suggestion to simplify a tiny LED on/off code
Dear all,
Anyone can show me some tips how to simplify this code: turn on/off LEDs in turns.
  // loop from the lowest pin to the highest:
    digitalWrite(3, HIGH);
    digitalWrite(5, HIGH);
    digitalWrite(6, HIGH);
    digitalWrite(9, HIGH);
    digitalWrite(10, HIGH);
    delay(2000);
    digitalWrite(3, LOW);
    delay(2000);
    digitalWrite(5, LOW);
    delay(2000);
    digitalWrite(6, LOW);
    delay(2000);
    digitalWrite(9, LOW);
    delay(2000);
    digitalWrite(10, LOW);
    delay(2000);
    delay(2000);
const byte PinMap[] = {3, 5, 6, 9, 10};
#define NbLeds sizeof(PinMap)
  for(byte i = 0; i < NbLeds; i++){
    pinMode(PinMap[i], OUPUT);
  //Turn them all on
    digitalWrite(PinMap[i], HIGH);
  //loop trough the rest
    digitalWrite(PinMap[i], LOW); //turn the leds off
    delay(2000);
    digitalWrite(PinMap[i], HIGH); //turn the last back on
  //Part two, one by one off
  for(byte i = 0; i < sizeof(PinMap); i++){
    digitalWrite(PinMap[NbLeds - i - 1], LOW);
  delay(2000);
But problem with this is you can’t do anything else with the Arduino because it’s waiting all the time. Are you planning to do something else with the Arduino as well?
And if you want something non blocking (so you can do other stuff) something like this should work.
const unsigned int DelayMap[] = {0, 2000, 1000, 2000};
  ledUpdate();
  //do some other NON BLOCKING stuff
void ledUpdate(){
  static byte stage = 0;
  static unsigned int lastMillis = 0;
  static byte currentLed = 0;
  unsigned int currentMillis = millis();
  if(currentMillis - lastMillis >= DelayMap[stage]){
    lastMillis = currentMillis;
    switch(stage){
      case 0: //turn on all the LED's
        stage++;
      case 1: //walk up
        if(currentLed != 0){
          digitalWrite(PinMap[currentLed - 1], HIGH); //turn on the last
        if(currentLed == NbLeds){
          stage++; //goto next stage
        else{
          digitalWrite(PinMap[currentLed], LOW);
          curentLed++; //goto next led
      case 2; //walk down
        if(currentLed == 0){
          stage++;
        else{
          digitalWrite(PinMap[currentLed - 1], LOW);
      case 3;
        stage = 0;
