Sun tracking hat coding HELP
I tried to recreate the sun tracking hat done by a youtuber (william osman) and I ran into a problem in my code, more precisely I don't understand the code. It uses PID to control a servo which is 360 modded (so with a fixed resistor to replace potentiometer so servo will never reach where it wants to go and continues spinning) Can someone help explain the following lines of code? Thanks!
Part of code that needs explaining:
 float error =sensLeft - sensRight;
  float pid_p, pid_i, pid_d;
  pid_p = error * 20;
  pid_i = 0.0;
  pid_d = 2.0;
  byte motor_pwm = SERVO_NEUTRAL + pid_p + pid_i + pid_d;
  hatservo.write(motor_pwm);
For this line, will the servo never stop spinning even when the error is 0, as it never reaches the neutral position? (modded)
Full code:
#include <Servo.h>
#define LIGHTSENS_RIGHT A1
#define LIGHTSENS_LEFT A0
#define HATSERVO_PIN 11 //D11pin
#define SERVO_NEUTRAL 93 //
#define PID_P 20
#define PID_I 0.0
#define PID_D 2.0   //
Servo hatservo;
  hatservo.attach(HATSERVO_PIN);
  trackSun();
int8_t trackSun(void){
  int sensRight = analogRead(LIGHTSENS_RIGHT);
  int sensLeft = analogRead(LIGHTSENS_LEFT);
  pid_p = error * 20;
  pid_i = 0.0;
  pid_d = 2.0;
  delay (3);
Thanks guys!
Did you ask the guy that wrote the code?
-jim lee
I cannot reach him, well I tried already, but didn't get a reply.
You should test your code step by step otherwise it will be quite difficult to debug it. I have seen a variable SERVO_NEUTRAL, have you configured it for your servo motors ???
"dont't understand code" --> go read code and learn C. Then write a propper question.
