Suggestion for board selection feature
When searching for board type, make it possible to scroll through the results using arrow keys.
Hi @lasso_water. Thanks for your feedback.
I am interested in learning more about your use case. Would you mind providing a detailed set of steps you would follow to select a board if the IDE had the capability you are requesting?
For example, would you expect to be required to press the Tab key to change the focus from the "Search board" search field to the search listings after you have typed your search query?
