 08:53:15 36.3
1674291215 21.01.2023 08:53:35 36.3
1674291235 21.01.2023 08:53:55 36.3
1674291255 21.01.2023 08:54:15 36.3
1674291275 21.01.2023 08:54:35 36.3
1674291295 21.01.2023 08:54:55 36.3
1674291315 21.01.2023 08:55:15 36.3
1674291335 21.01.2023 08:55:35 36.3
1674291355 21.01.2023 08:55:55 36.3
1674291375 21.01.2023 08:56:15 36.3
1674291395 21.01.2023 08:56:35 36.3
1674291415 21.01.2023 08:56:55 36.3
1674291435 21.01.2023 08:57:15 36.3
1674291455 21.01.2023 08:57:35 36.3
1674291475 21.01.2023 08:57:55 36.3
1674291495 21.01.2023 08:58:15 36.3
1674291515 21.01.2023 08:58:35 36.3
1674291535 21.01.2023 08:58:55 36.3
1674291555 21.01.2023 08:59:15 36.3
1674291575 21.01.2023 08:59:35 36.3
1674291595 21.01.2023 08:59:55 36.3
1674291615 21.01.2023 09:00:15 36.3
1674291635 21.01.2023 09:00:35 36.3
1674291655 21.01.2023 09:00:55 36.3
1674291675 21.01.2023 09:01:15 36.3
1674291695 21.01.2023 09:01:35 36.3
1674291715 21.01.2023 09:01:55 36.3
1674291735 21.01.2023 09:02:15 36.3
1674291755 21.01.2023 09:02:35 36.3
1674291775 21.01.2023 09:02:55 36.3
1674291795 21.01.2023 09:03:15 36.3
1674291815 21.01.2023 09:03:35 36.3
1674291835 21.01.2023 09:03:55 36.3
1674291855 21.01.2023 09:04:15 36.4
1674291875 21.01.2023 09:04:35 36.3
1674291895 21.01.2023 09:04:55 36.3
1674291915 21.01.2023 09:05:15 36.3
1674291935 21.01.2023 09:05:35 36.3
1674291955 21.01.2023 09:05:55 36.4
1674291975 21.01.2023 09:06:15 36.4
1674291995 21.01.2023 09:06:35 36.4
1674292015 21.01.2023 09:06:55 36.3
1674292035 21.01.2023 09:07:15 36.4
1674292055 21.01.2023 09:07:35 36.4
1674292075 21.01.2023 09:07:55 36.4
1674292095 21.01.2023 09:08:15 36.3
1674292115 21.01.2023 09:08:35 36.4
1674292135 21.01.2023 09:08:55 36.3
1674292155 21.01.2023 09:09:15 36.4
1674292175 21.01.2023 09:09:35 36.4
1674292195 21.01.2023 09:09:55 36.4
1674292215 21.01.2023 09:10:15 36.4
1674292235 21.01.2023 09:10:35 36.4
1674292255 21.01.2023 09:10:55 36.4
1674292275 21.01.2023 09:11:15 36.4
1674292295 21.01.2023 09:11:35 36.4
1674292315 21.01.2023 09:11:55 36.4
1674292335 21.01.2023 09:12:15 36.4
1674292355 21.01.2023 09:12:35 36.4
1674292375 21.01.2023 09:12:55 36.4
1674292395 21.01.2023 09:13:15 36.4
1674292415 21.01.2023 09:13:35 36.4
1674292435 21.01.2023 09:13:55 36.4
1674292455 21.01.2023 09:14:15 36.4
1674292475 21.01.2023 09:14:35 36.4
1674292495 21.01.2023 09:14:55 36.4
1674292515 21.01.2023 09:15:15 36.4
1674292535 21.01.2023 09:15:35 36.4
1674292555 21.01.2023 09:15:55 36.4
1674292575 21.01.2023 09:16:15 36.4
1674292595 21.01.2023 09:16:35 36.4
1674292615 21.01.2023 09:16:55 36.4
1674292635 21.01.2023 09:17:15 36.4
1674292655 21.01.2023 09:17:35 36.4
1674292675 21.01.2023 09:17:55 36.4
1674292695 21.01.2023 09:18:15 36.4
1674292715 21.01.2023 09:18:35 36.4
1674292735 21.01.2023 09:18:55 36.4
1674292755 21.01.2023 09:19:15 36.4
1674292775 21.01.2023 09:19:35 36.4
1674292795 21.01.2023 09:19:55 36.4
1674292815 21.01.2023 09:20:15 36.4
1674292835 21.01.2023 09:20:35 36.4
1674292855 21.01.2023 09:20:55 36.4
1674292875 21.01.2023 09:21:15 36.4
1674292895 21.01.2023 09:21:35 36.4
1674292915 21.01.2023 09:21:55 36.4
1674292935 21.01.2023 09:22:15 36.4
1674292955 21.01.2023 09:22:35 36.4
1674292975 21.01.2023 09:22:55 36.4
1674292995 21.01.2023 09:23:15 36.4
1674293015 21.01.2023 09:23:35 36.4
1674293035 21.01.2023 09:23:55 36.4
1674293055 21.01.2023 09:24:15 36.4
1674293075 21.01.2023 09:24:35 36.4
1674293095 21.01.2023 09:24:55 36.4
1674293115 21.01.2023 09:25:15 36.4
1674293135 21.01.2023 09:25:35 36.4
1674293155 21.01.2023 09:25:55 36.4
1674293175 21.01.2023 09:26:15 36.4
1674293195 21.01.2023 09:26:35 36.4
1674293215 21.01.2023 09:26:55 36.4
1674293235 21.01.2023 09:27:15 36.4
1674293255 21.01.2023 09:27:35 36.4
1674293275 21.01.2023 09:27:55 36.4
1674293295 21.01.2023 09:28:15 36.4
1674293315 21.01.2023 09:28:35 36.4
1674293335 21.01.2023 09:28:55 36.4
1674293355 21.01.2023 09:29:15 36.4
1674293375 21.01.2023 09:29:35 36.4
1674293395 21.01.2023 09:29:55 36.4
1674293415 21.01.2023 09:30:15 36.4
1674293435 21.01.2023 09:30:35 36.4
1674293455 21.01.2023 09:30:55 36.4
1674293475 21.01.2023 09:31:15 36.4
1674293495 21.01.2023 09:31:35 36.4
1674293515 21.01.2023 09:31:55 36.4
1674293535 21.01.2023 09:32:15 36.4
1674293555 21.01.2023 09:32:35 36.4
1674293575 21.01.2023 09:32:55 36.4
1674293595 21.01.2023 09:33:15 36.4
1674293615 21.01.2023 09:33:35 36.4
1674293635 21.01.2023 09:33:55 36.4
1674293655 21.01.2023 09:34:15 36.4
1674293675 21.01.2023 09:34:35 36.4
1674293695 21.01.2023 09:34:55 36.4
1674293715 21.01.2023 09:35:15 36.4
1674293735 21.01.2023 09:35:35 36.4
1674293755 21.01.2023 09:35:55 36.4
1674293775 21.01.2023 09:36:15 36.4
1674293795 21.01.2023 09:36:35 36.4
1674293815 21.01.2023 09:36:55 36.4
1674293835 21.01.2023 09:37:15 36.4
1674293855 21.01.2023 09:37:35 36.4
1674293875 21.01.2023 09:37:55 36.4
1674293895 21.01.2023 09:38:15 36.4
1674293915 21.01.2023 09:38:35 36.4
1674293935 21.01.2023 09:38:55 36.4
1674293955 21.01.2023 09:39:15 36.4
1674293975 21.01.2023 09:39:35 36.4
1674293995 21.01.2023 09:39:55 36.4
1674294015 21.01.2023 09:40:15 36.4
1674294035 21.01.2023 09:40:35 36.4
1674294055 21.01.2023 09:40:55 36.4
1674294075 21.01.2023 09:41:15 36.4
1674294095 21.01.2023 09:41:35 36.4
1674294115 21.01.2023 09:41:55 36.4
1674294135 21.01.2023 09:42:15 36.4
1674294155 21.01.2023 09:42:35 36.4
1674294175 21.01.2023 09:42:55 36.4
1674294195 21.01.2023 09:43:15 36.4
1674294215 21.01.2023 09:43:35 36.4
1674294235 21.01.2023 09:43:55 36.4
1674294255 21.01.2023 09:44:15 36.4
1674294275 21.01.2023 09:44:35 36.4
1674294295 21.01.2023 09:44:55 36.4
1674294315 21.01.2023 09:45:15 36.4
1674294335 21.01.2023 09:45:35 36.4
1674294355 21.01.2023 09:45:55 36.4
1674294375 21.01.2023 09:46:15 36.4
1674294395 21.01.2023 09:46:35 36.4
1674294415 21.01.2023 09:46:55 36.4
1674294435 21.01.2023 09:47:15 36.4
1674294455 21.01.2023 09:47:35 36.4
1674294475 21.01.2023 09:47:55 36.4
1674294495 21.01.2023 09:48:15 36.4
1674294516 21.01.2023 09:48:36 36.4
1674294536 21.01.2023 09:48:56 36.4
1674294556 21.01.2023 09:49:16 36.4
1674294576 21.01.2023 09:49:36 36.4
1674294596 21.01.2023 09:49:56 36.4
1674294616 21.01.2023 09:50:16 36.4
1674294636 21.01.2023 09:50:36 36.4
1674294656 21.01.2023 09:50:56 36.4
1674294676 21.01.2023 09:51:16 36.5
1674294696 21.01.2023 09:51:36 36.5
1674294716 21.01.2023 09:51:56 36.5
1674294736 21.01.2023 09:52:16 36.5
1674294756 21.01.2023 09:52:36 36.5
1674294776 21.01.2023 09:52:56 36.5
1674294796 21.01.2023 09:53:16 36.5
1674294816 21.01.2023 09:53:36 36.5
1674294836 21.01.2023 09:53:56 36.6
1674294856 21.01.2023 09:54:16 36.6
1674294876 21.01.2023 09:54:36 36.6
1674294896 21.01.2023 09:54:56 36.6
1674294916 21.01.2023 09:55:16 36.7
1674294936 21.01.2023 09:55:36 36.8
1674294956 21.01.2023 09:55:56 36.8
1674294976 21.01.2023 09:56:16 36.9
1674294996 21.01.2023 09:56:36 36.9
1674295016 21.01.2023 09:56:56 37.1
1674295036 21.01.2023 09:57:16 37.2
1674295056 21.01.2023 09:57:36 37.3
1674295076 21.01.2023 09:57:56 36.9
1674295096 21.01.2023 09:58:16 36.4
1674295116 21.01.2023 09:58:36 35.7
1674295136 21.01.2023 09:58:56 35.1
1674295156 21.01.2023 09:59:16 34.4
1674295176 21.01.2023 09:59:36 33.8
1674295196 21.01.2023 09:59:56 33.3
1674295216 21.01.2023 10:00:16 32.9
1674295236 21.01.2023 10:00:36 32.5
1674295256 21.01.2023 10:00:56 32.2
1674295276 21.01.2023 10:01:16 31.9
1674295296 21.01.2023 10:01:36 31.6
1674295316 21.01.2023 10:01:56 31.3
1674295336 21.01.2023 10:02:16 31.1
1674295356 21.01.2023 10:02:36 30.8
1674295376 21.01.2023 10:02:56 30.6
1674295396 21.01.2023 10:03:16 30.4
1674295416 21.01.2023 10:03:36 30.2
1674295436 21.01.2023 10:03:56 30.0
1674295456 21.01.2023 10:04:16 29.8
1674295476 21.01.2023 10:04:36 29.6
1674295496 21.01.2023 10:04:56 29.4
1674295516 21.01.2023 10:05:16 29.3
1674295536 21.01.2023 10:05:36 29.2
1674295556 21.01.2023 10:05:56 29.1
1674295576 21.01.2023 10:06:16 28.9
1674295596 21.01.2023 10:06:36 28.8
1674295616 21.01.2023 10:06:56 28.7
1674295636 21.01.2023 10:07:16 28.6
1674295656 21.01.2023 10:07:36 28.5
1674295676 21.01.2023 10:07:56 28.4
1674295696 21.01.2023 10:08:16 28.3
1674295716 21.01.2023 10:08:36 28.2
1674295736 21.01.2023 10:08:56 28.1
1674295756 21.01.2023 10:09:16 28.0
1674295776 21.01.2023 10:09:36 27.9
1674295796 21.01.2023 10:09:56 27.9
1674295816 21.01.2023 10:10:16 27.8
1674295836 21.01.2023 10:10:36 27.7
1674295856 21.01.2023 10:10:56 27.6
1674295876 21.01.2023 10:11:16 27.6
1674295896 21.01.2023 10:11:36 27.5
1674295916 21.01.2023 10:11:56 27.4
1674295936 21.01.2023 10:12:16 27.4
1674295956 21.01.2023 10:12:36 27.3
1674295976 21.01.2023 10:12:56 27.3
1674295996 21.01.2023 10:13:16 27.2
1674296016 21.01.2023 10:13:36 27.2
1674296036 21.01.2023 10:13:56 27.1
1674296056 21.01.2023 10:14:16 27.1
1674296076 21.01.2023 10:14:36 27.0
1674296096 21.01.2023 10:14:56 26.9
1674296116 21.01.2023 10:15:16 26.9
1674296136 21.01.2023 10:15:36 26.9
1674296156 21.01.2023 10:15:56 26.8
1674296176 21.01.2023 10:16:16 26.8
1674296196 21.01.2023 10:16:36 26.8
1674296216 21.01.2023 10:16:56 26.8
1674296236 21.01.2023 10:17:16 26.7
1674296256 21.01.2023 10:17:36 26.9
1674296276 21.01.2023 10:17:56 27.8
1674296296 21.01.2023 10:18:16 28.8
1674296316 21.01.2023 10:18:36 29.6
1674296336 21.01.2023 10:18:56 30.1
1674296356 21.01.2023 10:19:16 30.5
1674296376 21.01.2023 10:19:36 30.8
1674296396 21.01.2023 10:19:56 31.1
1674296416 21.01.2023 10:20:16 31.4
1674296436 21.01.2023 10:20:36 31.6
1674296456 21.01.2023 10:20:56 31.8
1674296476 21.01.2023 10:21:16 32.0
1674296496 21.01.2023 10:21:36 32.2
1674296516 21.01.2023 10:21:56 32.4
1674296536 21.01.2023 10:22:16 32.5
1674296556 21.01.2023 10:22:36 32.7
1674296576 21.01.2023 10:22:56 32.8
1674296596 21.01.2023 10:23:16 33.0
1674296616 21.01.2023 10:23:36 33.1
1674296636 21.01.2023 10:23:56 33.3
1674296656 21.01.2023 10:24:16 33.4
1674296676 21.01.2023 10:24:36 33.6
1674296696 21.01.2023 10:24:56 33.8
1674296716 21.01.2023 10:25:16 33.9
1674296736 21.01.2023 10:25:36 34.0
1674296756 21.01.2023 10:25:56 34.1
1674296776 21.01.2023 10:26:16 34.2
1674296796 21.01.2023 10:26:36 34.3
1674296816 21.01.2023 10:26:56 34.4
1674296836 21.01.2023 10:27:16 34.4
1674296856 21.01.2023 10:27:36 34.5
1674296876 21.01.2023 10:27:56 34.6
1674296896 21.01.2023 10:28:16 34.6
1674296916 21.01.2023 10:28:36 34.7
1674296936 21.01.2023 10:28:56 34.8
1674296956 21.01.2023 10:29:16 34.8
1674296976 21.01.2023 10:29:36 34.8
1674296996 21.01.2023 10:29:56 34.9
1674297016 21.01.2023 10:30:16 34.9
1674297036 21.01.2023 10:30:36 35.0
1674297056 21.01.2023 10:30:56 35.0
1674297076 21.01.2023 10:31:16 35.1
1674297096 21.01.2023 10:31:36 35.1
1674297116 21.01.2023 10:31:56 35.1
1674297136 21.01.2023 10:32:16 35.2
1674297156 21.01.2023 10:32:36 35.2
1674297176 21.01.2023 10:32:56 35.3
1674297196 21.01.2023 10:33:16 35.3
1674297216 21.01.2023 10:33:36 35.3
1674297236 21.01.2023 10:33:56 35.3
1674297256 21.01.2023 10:34:16 35.3
1674297276 21.01.2023 10:34:36 35.3
1674297296 21.01.2023 10:34:56 35.4
1674297316 21.01.2023 10:35:16 35.4
1674297336 21.01.2023 10:35:36 35.4
1674297356 21.01.2023 10:35:56 35.4
1674297376 21.01.2023 10:36:16 35.4
1674297396 21.01.2023 10:36:36 35.4
1674297416 21.01.2023 10:36:56 35.4
1674297436 21.01.2023 10:37:16 35.4
1674297456 21.01.2023 10:37:36 35.5
1674297476 21.01.2023 10:37:56 35.5
1674297496 21.01.2023 10:38:16 35.5
1674297516 21.01.2023 10:38:36 35.5
1674297536 21.01.2023 10:38:56 35.5
1674297556 21.01.2023 10:39:16 35.6
1674297576 21.01.2023 10:39:36 35.6
1674297596 21.01.2023 10:39:56 35.6
1674297616 21.01.2023 10:40:16 35.6
1674297636 21.01.2023 10:40:36 35.6
1674297656 21.01.2023 10:40:56 35.6
1674297676 21.01.2023 10:41:16 35.6
1674297696 21.01.2023 10:41:36 35.6
1674297716 21.01.2023 10:41:56 35.6
1674297736 21.01.2023 10:42:16 35.6
1674297756 21.01.2023 10:42:36 35.7
1674297776 21.01.2023 10:42:56 35.7
1674297796 21.01.2023 10:43:16 35.7
1674297816 21.01.2023 10:43:36 35.7
1674297836 21.01.2023 10:43:56 35.7
1674297856 21.01.2023 10:44:16 35.8
1674297876 21.01.2023 10:44:36 35.8
1674297896 21.01.2023 10:44:56 35.8
1674297916 21.01.2023 10:45:16 35.8
1674297936 21.01.2023 10:45:36 35.8
1674297956 21.01.2023 10:45:56 35.8
1674297976 21.01.2023 10:46:16 35.8
1674297996 21.01.2023 10:46:36 35.8
1674298016 21.01.2023 10:46:56 35.8
1674298036 21.01.2023 10:47:16 35.8
1674298056 21.01.2023 10:47:36 35.8
1674298076 21.01.2023 10:47:56 35.8
1674298096 21.01.2023 10:48:16 35.8
1674298116 21.01.2023 10:48:36 35.9
1674298136 21.01.2023 10:48:56 35.9
1674298156 21.01.2023 10:49:16 35.9
1674298176 21.01.2023 10:49:36 35.9
1674298196 21.01.2023 10:49:56 35.9
1674298216 21.01.2023 10:50:16 35.9
1674298236 21.01.2023 10:50:36 35.9
1674298256 21.01.2023 10:50:56 35.9
1674298276 21.01.2023 10:51:16 35.9
1674298296 21.01.2023 10:51:36 35.9
1674298316 21.01.2023 10:51:56 35.9
1674298336 21.01.2023 10:52:16 35.9
1674298356 21.01.2023 10:52:36 35.9
1674298376 21.01.2023 10:52:56 35.9
1674298396 21.01.2023 10:53:16 35.9
1674298416 21.01.2023 10:53:36 35.9
1674298436 21.01.2023 10:53:56 35.9
1674298456 21.01.2023 10:54:16 35.9
1674298476 21.01.2023 10:54:36 35.9
1674298496 21.01.2023 10:54:56 35.9
1674298516 21.01.2023 10:55:16 35.9
1674298536 21.01.2023 10:55:36 35.9
1674298556 21.01.2023 10:55:56 36.0
1674298576 21.01.2023 10:56:16 36.0
1674298596 21.01.2023 10:56:36 36.0
1674298616 21.01.2023 10:56:56 36.0
1674298636 21.01.2023 10:57:16 36.0
1674298656 21.01.2023 10:57:36 36.0
1674298676 21.01.2023 10:57:56 36.0
1674298696 21.01.2023 10:58:16 36.0
1674298716 21.01.2023 10:58:36 36.0
1674298736 21.01.2023 10:58:56 36.0
1674298756 21.01.2023 10:59:16 36.0
1674298776 21.01.2023 10:59:36 36.0
1674298796 21.01.2023 10:59:56 36.1
1674298816 21.01.2023 11:00:16 36.1
1674298836 21.01.2023 11:00:36 36.1
1674298856 21.01.2023 11:00:56 36.1
1674298876 21.01.2023 11:01:16 36.1
1674298896 21.01.2023 11:01:36 36.1
1674298916 21.01.2023 11:01:56 36.1
1674298936 21.01.2023 11:02:16 36.1
1674298956 21.01.2023 11:02:36 36.1
1674298976 21.01.2023 11:02:56 36.1
1674298996 21.01.2023 11:03:16 36.1
1674299016 21.01.2023 11:03:36 36.1
1674299036 21.01.2023 11:03:56 36.1
1674299056 21.01.2023 11:04:16 36.1
1674299076 21.01.2023 11:04:36 36.1
1674299096 21.01.2023 11:04:56 36.1
1674299116 21.01.2023 11:05:16 36.1
1674299136 21.01.2023 11:05:36 36.1
1674299156 21.01.2023 11:05:56 36.1
1674299176 21.01.2023 11:06:16 36.1
1674299196 21.01.2023 11:06:36 36.1
1674299216 21.01.2023 11:06:56 36.1
1674299236 21.01.2023 11:07:16 36.1
1674299256 21.01.2023 11:07:36 36.1
1674299276 21.01.2023 11:07:56 36.1
1674299296 21.01.2023 11:08:16 36.1
1674299316 21.01.2023 11:08:36 36.1
1674299336 21.01.2023 11:08:56 36.1
1674299356 21.01.2023 11:09:16 36.1
1674299376 21.01.2023 11:09:36 36.1
1674299396 21.01.2023 11:09:56 36.1
1674299416 21.01.2023 11:10:16 36.1
1674299436 21.01.2023 11:10:36 36.1
1674299456 21.01.2023 11:10:56 36.1
1674299476 21.01.2023 11:11:16 36.1
1674299496 21.01.2023 11:11:36 36.1
1674299516 21.01.2023 11:11:56 36.1
1674299536 21.01.2023 11:12:16 36.1
1674299556 21.01.2023 11:12:36 36.2
1674299576 21.01.2023 11:12:56 36.2
1674299596 21.01.2023 11:13:16 36.2
1674299616 21.01.2023 11:13:36 36.2
1674299636 21.01.2023 11:13:56 36.2
1674299656 21.01.2023 11:14:16 36.2
1674299676 21.01.2023 11:14:36 36.2
1674299696 21.01.2023 11:14:56 36.2
1674299716 21.01.2023 11:15:16 36.2
1674299736 21.01.2023 11:15:36 36.2
1674299756 21.01.2023 11:15:56 36.2
1674299776 21.01.2023 11:16:16 36.2
1674299796 21.01.2023 11:16:36 36.2
1674299816 21.01.2023 11:16:56 36.2
1674299836 21.01.2023 11:17:16 36.2
1674299856 21.01.2023 11:17:36 36.2
1674299876 21.01.2023 11:17:56 36.2
1674299896 21.01.2023 11:18:16 36.2
1674299916 21.01.2023 11:18:36 36.2
1674299936 21.01.2023 11:18:56 36.2
1674299956 21.01.2023 11:19:16 36.2
Wenn du es im Bild nicht drangemalt hättest, und die Minima auch ungefähr gleich niedrig sein können, hätte ich es nicht erkannt. Der kleine Anstieg auf 37,4° vor dem Takt Ende ist zwar vermutlich der Auslöser fürs Abschalten, aber diese 37,4° hängen wohl an der Außentemperatur.
Entweder du findest Signale die dir WW Start / WW Ende sagen, oder es wird schwer.
Wenn digitale Steuerungssignale aus der Heizung, dann doch gleich Heizanforderung EIN / AUS
(im Beispiel bei 37,4° AUS und bei 27° EIN, aber vermutlich bei Variablen Werten und eventuall auch an einem anderen Fühler?)
Nein.
Wenn Du das machst und Dein WW-Vorrat ausreichend ist, verpasst Du die Heizung in der Zeit. Was mich wundert, warum die WW-Bereitung kühler endet als die Heizung.
progger
January 22, 2023, 6:10pm
28
Ja genau, die erhöhen sich wenn’s kälter wird.
Leider nein…
progger
January 22, 2023, 6:19pm
29
Das ist dann nicht so schlimm. Es geht hauptsächlich um die langen Zeiten zwischen den WW Zeiten. Und das in den Übergangszeiten.
Ups? Wo siehst Du das denn?
Das ja am Vorlauf Heizung gemessen. Da schaltet wohl ein Ventil um auf WW und der Vorlauf kühlt ab.
Ich bin davon ausgegangen, das links im Diagramm die Temperatur steht.
Das WW schaltet in der Zeit 7:30 bis 8:30 bei 36,2 max ab.
Die Heizung meldet sich u.a. mit:
Wo misst Du die Temperatur?
progger
January 22, 2023, 6:42pm
31
Genauer: Am Kesselvorlauf zum Systemtrenner
(ich hoffe das ist so richtig benannt von mir).
Eigentlich wäre das der Rücklauf.
OK, dann nimmt der WW-Speicher mehr auf als die Heizung, was den oberen Knick angeht. Vermutlich hast Du irgendwo einen Heizkörper, der Dir den Rücklauf zu schnell anhebt. Aber das ist Nebenschauplatz
Ich hätte ja versucht am Vorlauf die Temperatur abzugreifen.
Denn die steigende Flanke bekommst Du am Rücklauf erst mit, wenn der Brenner schon ne Weile läuft. Die Spreizung zwischen oberem und unterem Flankenwechsel ist am VL auch höher.
Damit könnte man dann ggfls. den WW-Heizpunkt besser erkennen, da der eigentlich höher abschaltet.
progger
January 23, 2023, 8:02am
33
Also den Temperaturanstieg an der Stelle, wo ich messe, sieht man nach einigen Sekunden…. das sollte schon passen.
Ich werde mal mit euren Vorschlägen experimentieren und sehen, wie es sich verhält.
Danke für eure unerschütterliche Unterstützung
progger
January 24, 2023, 2:25pm
34
Jetzt habe ich angefangen und es erstmal simple so gemacht, um die Zeitstempel einmal beim
Unterscheiten zu loggen. Das funktioniert auch:
Pseudo
constexpr float GRENZE {27.0}; // Schwellwert
float temp {}; // Temperaturen werden alle 20 sek aktualisiert
void loggen() { // wird alle 20 sek aufgerufen
static bool einmal {true};
if (temp < GRENZE) { // SO GEHT ES
if (einmal) {
...ins Log schreiben...
einmal = false;
else if (!einmal) { // ab 27 Grad nicht mehr loggen und einmal auf true setzen
einmal = true;
Dann wollte ich die 2 ifs vereinfachen, aber da schreibt es mit unter 27 Grad immer wieder ins Log... mache ich etwas mit der Klammersetzung verkehrt?
Pseudo
if (temp <= GRENZE && einmal) { // DAS FUNKTIONIERT NICHT NUR EINMAL
einmal = false;
einmal = true;
Wo ist mein Denkfehler? Danke euch
Schreib Dir doch serielle Ausgaben rein!
Und dann kannst Du nicht zwei Bedingungen auf eine reduzieren und erwarten, das das gleiche Ergebnis rauskommt.
void loggen() // wird alle 20 sek aufgerufen
Serial.println(einmal);
if (temp <= GRENZE && einmal) // DAS FUNKTIONIERT NICHT NUR EINMAL
Serial.println(F("...ins Log schreiben..."));
einmal = false;
else if (temp > GRENZE && !einmal) // ab 27 Grad nicht mehr loggen und einmal auf true setzen
einmal = true;
progger
January 24, 2023, 3:05pm
36
Ahhh jetzt hab ich’s ! Danke
Beim 2. Durchlauf läuft er in den else Zweig weil einmal ja false ist
Habe ich echt nicht gesehen!
system
Closed
July 23, 2023, 3:05pm
37
