Greetings,
I have successfully created my soil moisture monitor prototype using a standard Arduino, powered by 5V USB charger, with RGB LED indicating moisture content! It might be simple, but this is my first Arduino project, and I'm very excited about it.
I would like to take this project to the next level, and make it battery powered. This is where I could use some advice to guide me on creating something that works well, and has a decent battery life.
Here are some things that I've been thinking about:
- I want to use the Pro Mini for this project because of its small footprint and because I have one on hand
- I want to use some type of LED to provide an alert that the plant needs to be watered. I realize that I solid LED is not ideal, and it will drain the battery quickly. I was thinking about maybe using an RGB LED to blink different colors. I could do something like have it blink 5 times once a minute to provide feedback to the plant keeper.
- I want this to be battery powered. I know 9V batteries are not recommended, so I was thinking about using 4xAA batteries, with an on/off switch
- In order to prolong sensor life, and hopefully increase battery life, I will use one of the digital pins to turn the soil moisture sensor on/off before/after reading the sensor every 30 minutes.
- I've also been reading about the sleepy library as a way to put the Arduino in hibernation when it is not doing anything. I plan to use this as a way to converse battery life.
Do you have any feedback on the things that I have mentioned so far?
Is there anything that I have not mentioned that you think that I should be aware of?
Do you think my ideal of using 1 RGB LED is a good idea, or would I be better off using 3 individual different color LEDs and just lighting up one at a time depending on the reading?
Thank you to everyone here for all their help.
