This one is the shortest, single precision floating point (yet accurate) algorithm I've been able to find. And yes, it does tell you where to point your solar panel. The date and time have to be UTC, but I added the time zone to help with printing out the local time.
It is not yet incorporated into Arduino-speak! I agree with the above comment that most codes you find should work. If they don't, you are either not using them correctly or did not adapt them properly to the peculiarities of the Arduino environment.
a simplified, yet accurate sun position calculator
based on Blanco-Muriel et al.'s SPA algorithm
closely matches altitude, azimuth values returned by NOAA calculator
This variation was converted from Javascript
#include <math.h>
#include <stdio.h>
float UTHours=20., UTMinutes=0., UTSeconds=0.;
float Lat=44., Lon=-123., TZ = -8;
int year=2014,month=6,day=14; //UTC date
// accuracy tests... double precision algorithm said to be accurate to 0.5 arcmin (.0083 deg) until 2015
// 2003/1/1 Lat,Lon = (0,0) @12:00 UTC: if double precision get alt=66.9713, az=177.9905, zenith=23.0287
// for above NOAA says 66.98 177.99
// 2023/1/1 (0,0) @12:00 UTC: get 66.9847, 177.9738 NOAA says 66.99 177.97
// local test Eugene OR:
// float UTHours=20., UTMinutes=0., UTSeconds=0.; //(local hours - TZ)
// float Lat=44.052, Lon=-123.087; // (44 3' 7" -123 5' 13") @12:00 local time no DST => 20:00 UT get alt = 68.97 az = 172.14 NOAA sez 68.98 172.12
// int year=2014,month=6,day=12; //UTC date
void get_sun_pos(float latitude, float longitude, float *altitude, float *azimuth){
float zenith;
float pi =3.14159265358979323;
float twopi=(2*pi);
float rad=(pi/180);
float EarthMeanRadius=6371.01; // In km
float AstronomicalUnit=149597890.; // In km
float DecimalHours = UTHours + (UTMinutes + UTSeconds / 60.0 ) / 60.0;
long liAux1 =(month-14)/12;
long liAux2=(1461*(year + 4800 + liAux1))/4 + (367*(month - 2-12*liAux1))/12- (3*(year + 4900 + liAux1)/100)/4+day-32075;
float JulianDate=(liAux2)-0.5+ DecimalHours/24.0;
float ElapsedJulianDays = JulianDate-2451545.0;
float Omega=2.1429-0.0010394594*ElapsedJulianDays;
float MeanLongitude = 4.8950630+ 0.017202791698*ElapsedJulianDays; // Radians
float MeanAnomaly = 6.2400600+ 0.0172019699*ElapsedJulianDays;
float EclipticLongitude = MeanLongitude + 0.03341607*sin( MeanAnomaly ) + 0.00034894*sin( 2*MeanAnomaly )-0.0001134 -0.0000203*sin(Omega);
float EclipticObliquity = 0.4090928 - 6.2140e-9*ElapsedJulianDays +0.0000396*cos(Omega);
float Sin_EclipticLongitude= sin( EclipticLongitude );
float Y = cos( EclipticObliquity ) * Sin_EclipticLongitude;
float X = cos( EclipticLongitude );
float RightAscension = atan2( Y, X );
if ( RightAscension < 0.0 ) RightAscension = RightAscension + twopi;
float Declination = asin( sin( EclipticObliquity )* Sin_EclipticLongitude );
float GreenwichMeanSiderealTime = 6.6974243242 + 0.0657098283*ElapsedJulianDays + DecimalHours;
float LocalMeanSiderealTime = (GreenwichMeanSiderealTime*15 + longitude)*rad;
float HourAngle = LocalMeanSiderealTime - RightAscension;
float LatitudeInRadians = latitude*rad;
float Cos_Latitude = cos( LatitudeInRadians );
float Sin_Latitude = sin( LatitudeInRadians );
float Cos_HourAngle= cos( HourAngle );
float UTSunCoordinatesZenithAngle = (acos( Cos_Latitude*Cos_HourAngle*cos(Declination) + sin( Declination )*Sin_Latitude));
Y = -sin( HourAngle );
X = tan( Declination )*Cos_Latitude - Sin_Latitude*Cos_HourAngle;
float UTSunCoordinatesAzimuth = atan2( Y, X );
if ( UTSunCoordinatesAzimuth < 0.0 )
UTSunCoordinatesAzimuth = UTSunCoordinatesAzimuth + twopi;
UTSunCoordinatesAzimuth = UTSunCoordinatesAzimuth/rad;
float Parallax=(EarthMeanRadius/AstronomicalUnit)*sin(UTSunCoordinatesZenithAngle);
UTSunCoordinatesZenithAngle=(UTSunCoordinatesZenithAngle + Parallax)/rad;
*azimuth=UTSunCoordinatesAzimuth;
zenith=UTSunCoordinatesZenithAngle;
*altitude=90.-UTSunCoordinatesZenithAngle;
int main()
float alt, az;
get_sun_pos(Lat, Lon, &alt, &az);
printf("At Lat = %7.2f, Lon = %7.2f \r\n",Lat,Lon);
printf("UTC Date: %02i/%02i/%4i local time: %2i:%02i \r\n",month,day,year,(int)(UTHours+TZ),(int)UTMinutes);
printf("Sun altitude = %7.2f, azimuth = %7.2f",alt,az);
return 0;
