Suggestion needed for 1.3mm object detection sensor
Hi there. Im seeking advise for my project. My project title is MB Detection on the unit. A unit will be having 2 MB and size of MB is 1.3mm. The distance between MB1 to MB2 typically around 18mm. Basically, the unit will be placed on a slide rail for inspection. The velocity of the slide rail is 0.21m/s. The material of the MB is non ferrous metal. I have dig ChatGPT for sensor solution but I couldnt find the compatible sensor for my project. Can anyone help me on this? Any sensor suggestion? Thanks
Suggestions? Yes, get rid of the use of unknown stuff such as "MB" and MB Detection". Only you know what that means and it seems to be a secret. Also the slide rail and velocity of the slide rail needs to be clarified. What does the movement of the slide rail have anything to do with the project? And what is "the unit"?
perhaps ChatGPT knows, but no one here knows.
How can an object distance sensor detect the amount of memory (MB) fitted to a 'unit' ?
You need photos labelled to point to MB Detection and any other technical terms. I, for one, have no clue what you are talking about. Explain it to the cleaning lady was a popular phrase on certain forums a long time ago. It worked!
mini-ball?
Edit: I asked ChatGPT to decipher OP's post, and this is what was generated:
What a completly absurd assertion, from so called AI.
I doubt there is any 'typical' spherical size of objects, given the variety of such objects there are in the real World.
Thanks for your reply. Btw, im sorry for the insufficient information. MB is marker band. Marker band used in medical devices to enhance visibility and positioning during procedures. Im working at one of medical manufacturing company, so I planned to do a project on this.
Can you please post a picture of this band? And may be more pictures so we can understand the task more. May be you can get away with a computer mouse sensor, who knows
Is this going to prevent you from posting code?
Because basically we are an open source community, and we can't fix what we can't see.
I am a bit familiar with medical related manufacturing. Will your project have any effect on the company certification?
