hello,
i am having problem uploading the code to the sensor ( see title ) giving me this error:
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.1.0_x64__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
An error occurred while uploading the sketch
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
avrdude done. Thank you.
please Help.
the code is:
#include <TimerOne.h>
#define S0 3 // Please notice the Pin's define
#define S1 4
#define S2 5
#define S3 6
#define OUT 2
int g_count = 0; // count the frequecy
int g_array[3]; // store the RGB value
int g_flag = 0; // filter of RGB queue
float g_SF[3]; // save the RGB Scale factor
// Init TSC230 and setting Frequency.
void TSC_Init()
//set the pins as OUTPUT
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(OUT, INPUT);
// OUTPUT Frequency Scaling 2%
digitalWrite(S0, LOW);
digitalWrite(S1, HIGH);
// Select the filter color
void TSC_FilterColor(int Level01, int Level02)
if(Level01 != 0)
Level01 = HIGH;
if(Level02 != 0)
Level02 = HIGH;
digitalWrite(S2, Level01);
digitalWrite(S3, Level02);
void TSC_Count()
g_count ++ ;
void TSC_Callback()
switch(g_flag)
case 0:
Serial.println("->WB Start");
TSC_WB(LOW, LOW); //Filter output Red
case 1:
Serial.print("->Frequency R=");
Serial.println(g_count);
g_array[0] = g_count;
TSC_WB(HIGH, HIGH); //Filter output Green
case 2:
Serial.print("->Frequency G=");
g_array[1] = g_count;
TSC_WB(LOW, HIGH); //Filter output Blue
case 3:
Serial.print("->Frequency B=");
Serial.println("->WB End");
g_array[2] = g_count;
TSC_WB(HIGH, LOW); //Clear(no filter)
default:
g_count = 0;
void TSC_WB(int Level0, int Level1) //White Balance
g_count = 0;
g_flag ++;
TSC_FilterColor(Level0, Level1);
Timer1.setPeriod(1000000);//1000000 microseconds(1s)
TSC_Init();
Timer1.initialize(); // defaulte is 1s
Timer1.attachInterrupt(TSC_Callback);
attachInterrupt(0, TSC_Count, RISING);
delay(4000);
for(int i=0; i<3; i++)
Serial.println(g_array*);*
- g_SF[0] = 255.0/ g_array[0]; //R Scale factor*
- g_SF[1] = 255.0/ g_array[1] ; //G Scale factor*
- g_SF[2] = 255.0/ g_array[2] ; //B Scale factor*
- Serial.println(g_SF[0]);*
- Serial.println(g_SF[1]);*
- Serial.println(g_SF[2]);*
{ - g_flag = 0;*
- for(int i=0; i<3; i++)*
Serial.println(int(g_array * g_SF*));
_ delay(4000);
the timeone library I got is the 11v._
