Hi all!
I'm new bie. Hope everyone help!
I'm using Arduino Nano v3.0 Board (ATM328P).
I use one potentiometer. It uses the reference source AREF
Frequency_Board uses +5V source on board.
I'm afraid that USB power is not enough to provide in my application
I hope everyone to explaine my problem.
Thank all!
I don't understand the connection between the Inverter output and the 5V line.
( I guess it's a drawing problem only, and should go to Vcc pin of your 74HC14 )
If I understand analogReference() - Arduino Reference properly, there's an internal resistor, if you use AREF as a voltage source, which would affect your potentiometer reading.
Rather connect Vcc (ATMEGA Pin7) to the high end of your pot, if you need the full 0..5V range. (?)
But you did not say what you thought that, what problems, if any, you were having.
Apart from using the Vref which you should not. And probably blowing up your 74HC14 buffer by connecting it to the power line, you seem to be making no other mistakes.
Thanks your reply! My purpose: I have a 3D program, my program will read value of sensors from Arduino board throught USB cable. + Hardware:
According to the comments, I have to fix:
Is that right?
Frequency_board: Measuring frequency form encoder, sent to PC (my froject is written in VC++2008)
Potentiometer: Mesuring analog input (A0 pin), sent to PC (my project ís written in VC++2008) + Software:
*Communication between PC and Arduino board:
-I am writing an application in VC++2008. I use SerialPort Class (MSDN) (http://msdn.microsoft.com/en-us/library/system.io.ports.serialport.aspx) to read each byte that Arduino board posted
-On the board,I use "Serial" to read requests from the computer (Serial.read, Serial.ReadBytes) and send the value of the sensor to the computer (Serial.write, Serial.print)
*Progamming for chip:
-Analog input: i use function "analogRead(A0)"
-Frequency from encoder: I used library "FreqMeasure" of Paul Stoffregen (best for 0.1 Hz to 1 kHz)
---->>>>It is my understanding. I'm not sure about my methods. Hope you guide, please!
Thank in advance!
Much better, still to remove the connection from c1 to pin2 of your 74HC14.
c1 is just between 5V and GND and intended to be parallel (and close to) to the power pins of the 74HC14
"Software" is fine so far, IMU ( description is not as detailed as your circuit picture )
nhatnam06dt1:
Hi all!
Thank all!
You are fine. That circuit looks like it only uses a 10 to 20 milliamps. USB will give you 500 mA.
@ dhenry a Schmidt trigger input inverting buffer is good engineering practice to 'clean up' the output of a photo-transistor.
The connection from the buffer output to Vcc isn't though.
@ dhenry you are expecting my feeble brain to anticipate you... Which Pin? I see an NPN transistor, a photo transistor with a 104 resistor from collector + 'HC14 input to Vcc.
I don't see any "Pin" that would counter indicate the use of a schmitted buffer, replace it or in any other way mitigate the requirement... Let the rest of us in on your little secret because
I still don't see where my original observation has changed in any way...
No R2 isn't needed, It is good insurance though for issues on either side of the resistor and If the 328 port connected to that resistor were set opposite of the 'HC14 the resistor would limit current with no ill effects on a 'normal' circuit.
I deplore this modern trend for trying to idiot proof things. If you are going to be that stupid you should not be messing with electronics in the first place.
Grumpy_Mike:
deplore - ha, now there's a very strong word. Since we're always telling stories of the days
of yore ....
Back in the olden days, I was making some pcbs for use with OOPics [a deplorably weak device,
after all]. All of my boards had small-valued series-Rs on the I/O lines. Then, oopic started
selling boards with the cpu surface-mounted, and there was no protection on the I/O lines
whatsoever. Well, almost every day on the forum, some poor sack would come on crying he
had blown up his oopic board by overvolting one of the pins, etc. The market of course, was
aimed at beginners. And of course, the smt cpu could not be replaced, so the board was
toast [at $70 a pop in those days]. Well, over time, not one person ever blew up even one
of my boards with the I/O pin protection - and I still swear by such measures.
At least in the Arduino world, we have a lot of boards with DIP28 chips that are easily and
cheaply replaced when blown, even if there's still scant pin protection.
That all being said, the series-R probably really isn't needed in the OP's original ckt.
[waiting for thunderbolts now, :-)].
