my brain was confuse...i was tired a few minute ago...because all day i always try and make program.but I'm more excited to work again now. when i try my code it work fine.and this problem sudenly happen:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_179880 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_67274 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\ridho\Documents\Arduino\parsingdata\parsingdata.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_179880 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_67274 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\ridho\Documents\Arduino\parsingdata\parsingdata.ino
Using board 'uno' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_179880\\sketch\\parsingdata.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_179880\\sketch\\parsingdata.ino.cpp" -o "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_179880\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_179880\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_179880\\sketch\\parsingdata.ino.cpp" -o "C:\\Users\\ridho\\AppData\\Local\\Temp\\arduino_build_179880\\sketch\\parsingdata.ino.cpp.o"
C:\Users\ridho\Documents\Arduino\parsingdata\parsingdata.ino: In function 'void setup()':
parsingdata:26:5: error: 'Serial2' was not declared in this scope
Serial2.begin (9600, SERIAL_8N1, RXp2, TXp2);
C:\Users\ridho\Documents\Arduino\parsingdata\parsingdata.ino:26:5: note: suggested alternative: 'Serial'
Serial
C:\Users\ridho\Documents\Arduino\parsingdata\parsingdata.ino: In function 'void loop()':
parsingdata:32:9: error: 'Serial2' was not declared in this scope
if(Serial2.available()>0)
C:\Users\ridho\Documents\Arduino\parsingdata\parsingdata.ino:32:9: note: suggested alternative: 'Serial'
Serial
exit status 1
this is my code:
#define RXp2 16
#define TXp2 17
String dataIn;
String dt[10];
int i;
bool parsing=false;
//int rpm = 0;
//float cadence = 0;
//float Odo = 0;
//float Trip = 0;
//float Speed = 0;
//float torsi = 0;
//float batt = 0;
//float TripNow = 0;
//float OdoNow = 0.0;
//float keliling = 1.57;
dataIn="";
char inChar = (char)Serial2.read();
dataIn += inChar;
if (inChar == '\n')
parsing = true;
if(parsing)
parsingData();
// voltbat();
// cadance();
// kecepatan();
parsing=false;
dataIn="";
void parsingData()
int j=0;
//kirim data yang telah diterima sebelumnya
Serial.print("data masuk : ");
Serial.print(dataIn);
Serial.print("\n");
//inisialisasi variabel, (reset isi variabel)
dt[j]="";
//proses parsing data
for(i=1;i<dataIn.length();i++)
//pengecekan tiap karakter dengan karakter (#) dan (,)
if ((dataIn[i] == '#') || (dataIn[i] == ','))
//increment variabel j, digunakan untuk merubah index array penampung
j++;
dt[j]=""; //inisialisasi variabel array dt[j]
//proses tampung data saat pengecekan karakter selesai.
dt[j] = dt[j] + dataIn[i];
//kirim data hasil parsing
Serial.print("data 1 : ");
Serial.print(dt[0].toInt());
Serial.print("\n");
Serial.print("data 2 : ");
Serial.print(dt[1].toFloat());
Serial.print("\n");
Serial.print("data 3 : ");
Serial.print(dt[2].toFloat());
Serial.print("\n");
Serial.print("data 4 : ");
Serial.print(dt[3].toFloat());
Serial.print("\n");
Serial.print("data 5 : ");
Serial.print(dt[4].toFloat());
Serial.print("\n\n");
Serial.print("data 6 : ");
Serial.print(dt[5].toFloat());
in this project i use ESP32 as receiver ADC data from UNO with serial comunication. and it works fine. and then this problem happen. how to solve this?
