sudden hassles with Keypad
I have been using basically the same sketch for awakening a remote from sleep, and reading a keypad for 2 years now.
Suddenly now its giving me hassles, I have checked my wiring, even checked that I didn't fit N/C pushbuttons instead of N/O.
here's a sketch of the circuit for the keypad, actually 5 N/O pushbuttons.
The buttons on column 2 and 3 work most of the time, but sometimes do not send the data, the serial monitor just shows "sleep" when it has gone through its loop.
Both buttons on column 1 do not work. But if I hook a scope probe on column 1, both buttons run through the loop ( and show " sleep " ) and intermittently with no scope attached.
I have swapped the physical wiring over from pins 12 and 17, and its still the buttons connected to pin 17 that misbehave.
I have tried different pins for all the keypad, but no different, any ideas ?
I can just have the 5 switches grounding 5 pins with 5 diodes from the interrupt, but I want to know whats happening ...
Heres the sketch
#include <VirtualWire.h>    // Wireless transmitter/receiver library
#include <Keypad.h>         // Matrix Keypad library
#include <avr/sleep.h>      // powerdown library
#include <avr/interrupt.h>  // interrupts library
uint8_t SW[4]; // assign four data pins from bcd switches
int SW0 = 5;               // bits to read from bcd switches LSB
int SW1 = 6;
int SW2 = 7;
int SW3 = 8;               // - MSB
int address = 0;
int add0;  //  bits generated from bcd switches
int add1;
int add2;
int add3;
int clockPin = 18;
int resetPin = 19;
int PIN = 18;  //  preset pin number to send
int dataA;  //   DATA REBUILT FROM BCD INPUTS FROM SWITCHES
int dataB;
int dataC;
int dataD;
int dataF;
int dataG;
int pause=HIGH;
int dpin0 = 0;              // apparently redefined by Serial as Serial Monitor works
int dpin1 = 1;              // apparently redefined by Serial as Serial Monitor works
int pin2 = 2;               // Int0 interrupt pin
int sleep_count = 0;      // flag/counter to tell us to go sleep
// create an array to store data to be sent out
char msg [10]; //   keeping msg 0 for now as we dont have period
// set up the Keypad
const byte ROWS = 2; // two rows
const byte COLS = 3; // three columns
// Define the Keymap
char keys[ROWS][COLS] =
    'A', 'B','C'   }
  ,  // row 1   //
    'D','E', 'F'   }
  ,  // row 2
byte rowPins[ROWS] = {
  14, 15  };  // Keypad uses internal pullups? No externals supplied
// Pressing a Row button connects to a Low Columna and pulls the appropriate Row Diode Low for a Pin2 Low interrupt.
// Column pins are then set back high for the keypad library button determination.
byte colPins[COLS] = {
  13,12,11};
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// *  Name:        pin2Interrupt, "ISR" to run when interrupted in Sleep Mode
void pin2Interrupt()
  /* This brings us back from sleep. */
// *  Name:        enterSleep
void enterSleep()
  /* Setup pin2 as an interrupt and attach handler. */
  attachInterrupt(0, pin2Interrupt, FALLING);
  delay(50); // need this?
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);  // setting up for sleep ...
  sleep_enable();                       // setting up for sleep ...
  ADCSRA &= ~(1 << ADEN);
  PRR = 0xFF;
  sleep_mode();                         // now goes to Sleep and waits for the interrupt
  /* The program will continue from here after the interrupt. */
  detachInterrupt(0);                 //disable interrupts while we get ready to read the keypad
  PRR = 0x00;
  /* First thing to do is disable sleep. */
  sleep_disable();
  // set all the keypad columns back high so can read keypad presses again
  digitalWrite(11, HIGH);
  digitalWrite(12, HIGH);
  digitalWrite(13, HIGH);
  // then go to the void Loop()
  pinMode(pin2, INPUT);                 // our sleep interrupt pin
  digitalWrite(pin2, HIGH);  // set pull up res
  // define all the unused pins as inputs with internal pullups for lower power state
  pinMode(dpin0, INPUT);                  // apparently redefined by Serial as Serial Monitor works (receiving anyway)
  digitalWrite(dpin0, HIGH);              // apparently redefined by Serial as Serial Monitor works
  pinMode(dpin1, INPUT);                  // apparently redefined by Serial as Serial Monitor works
  digitalWrite(dpin1, HIGH);              // apparently redefined by Serial as Serial Monitor works
  pinMode (resetPin , OUTPUT );
  pinMode (clockPin , OUTPUT );
  pinMode(SW0, INPUT); // LSB of bcd
  byte add0 = 0;
  pinMode(SW1, INPUT); // LSB+1
  byte add1= 0;
  pinMode(SW2, INPUT);  // LSB+2
  byte add2 = 0;
  pinMode(SW3, INPUT);  // MSB of bcd
  byte add3 = 0;
  PIN = 18; //  ( preset for WPCC to 1101  ( 13 )  Pin number  SACS = 11  Glenwoodrugby 18
  Serial.println("my address is: ");
  Serial.println(PIN, BIN);
  digitalWrite(SW0, LOW);   //  disable pullups on PIN inputs to save current, finished with these pins PIN read.msg[0]
  digitalWrite(SW1, LOW);
  digitalWrite(SW2, LOW);
  digitalWrite(SW3, LOW);
  Serial.println("TX setup");              // for debug only
  // vw_set_rx_pin(0);
  vw_set_tx_pin(4);    //  data
  vw_set_ptt_pin(3); // powers Tx and LED
  vw_setup(2000);
  digitalWrite(resetPin, HIGH);
  digitalWrite(clockPin, LOW);
  digitalWrite(resetPin, LOW);
// *************************************************************************end of void Setup()
  if (sleep_count>100){                      // check if we should go to sleep because of "time" --> Try shorter versions of this
    sleep_count=0;                           // turn it off for when we wake up
    Serial.println("Sleep");               // for debug only
    //  digitalWrite(3, LOW);// set the columns low before sleeping, otherwise Keypad leaves them high and Rows have nothing to pull low.
    digitalWrite(11,LOW);
    digitalWrite(12, LOW);
    digitalWrite(13, LOW);
    digitalWrite(resetPin, HIGH);  //  making sue 4017 is off
    enterSleep();                             // call Sleep function to put us out
    //  THE PROGRAM CONTINUEs FROM HERE after waking up in enterSleep()
  }                                           // end of checking to go to sleep
  // Serial.println("wake up and read keypad");
  char key = keypad.getKey();                 // reading the keypad
  if(key)                                     // same as if(key != NO_KEY)- did something change?
    Serial.print("key read =");
    Serial.println(key);
    msg [0]  = PIN;
    msg [1]  = key;
    digitalWrite(resetPin, LOW);  //  making sue 4017 is off
    for ( int h = 2; h <= 9; h++ ) {  // commutate all switch banks
      digitalWrite(clockPin, HIGH);
      address=0;
      add3 = digitalRead(SW3);
      add3 = add3 << 3;
      add2 = digitalRead(SW2);
      add2 = add2 << 2;
      add1 = digitalRead(SW1);
      add1 = add1 << 1;
      add0 = digitalRead(SW0);
      address = address|add3;
      address = address|add2;
      address = address|add1;
      address = address|add0;
      msg [h]  = address;
      delay ( 5 );
    digitalWrite(resetPin, HIGH);  //  making sure 4017 is off
    for ( int k= 0; k <=9; k++ ) {
      Serial.print("msg = ");
      Serial.print(k);
      Serial.print(" = ");
      Serial.println(int ( msg[k]) );
    vw_send((uint8_t *)msg, 10);     // send the character out
    vw_wait_tx();                             // Wait until the whole message is gone
    sleep_count = 0;                          // reset count up to sleep if transmitted a key press
  } //                                           // end of if(key) & transmitting a character
  sleep_count ++;
} // end of void loop
I couldn't waste any more time, so I just used the 5 pins straight to the pushbuttons, it cost me 3 extra schottky diodes :slight_smile: but its working fine.
I am using a CD4017 to scan 8 bcd switches, so thats 8 bcd switches, 5 pushbuttons, and a transmitter all from 12 pins.
I have to use the keypad for one of the other projects in line so I must find out what happened.
