Suggestions on replacing a bike speed magnetic sensor
I have a bike speed meter which uses a magnet at the wheel and a glass encapsulated metal contact to make short circuits, which will be then counted as pulses at the computer.
This sensor is now broken. I've tested the computer with a new speed meter sensor and it's working nicely.
Would you have any suggestions on how could I assemble a similar sensor at home, or maybe create another of my own, preferentially not battery-powered?
many thanks,
Martin
Replace like with like - that is a Reed switch , usually very reliable
There may be a fault with that wiring ? .
thanks, Hammy, that might be a solution!
  • no, not the wiring... I even tested with a magnet to check if it shorted at the solder joints, but it didn't
please explain! What would it do if no power?
You might look into mechanical speed sensors. In the 1940-50s, there were bicycle speed sensors that counted the wheel spokes as they moved and indicated on a device, same as an automobile speedometer.
Hey, it's a reed switch.
Cheap, and the perfect choice for the application. Available in different sizes.
You do still need to de-bounce it in code.
