Hi all! I'm brand new here. I just found out about the Arduino microcontroller yesterday and I must say I am quite impressed so far!
I am planning to use a linear actuator that will extend out until it finds a surface, at that point it will stop. If the surface it finds is moving, the actuator should retract or extend further, depending on the direction the surface is moving. Basically I want the actuator to stay in touch with the surface. The actuator I am planning to use is the Firgelli L12 series found here: http://www.firgelli.com/products.php. The part number for the actuator I want to use is: L12-100-100-12-I. I would like to use the Arduino Diecimila USB Microcontroller Board.
Now my question... Can someone recomend a way of interfacing the actuator and the microcontroller? What else will I need?
I really appreciate any advice that may be offered.
