Sucrets tin vs Altoids tin for UNO
I measured and trial fit a number of different options for my UNO board to use as a small protective case, including the Altoids tin. The size difference between these two tins makes the Sucrets tin a better choice for fitting an UNO board. The height is about 1/16" higher and permits the lid to be closed with the USB jack in place. The bottom of the tin is simply covered with short strips of electrical tape. I also used some fiber washers (#4 machine screw size) as stand-offs.
Although when used the lid will be open, I dislike cutting Altoids lids, and this just looks better.
This is a second photo… simply showing the difference in height, and why to choose the Sucrets tin.
