hab mir ein 50LEDs Strang bestellt um mir adalight an dem TV zu machen,
jedoch hab ich nicht die WS2801 Chip version bekommen sondern die sm16716
da ich aber vom code schreiben und ändern zero plan habe bin ich im mom zimlich aufgeschmissen.
hab rausgefunden das man dafür den fastspi code nutzen kann jedoch lauft nix bei mir.
// Uncomment this line if you have any interrupts that are changing pins - this causes the library to be a little bit more cautious
// #define FAST_SPI_INTERRUPTS_WRITE_PINS 1
// Uncomment this line to force always using software, instead of hardware, SPI (why?)
// #define FORCE_SOFTWARE_SPI 1
// Uncomment this line if you want to talk to DMX controllers
// #define FASTSPI_USE_DMX_SIMPLE 1
#include "FastSPI_LED2.h"
// test code
#define NUM_LEDS 150
struct CRGB leds[NUM_LEDS];
// sanity check delay - allows reprogramming if accidently blowing power w/leds
delay(2000);
// For safety (to prevent too high of a power draw), the test case defaults to
// setting brightness to 25% brightness
LEDS.setBrightness(64);
// LEDS.addLeds<WS2811, 13>(leds, NUM_LEDS);
// LEDS.addLeds<TM1809, 13>(leds, NUM_LEDS);
// LEDS.addLeds<UCS1903, 13>(leds, NUM_LEDS);
// LEDS.addLeds<TM1803, 13>(leds, NUM_LEDS);
LEDS.addLeds<LPD8806>(leds, NUM_LEDS)->clearLeds(300);
// LEDS.addLeds<WS2801>(leds, NUM_LEDS);
// LEDS.addLeds<SM16716>(leds, NUM_LEDS);
// LEDS.addLeds<WS2811, 11>(leds, NUM_LEDS);
// Put ws2801 strip on the hardware SPI pins with a BGR ordering of rgb and limited to a 1Mhz data rate
// LEDS.addLeds<WS2801, 11, 13, BGR, DATA_RATE_MHZ(1)>(leds, NUM_LEDS);
// LEDS.addLeds<LPD8806, 10, 11>(leds, NUM_LEDS);
// LEDS.addLeds<WS2811, 13, BRG>(leds, NUM_LEDS);
// LEDS.addLeds<LPD8806, BGR>(leds, NUM_LEDS);
for(int i = 0; i < 3; i++) {
for(int iLed = 0; iLed < NUM_LEDS; iLed++) {
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB));
switch(i) {
// You can access the rgb values by field r, g, b
case 0: leds[iLed].r = 128; break;
// or by indexing into the led (r==0, g==1, b==2)
case 1: leds[iLed][i] = 128; break;
// or by setting the rgb values for the pixel all at once
case 2: leds[iLed] = CRGB(0, 0, 128); break;
// and now, show your led array!
LEDS.show();
delay(10);
// fade up
for(int x = 0; x < 128; x++) {
// The showColor method sets all the leds in the strip to the same color
LEDS.showColor(CRGB(x, 0, 0));
delay(10);
// fade down
for(int x = 128; x >= 0; x--) {
delay(10);
// let's fade up by scaling the brightness
for(int scale = 0; scale < 128; scale++) {
LEDS.showColor(CRGB(0, 128, 0), scale);
delay(10);
// let's fade down by scaling the brightness
for(int scale = 128; scale > 0; scale--) {
delay(10);
Ist das überhaupt richtig also der code brauch ich den und wenn ja könnte mir den jemand umschreiben das er auf meinem arduino uno r3 lauft mit 50 LEDs ?
MFG Danke
