I'm making a small quadruped with a dozen or so standard (55g 10kg/cm) hobby servos. Power is a 7.2V 5300 mAH NiMH battery.
From what I gather, NiMH source about 1.2 times the AH rating. What I think I want to do is isolate the Arduino from the servos and have a surge cap on the servo bus.
The isolation for the Arduino seems simple enough, a diode and a capacitor. Similarly a capacitor across the servo bus to ground.
In the old school days all we had was caps rated in microfarads, now we have super caps. I have on order some 1F 5.5V caps (I assume two 2F caps in series in one package).
So, two of these in series could yield a .5F at ~ 11V.
Questions:
Are the super caps well enough matched that the voltage will divide more or less evenly enough to get at least a 7.2V rating? Or will I need some bleeder resistors across the caps to do some balancing?
What happens when I connect my NiMH battery to a Farad or so? Seems like quite a surge...
I'm considering a switch with .5 ohm 5W resistor in series to slow the charge down a bit, then a direct connection.
Am I making too big a deal on this? Should I just use smaller caps to filter the transients? Or something else?
