Suggerimento ACCES POINT
Salve ragazzi
Un suggerimento , ho il seguente listato non riesco a trasformare il funzionamento in access point.
#include <ESP8266WiFi.h>
#include "indexl.h"
const char* ssid = " ";
const char* password = " ";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
int dac = 0;
int DigitalPin[] = {4, 12, 13};
int DacPin = 5;
// Auxiliary variables to store selected mode and settings
int selectedMode = 0;
int timer = 0;
int ldrThreshold = 0;
int armMotion = 0;
int armLdr = 0;
String modes[4] = { "Manual", "Auto PIR", "Auto LDR", "Auto PIR and LDR" };
// Decode HTTP GET value
String valueString = "0";
int pos1 = 0;
int pos2 = 0;
// Variable to store the HTTP request
String header;
// Set web server port number to 80
  delay(10);
pinMode(4,INPUT);
pinMode(4, INPUT_PULLUP);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String command1 = client.readStringUntil('/');
  String command = client.readStringUntil('/');
  Serial.println(command1);
  Serial.println(command);
 client.println("<body><h1>ESP8266 Web Server</h1>");
            // Drop down menu to select mode
            client.println("<p><strong>Mode selected:</strong> " + modes[selectedMode] + "</p>");
            client.println("<select id=\"mySelect\" onchange=\"setMode(this.value)\">");
            client.println("<option>Change mode");
            client.println("<option value=\"0\">Manual");
            client.println("<option value=\"1\">Auto PIR");
            client.println("<option value=\"2\">Auto LDR");
            client.println("<option value=\"3\">Auto PIR and LDR</select>");
if (command == "digital") {
int pin, value;
pin = client.parseInt();
  Serial.println(pin);
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
client.print(F("digital,"));
client.print(pin);
client.print(F(","));
client.println(value);
else if (command == "dac"){
  int pin, value;
dac = value;
analogWrite(pin, value);
else {
value = dac;
client.print(F("dac,"));
client.print(pin);
else if (command == "status") {
int pin, value;
client.print(F("status"));
for (int thisPin = 0; thisPin < 3; thisPin++) {
pin = DigitalPin[thisPin];
client.print(F("#"));
client.print(pin);
client.print(F("="));
client.print(value);
pin = DacPin;
value = dac;
client.print(pin);
value = analogRead(A0);
float lux=value;
client.print(F("#A0"));
client.print(lux);
client.println("");
else {  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
  s += file1;
  client.flush();
  // Send the response to the client
while(s.length()>2000)
  String dummy = s.substring(0,2000);
  client.print(dummy);
  s.replace(dummy," ");
  client.print(s);
  delay(1);
  Serial.println("Client disconnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is destroyed
Beh attivi la modalità AP in questo modo (è uno spezzone di un mio programma che fa proprio quello):
  Serial.print("Starting AP... ");
  WiFi.mode(WIFI_AP);
  if ( WiFi.softAP(ssid, password, chan, 1) )
    Serial.println("Ready");
  else {
    Serial.println("FAILED!");
    while (1) { };
Prova e facci sapere...
sostituendo inizia a darmi errore su client.print perchè vuole send.sever :-(
Posta il tuo codice modificato, e vediamo.
