Tried to upload an unchanged sketch that worked fine yesterday. Got this whole host of errors that seem to be related to the Wire.h library. Thought maybe the library got corrupted, so reloaded it and got exactly the same errors.
Arduino: 1.8.16 (Windows 10), Board: "Arduino Nano, ATmega328P"
Z:\01-Arduino projects\MPU-6050 tilt\Tilt_Temp_Tx\Tilt_Temp_Tx.ino: In function 'void setup()':
Tilt_Temp_Tx:225:31: error: no matching function for call to 'TwoWire::begin(int, int)'
Wire.begin(OLED_SDA, OLED_SCL) ;
In file included from C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:5:0,
from C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_BusIO_Register.h:9,
from C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\Adafruit_MPU6050-master/Adafruit_MPU6050.h:21,
from Z:\01-Arduino projects\MPU-6050 tilt\Tilt_Temp_Tx\Tilt_Temp_Tx.ino:9:
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:53:10: note: candidate: void TwoWire::begin()
void begin();
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:53:10: note: candidate expects 0 arguments, 2 provided
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:54:10: note: candidate: void TwoWire::begin(uint8_t)
void begin(uint8_t);
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:54:10: note: candidate expects 1 argument, 2 provided
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:55:10: note: candidate: void TwoWire::begin(int)
void begin(int);
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:55:10: note: candidate expects 1 argument, 2 provided
Tilt_Temp_Tx:259:31: error: no matching function for call to 'SPIClass::begin(int, int, int, int)'
SPI.begin(SCK, MISO, MOSI, SS);
In file included from C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_SPIDevice.h:9:0,
from C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_BusIO_Register.h:10,
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src/SPI.h:159:15: note: candidate: static void SPIClass::begin()
static void begin();
C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src/SPI.h:159:15: note: candidate expects 0 arguments, 4 provided
Multiple libraries were found for "Wire.h"
Used: C:\Users\biz-1\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Not used: C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\Wire-master
Multiple libraries were found for "OneWire.h"
Used: C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\OneWire
Not used: C:\Users\biz-1\OneDrive\Documents\Arduino\libraries\OneWireNg
exit status 1
option enabled in File -> Preferences.
I have no idea what is wrong. The IDE halts and highlights the line containing "Wire.begin(xx), about 20 lines into setup(). Here's all the code:
// -------------- "01234567890123456789"
char this_file[] = "Tilt_Temp_Tx" ;
char descp[] = "ESP32 TTGO LoRa" ;
char ver[] = "ver 1.1 12/31/22 " ;
char ver2[] = "Tilt + 2 Temps" ;
char ver3[] = "8 samples/50 ms loop" ;
#include <Adafruit_MPU6050.h>
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for DS18B20 sensor
#include <OneWire.h>
byte temp1 = 21 ; // needs ~2.2K pullup
byte temp2 = 13 ; // needs ~2.2K pullup
byte temp3 = 33 ; // needs ~2.2K pullup
// may need an external pullup
// if used for a discrete input
byte door = 23 ; // discrete switch input, internal pullup
byte disc = 36 ; // a discrete input, but must have
// an external pullup resistor
// same for 35, 37, 38, 39, maybe 34
byte button = 17 ; // pushbutton I/O pin
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 915E6 //915E6 for North America
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
Adafruit_MPU6050 mpu;
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RST);
// Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &Wire);
const int MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265;
int maxVal=402;
// float x;
// float y;
float z;
int xsamp[26] ;
int ysamp[26] ;
int xavI ; // integer angle in hundredths
int yavI ; // integer angle in hundredths
float xav ;
float yav ;
int xsum ;
int ysum ;
int xmax ;
int xmin ;
int ymax ;
int ymin ;
int Temp_1 ;
int Temp_2 ;
int Temp_3 ;
byte sync_byte ;
byte cmd_byte ;
byte counter ; // loop counter
byte i ;
String LoRaData ;
double LoRa_Tx_time ;
double Tilt_clk ; // max 10 minutes
bool Tilt_flag ; // true=tilt mode, false=temps mode
double temp_clk ; // sets the trigger for sending temps
double ds_clk ; // allow 1 sec conversion time between starts
display.setRotation(x)
// x = 0,1,2,3 for 0, 90, 180, 270 degrees of rotation
pinMode(button, INPUT_PULLUP) ; // external switch
pinMode(door, INPUT_PULLUP) ; // external discrete
// while (!Serial);
delay(100) ;
Serial.println() ;
Serial.println(this_file) ; //file name
Serial.println(descp) ; //description
Serial.println(ver) ; //version and date
Serial.println(ver2) ; //version and date
Serial.println(ver3) ; //version and date
Serial.println() ;
//reset OLED display via software
pinMode(OLED_RST, OUTPUT) ;
digitalWrite(OLED_RST, LOW) ;
delay(20) ;
digitalWrite(OLED_RST, HIGH) ;
//initialize OLED--force use of non-standard SDA, SCL
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C, false, false)) {
Serial.println(F("SSD1306 allocation failed")) ;
for(;;); // Don't proceed, loop forever
display.display() ;
display.setTextSize(1) ;
display.setTextColor(WHITE) ;
display.setRotation(0) ;
// display the file information
display.clearDisplay() ;
display.setCursor(0,0) ;
display.print(this_file) ;
display.setCursor(0,15) ;
display.print(descp) ;
display.setCursor(0,30) ;
display.print(ver) ;
display.setCursor(0,40) ;
display.print(ver2) ;
display.display() ;
delay(3000) ; // reading time
if (!mpu.begin()) {
Serial.println("Sensor init failed");
while (1)yield() ; // halt here
Serial.println("Found a MPU-6050 sensor");
//SPI LoRa pins
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
if (!LoRa.begin(BAND)) {
Serial.println("Starting LoRa failed!");
while (1);
display.clearDisplay();
Serial.println("LoRa Initializing OK!");
display.setCursor(0,10);
display.print("LoRa Initializing OK!");
display.display();
delay(2000);
Tilt_flag = false ;
LoRa.setSpreadingFactor(12); // temp mode
display.setTextSize(3);
LoRa_Tx_time = millis() ; // start the clock
temp_clk = millis() ; // start the clock (~5 sec)
readtemps() ; // start the first conversion
ds_clk = millis() ; // start the 1 sec conversion time
// ============================ LOOP() ====================================
int packetSize ;
sync_byte = 0 ;
cmd_byte = 0 ;
if(get_key()) change_mode() ; // change mode?
if(Tilt_flag == false) { // temp mode
Temp() ; // read and send temperatures/door status
//try to parse packet, look for mode switch command
packetSize = LoRa.parsePacket();
if (packetSize) { // packet received
Serial.print("Command packetSize = ") ;
Serial.println(packetSize) ;
if (packetSize == 2) { //
//read packet
sync_byte = LoRa.read(); // sync byte
cmd_byte = LoRa.read() ; // command byte
Serial.print("Sync byte = ") ;
Serial.println(sync_byte, HEX) ;
Serial.print("Cmd byte = ") ;
Serial.println(cmd_byte, HEX) ;
if((sync_byte == 0xAB) && (cmd_byte == 0x05)) {
change_mode() ; // go to tilt mode
} else { // tilt mode
// you can only leave the tilt mode via pushbutton or
// when the clock runs out.
// auto revert to temp mode, 10 minutes
if(((millis() - Tilt_clk) < 600000)) {
Tilt() ;
LoRa.parsePacket(); // dump leftover packets
change_mode() ; // go to temp mode
} // ========================= end of loop =================================
bool get_key() { // button = I/O pin 17
bool key_flag = false ;
// most keypad functions only activate when the key is released.
// this routine activates once the debounce time has been met.
// the reason is that there are LoRa transmit times that can
// be longer than 1 second, so the pushbutton needs to be held
// down until the activation is apparent. The debounce hopefully
// will prevent a re-dection upon release of the button.
// debounce 40 ms
if(!digitalRead(button)) { // button down?
delay(20) ; // start a clock
delay(20) ; // start another clock
key_flag = true ;
Serial.println("Button push");
return key_flag ;
} // ---------------- end of get_key() ----------------------------
void change_mode() {
Serial.println("Change Mode");
if(!LoRa.begin(BAND)) {
while (1); // halt here
if(Tilt_flag) { // tilt mode
Tilt_flag = false ;
Serial.println("Starting LoRa SF12 OK");
LoRa.setSpreadingFactor(9); // tilt mode
Tilt_flag = true ;
Tilt_clk = millis() ; // auto revert to temp mode
Serial.println("Starting LoRa SF-9 OK");
// display the mode
display.setCursor(0,15);
if(Tilt_flag) {
display.print("TILT") ;
display.print("Temp") ;
display.display();
delay(5000) ; // reading time
} // ---------------- end of change_mode() -------------------
// --------------------------- Tilt() ---------------------------
void Tilt() { // get the tilt x,y (left/right, up/down) angle data
Wire.beginTransmission(MPU_addr);
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
int xAng = map(AcX,minVal,maxVal,-90,90);
int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
int x = 5729.6 * (atan2(-yAng, -zAng)+PI);
int y = 5730 * (atan2(-xAng, -zAng)+PI);
// x = RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
// y = RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
// z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
// Serial.print("X= ");
if(x > 27000) x = x - 36000 ; // hundredths
rollx(x) ;
// Serial.print("Y= ");
if(y > 27000) y = y - 36000 ; // hundredths
rolly(y) ;
// Display packet information
display.setCursor(0,4);
if(!(yav < 0)) {
display.print("Up ");
display.print("Dn ") ;
yav = -yav ;
if((abs(yav)<10)) display.print(" ");
display.print(yav, 1);
display.setCursor(0,40);
if(!(xav < 0)) {
display.print("R ");
display.print("L ") ;
xav = -xav ;
if((abs(xav)<10)) display.print(" ");
display.print(xav, 1);
display.display();
if(LoRa.beginPacket() == 1) {
// Loop time w/o Tx is 27 ms
// Serial.print("MS Margin = ") ;
// Serial.println(200-(millis()-LoRa_Tx_time)) ;
if(((millis() - LoRa_Tx_time) > 200)) {
// Tx ~5 per sec, ~85 ms quiet time
// Tx time is 31 ms at SF7 (default)
// Tx time is 104 ms at SF9
LoRa_Tx_time = millis() ; // restart Tx clock
LoRa.write(lowByte(xavI)) ; // byte
LoRa.write(highByte(xavI)); // byte
LoRa.write(lowByte(yavI)) ; // byte
LoRa.write(highByte(yavI)); // byte
LoRa.endPacket() ; // /Tx the data
// Serial.print("On air time = ") ;
// Serial.println(millis()-LoRa_Tx_time) ;
// Serial.println(" ----------------------- ") ;
} // --------------------------- end of Tilt() ---------------------------
void rollx(int a) {
for(i=16;i>0; i --) { // i max is 26
xsamp[i] = xsamp[i - 1] ;
xsamp[0] = a ;
xsum = 0 ;
// xmax = 0 ;
// xmin = 45 ;
for(i=0;i<8; i ++) {
// if(abs(xsamp[i]) > xmax) xmax = abs(xsamp[i]) ;
// if(abs(xsamp[i]) < xmin) xmin = abs(xsamp[i]) ;
xsum = xsum + xsamp[i] ;
xavI = xsum / 8 ; // divide by 8
xav = xavI / 100.0 ;
void rolly(int a) {
ysamp[i] = ysamp[i - 1] ;
ysamp[0] = a ;
ysum = 0 ;
// ymax = 0 ;
// ymin = 45 ;
for(i=0;i<8;i ++) {
// if(abs(ysamp[i]) > ymax) ymax = abs(ysamp[i]) ;
// if(abs(ysamp[i]) < ymin) ymin = abs(ysamp[i]) ;
ysum = ysum + ysamp[i] ;
yavI = ysum / 8 ; // divide by 8
yav = yavI / 100.0 ;
// -------------------------- Temp() -------------------------------
void Temp() { // read and send two temperatures
// time for DS18B20 conversion
if((millis() - ds_clk) > 1000) { // allow 1 second
readtemps() ;
ds_clk = millis() ;
if((millis() - temp_clk) > 10000) { // send temps ~10 secs
temp_clk = millis() ; // reset the clock
Serial.print("Sending packet: ");
Serial.print(counter);
Serial.print(": ");
Serial.print(Temp_1 / 100.0) ;
Serial.print(" ");
Serial.println(Temp_2 / 100.0) ;
// Serial.println(Temp_3 / 100.0) ;
//Send LoRa packet to receiver/tow vehicle
LoRa.beginPacket();
LoRa.write(0x69) ; // user sync byte
LoRa.write(lowByte(counter)) ;
LoRa.write(lowByte(Temp_1));
LoRa.write(highByte(Temp_1));
LoRa.write(lowByte(Temp_2));
LoRa.write(highByte(Temp_2));
LoRa.write(digitalRead(door)) ; // Rx code fixed
// you could also read the gyro to see if the Airstream is
// moving (filtered or wind motion, etc.) and do an alert based
// on that, rather than the door.
LoRa.endPacket();
display.setTextSize(1);
display.setCursor(0,0);
display.print("SENDING: ");
display.print(counter) ;
if(digitalRead(door)) {
display.print(" UP") ;
display.print(" DN") ;
display.print(" ") ;
if(!(Temp_1<0)) {
if(Temp_1<10000) display.print(" ") ;
if(Temp_1<1000) display.print(" ") ;
if(abs(Temp_1)<1000) display.print(" ") ;
display.print(Temp_1/100.0, 1);
if(!(Temp_2<0)) {
if(Temp_2<10000) display.print(" ") ;
if(Temp_2<1000) display.print(" ") ;
if(abs(Temp_2)<1000) display.print(" ") ;
display.print(Temp_2/100.0, 1);
display.display();
counter++;
if(counter > 99) counter = 0 ;
} // -------------------- end of temp() ------------------------------
// ------------------ readtemps() -------------------------------------
void readtemps() {
// one sensor per I/O line, simple OneWire call
Temp_1 = dallas(temp1) ;
Temp_2 = dallas(temp2) ;
// Temp_3 = dallas(21) ;
} // ----------------- end of readtemps() -------------------
// --------------------- quick dallas() -------------------------------
// DS18B20 sensor chip driver code
// the standard library takes several seconds, this takes usecs.
// the logic is (1) read the chip (2) start the conversion.
// a one-second delay between calls is required to allow the
// conversion process to complete so that the next read is good.
// limited to only one chip per I/O pin
int dallas(byte x) {
OneWire ds(x) ;
int data0 ;
int data1 ;
int result ;
ds.reset() ;
ds.write(0xCC) ; // skip command
ds.write(0xBE) ; // Read 1st 2 bytes of Scratchpad
data0 = ds.read() ;
data1 = ds.read() ;
result = (data1 << 8) | data0 ;
// Serial.print("===== ") ;
// Serial.print(result, HEX) ;
// Serial.println(" ======") ;
if(result > 4095) result = (result - 0x0ffff) -1 ;
result = (((result * 90)+0x04) >> 3 ) + 3200 ; // F x 100
ds.reset() ;
ds.write(0x44,1) ; // start conversion
return result ;
} // ----------------- end of dallas() -------------------
I tried this with a similar sketch that also loaded fine yesterday and it generates the same errors.
