Blink 2 led independently with time adjustable ()each with a different ON and OFF period), {ALL THIS FOR A ADJUSTABLE SET TIME OF PERIOD AND END},and if possible .without delay() function
There are a few ways to make it, but they all use millis().
Try to blink one led with millis(), and add the other led to it.
IT IS A CONTINUOUS LOOP >>>>> {ALL THIS FOR A ADJUSTABLE SET TIME OF PERIOD AND END}???
// Which pins are connected to which LED
const byte greenLED = 12;
const byte redLED = 13;
// Time periods of blinks in milliseconds (1000 to a second).
const unsigned long greenLEDinterval = 500;
const unsigned long redLEDinterval = 1000;
// Variable holding the timer value so far. One for each "Timer"
unsigned long greenLEDtimer;
unsigned long redLEDtimer;
void setup ()
pinMode (greenLED, OUTPUT);
pinMode (redLED, OUTPUT);
greenLEDtimer = millis ();
redLEDtimer = millis ();
} // end of setup
void toggleGreenLED ()
if (digitalRead (greenLED) == LOW)
digitalWrite (greenLED, HIGH);
digitalWrite (greenLED, LOW);
// remember when we toggled it
} // end of toggleGreenLED
void toggleRedLED ()
if (digitalRead (redLED) == LOW)
digitalWrite (redLED, HIGH);
digitalWrite (redLED, LOW);
} // end of toggleRedLED
void loop ()
// Handling the blink of one LED.
if ( (millis () - greenLEDtimer) >= greenLEDinterval)
toggleGreenLED ();
// The other LED is controlled the same way. Repeat for more LEDs
if ( (millis () - redLEDtimer) >= redLEDinterval)
toggleRedLED ();
/* Other code that needs to execute goes here.
It will be called many thousand times per second because the above code
does not wait for the LED blink interval to finish. */
} // end of loop
love7007:
Please don't SHOUT.
love7007:
void setup ()
} // end of setup
void loop ()
toggleGreenLED ();
toggleRedLED ();
} // end of loop
That seems OK, although it could be tidied up. Have you got a question ?
const byte ledPins[] = {10, 11};
const unsigned long intervals[] = {500, 1000};
unsigned long periodStartTimes[2];
void setup ()
pinMode (ledPins[0], OUTPUT);
pinMode (ledPins[1], OUTPUT);
void loop ()
for (int led = 0; led < 2; led++)
if (millis() - periodStartTimes[led] >= intervals[led])
digitalWrite(ledPins[led], !digitalRead(ledPins[led]));
periodStartTimes[led] = millis();
love7007:
Any more of this caps lock, and I'm locking this thread.
