Super Maximum Board
Hello!
I've been thinking about making an arduino compitable monster, if it's not done already. Monster being more powerful. More I/Os more EPROM, EEPROM and SRAM.
I have the ATmega128 in mind (unless there is something even more porweful)
But: how do I implement the ATmega128 functions and additional I/Os to the Arduino IDE. (I'm a high-level programmer, but if I have to learn Assembly language, that's not stopping me)
If someone could point me in the right direction, I would be thrilled!
There are some things in the works, but nothing w/ the ATmega128.
You should check out the code in hardware/cores/arduino. That and the ATmega128 datasheet should get you started. Also check out the Wiring source code - it’s based on the ATmega128.
There is no need to touch assembly. :) Its all mainly just lookup tables.
You should check out the code in hardware/cores/arduino. That and the ATmega128 datasheet should get you started. Also check out the Wiring source code - it's based on the ATmega128.
erm there might be some rumblings occurring with the 1280
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1201851030/5#5
I certainly hope so :-?
