Suggestion on adding a second rfid card
Hey all, I have a UNO and Parallax RFID reader I am using to unlock a car door, the code work great but I am wanting to add a second card to the code to unlock but not to sure on how to do it. Looking for some suggestions or example on how to . Current code I am using below.
Thanks for any help.
char tag[12] = {'0', '7', '0', '0', '8', '0', 'B', 0', '6', 'F'};  //rfid code
char code[12];
int bytesread = 0;
int doorPin = 13; // Connect red LED to pin 13
int rfidPin = 2; // RFID enable pin connected to digital pin 2
int val=0;
long lastUpdate=0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(rfidPin,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
pinMode(doorPin,OUTPUT); // Set doorPin to output
digitalWrite(rfidPin, LOW); // Activate the RFID reader
 {  char tagString[13];
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread >= 10) {              // if 10 digit read is complete
       if(strcmp(code, tag) == 0) {
         Serial.print("ACCESS GRANTED  : ");
         Serial.println(code);
         digitalWrite(rfidPin, HIGH); // diable rfid reader
         digitalWrite(doorPin,HIGH); // good read unlock door
         delay(800);                // wait a second
         digitalWrite(doorPin,LOW); // turn off door lock relay
         delay(600);                 //wait about half a second
         digitalWrite(doorPin,HIGH); // unlock door
         delay(2000);                 // wait 2 seconds
         digitalWrite(rfidPin,LOW);   // enable rfid reader
         Serial.flush();        // flush all rfid reads, stops multiple reads from one rfid read
        else {
         Serial.print("ACCESS DENIED   : ");
         digitalWrite(rfidPin, HIGH); // disable rfid reader
         delay(3000);                 // wait 3 seconds
      bytesread = 0;
           delay(500);                       // wait for a 1/2 second
The tag variable defines the valid tag ID. The strcmp function compares the scanned tag ID to the valid tag ID, and does something if they match.
Add another valid tag variable with the 2nd valid tag ID, and another if(strcmp...) block to test the scanned tag to the 2nd valid tag.
Thanks PaulS for the reply, I Forgot to include this code to. The code works for both cards but has bug the first card “char tag” Will be granted and unlock the door and after the door unlocks and in the serial monitor wil then say access denied, it does not effect the unlocking . The second card works fine no error or nothing. I guess it should be fine to just go ahead and use the code, I guess OCD is saying don’t haha.
char tag[12] = {'0', '7', '0', '0', '8', '0', 'B', '0', '6', 'F'};  //rfid code
char tag2[12] = {'0', '5', '6', '0','0', '1', 'M', '0', '7', '0'};
char code[12];
int bytesread = 0;
int val=0;
long lastUpdate=0;
      bytesread = 0;
       if(strcmp(code, tag2) == 0)   {
        else {
      bytesread = 0;
Put each { and } on a separate line. Then use Tools + Auto Format. Then, look at the code where you test the tags. You have poorly nested if statements.
You want something like this:
if(bytesRead >= 10)
if(strcmp(first tag...) == 0)
else if(strcmp(second tag...) == 0)
// Access denied...
Thank you PaulS, I knew it would be something simple and I just couldn’t see it. Thanks for the format tip.
