Suggestions on getting more power?
So I have an Arduino UNO starter kit and I've been threw the whole starter book. I'm currently working on a GUI using C# for a full on input and output reader for my studies.
So to the point, my next project is controlling a strip of RGB LEDs and they require 12v. I was wondering what kind of options I have for getting more power? I don't have a DC power supply witch would be nice maybe I can get a small one for cheap?
I have also read this: http://bildr.org/2011/03/high-power-control-with-arduino-and-tip120/
Talks about using a Transistor like a switch allowing me to add more power.
What are my best options for getting more power?
12V wallwart would be best,.
Or a 5V to 12V step-up or boost converter.
5V to 12V, 1.4A, $3.95. Need good 5V supply to start.
Transistor like AOI514 will let you control the current thru the RGB LED strips, buffering the Arduino output signal.
As you state that they require 12V, you will probably also know how much power they require. That determines what you must look for.
In the stuff that I collected over the years was a power supply / charcher for an old laptop; 12V / 2A DC. Old cellphone chargers might also do; just check the voltage and current rating as well as if it's AC or DC out.
So I think I got the 12v DC wall plug however idk about the transistor, is there any I can get from Amazon. I have no idea what i'm looking for and I've checked my electronic tackle box full of parts but I can't find one.
Also Thanks for the help guys!
bump*
2nd time; Transistor like AOI514 will let you control the current thru the RGB LED strips, buffering the Arduino output signal.
http://www.digikey.com/product-search/en?keywords=aoi514
Yeah I got that, I was asking if there was any Transistors like that on Amazon? Thanks for the Help
