Suggestions for boards and modules for a temperature transducer comparative experiment
Hello, I am working on an experiment to compare different temperature transducers, performing three tests:
  1. One with an RTD (resistance temperature detector).
  2. One with a type K thermocouple.
  3. One with a type J thermocouple.
In all tests, I will use an LM35 semiconductor temperature sensor as a reference.
My advisor informed me that we have the following modules available:
  • X13406 thermocouple module.
  • ESP32 Wi-Fi module (30 pins, USB-C).
The goal is to measure the data from the transducers, where each experiment (always in pairs of LM35 and one other sensor) will have measurements taken within a range of 0 °C to 80 °C. The data needs to be saved (either in Arduino memory or transmitted directly to a computer), so it can later be imported into MATLAB for processing and curve comparison.
I have no prior experience with Arduino, and this project will be my first contact with it, so I can learn to use the hardware. I would appreciate suggestions for boards and modules that could be used for this purpose. I am not limited to the previously mentioned board and module. I need suggestions for a suitable intermediate processor that can be used in this application for purely educational purposes (after the experiments and results, a didactic material will be created to help teach the Transducer course in an Electrical Engineering program).
Thank you in advance for any help you can provide!
Uno R3
That sounds like an interesting project that could be a lot of fun! Hopefully, you have some time to dive into it. However, please remember that we’re not a free design or code-writing service. We’re more than happy to assist with your design or code, but we need you to make an initial attempt. Start by designing and writing your code, then share it along with an explanation of what’s not working properly.
To help us help you, please keep in mind:
  • We can’t touch, feel, or see your project—you’ll need to provide that context for us.
  • Clear details and a concise explanation will make it easier for us to offer meaningful guidance.
  • Show Your Work First: Before asking for assistance, make an attempt to design or write the code yourself. Share your work along with details about what isn’t working.
  • Provide Clear Documentation: Since we can’t see your project, share an annotated schematic (best) or a clear drawing of your setup. Pictures are welcome, but avoid using Fritzing diagrams as they are wiring diagrams, not schematics, and are not ideal for troubleshooting.
  • Include Technical Details: If there is specific hardware involved, include links to technical information. There are often many versions of similar components, so precise details are essential.
  • Reference Resources: For additional help, check out useful links and tutorials: Useful Links on Arduino Forum.
  • Obtain a copy: of the Arduino Cookbook and complete several of the projects. Many of them will help you achieve parts of your goals.
  • Course Electronics For Beginners (eBook)
  • Electronics For Beginners (eBook)
  • Arduino Step-by-step Projects Course | Build 25 Projects
