Suggestion on expansion board for DRV8825 driver
Hello , I am going to do a project in which I have to control a Nema 17 bipolar Stepper Motor with the DRV8825 driver and an Arduino Mega. The stepper motor will be used to move a motorized slider , forward and backward.
The specifications for the Stepper Motor are the following:
  • Step angle : 1.8 deg
  • Holding torque: 40 Ncm
  • Rated curreng/phase : 1.7 A
  • Phase resistance: 1.5 Ohm
  • Insulation Resistance : 100 Mohm
  • Insulation Strength : 500 VAC
    As for the power supply , I will use a 12V 2A DC Wall wart.
    I know that breadboards are not really recommended for motor connections .
    My soldering skills are not quite good , so I have been doing a lot of research and I found this expansion board for a single DRV8825 .
    Here is the link to the following board : https://www.makerlab-electronics.com/product/a4988-drv8825-stepper-motor-control-extension-board/
    The question would be how reliable is this board and can I use it for my purpose?
    Thank you in advance for any help!
I can't speak for the reliability, but that is kind of a neat little board. It has the necessary bits and should make your wiring easier.
1.7 Amps coil current is on the high side of what a DRV8825 can handle without a heat sink and forced air cooling. Consider adding some active cooling or dialing the coil current down a bit. The driver should handle 1.5A without extra cooling.
Make sure that the coil current limit (Vref) is set properly before using the driver. Refer to the Pololu DRV8825 page.
Thank you for your help . Probably I will not use the motor at the full torque so I will limit the current in order not to overheat the driver.
