Sudden failures
Hi everyone,
I’ve been working on a project to collect data from a GPS NEO6MV2 and send through a NiceRF 2AD66 LoRa device which uses a SX1276 chip. I started trying the components separately using the example programs that each of their library offers, which are: TinyGPS’ ”simple_test”, TinyGPS++’s “DeviceExample”, LoRa’s “LoRaSender” and “LoRaReceiver”. I used a Teensy 4.0, and it worked perfectly for the first time, but I changed a detail in the program and it stopped working. Then I returned to the example program, therefore maintaining the same variables as the first test, but it still didn't work. I then tried to use an Arduino Nano instead, and the same result: the first time it worked, I did some failed changes, and then returning to the original setup, it stopped working. Does anyone have an idea for the cause and/or solutions?
TinyGPS++ DeviceExample:
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
   This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  Serial.println(F("DeviceExample.ino"));
  Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.print(F("."));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
    Serial.print(gps.time.centisecond());
LoRa Sender Example:
#include <SPI.h>
#include <LoRa.h>
int counter = 0;
  while (!Serial);
  Serial.println("LoRa Sender");
  if (!LoRa.begin(915E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  Serial.print("Sending packet: ");
  Serial.println(counter);
  // send packet
  LoRa.beginPacket();
  LoRa.print("hello ");
  LoRa.print(counter);
  LoRa.endPacket();
  counter++;
  delay(5000);
