[suggestion] SofwareSerial - stopListening function
Hi!
I’ve found some problem with SoftwareSerial with my program.
I’ll write some example (by using parts of my project, so it might not work):
Let’s assume we configured stepper, softwareserial something like this:
SoftwareSerial SerialPort(pHrx, pHtx);
  Serial.println(F("<Arduino is ready>"));
  Serial.println("");
  SerialPort.begin(pHbod);
  SerialPort.listen();
  // set the speed at 60 rpm:
  myStepper.setSpeed(60*mlStep/stepsPerRevolution);
and let’s make simple loop for moving stepper:
  myStepper.step(-1);
Some would say ok, that should work!, but it does not.
My ph-meter sends data about once per second, and while I’m not reading it at all (i can even comment SerialPort.listen(); part), my stepper slows down once per second.
I needed to do some dirty workaround an my only idea is to do:
    pinMode(pHrx, INPUT);
    //read pH value now.
    pinMode(pHrx, OUTPUT);
So, here i’m suggesting adding some ‘stop read’ function to SoftwareSerial lib.
Best regards!
