Hi users, I actually devellop a project and i'm front of a supply problem, my system is compose of:
-an external power supply 12Vdc
-arduino mega 2560
-Usb host Shield
-Arduino Motor Shield
-1Dc Motor which consume 9V,2A
the issues is the next one:
before i was able to control this dc motor thanks to a ps3 controller and now when i used the 3 arduinos cards in same time my motorshield do not delivers current on A channel. (that was working good before).
I have done a test with 9V DC motor and i add a brake on channel B which consume 9V 0.4 A
I have try to use only motor shield + arduino mega and that works
i have try to use only usb host shield+ arduino mega and i receive data from ps3 controller ( so that work)
When i use the 3 cards i can see leds on motor shield light a little bit.
I suspect a pin problem, but arduino mega is compatible with usb host shield, the connection is made by ISCP connector (equal to pin 51,52,53)
my motor shield use pin 3 (for Pulse Wight Modulation A) and pin 12 for DIR A
use pin 11 f(or pwm B )
i tried with a simple programm like it:
analogwrite( 11 ,190) ;
delay (500);
analogwrite(3,190); PWM
digitalWrite(12,HIGH);
if someone can explain me why, i will listen him really carefully.
3 cards are suppose to works together so ....
