Thanks all - it is working, but maybe a little dim. I might try a different resistor...
Display Pin
ESP32 Pin
#define
Schematic label
Display Pin
ESP32 Pin
#define
Schematic label
P1
(Not Connected)
P2
(Not Connected)
P3
(Not Connected)
P4
(Not Connected)
P5
Ground
P6
3.3v
P7
27
TFT_CS
LCD_nCS
P8
14
TFT_DC
LCD_RS
P9
12
TFT_WR
LCD_nWR
P10
13
TFT_RD
LCD_nRD
P11
3.3v
P12
(Not Connected)
P13
(Not Connected)
P14
(Not Connected)
P15
(Not Connected)
P16
180 Ohm resistor to 3.3v
P17
Ground
P18
Ground
P19
Ground
P20
Ground
P21
Ground
P22
(Not connected)
P23
16
TFT_D0
DB0
P24
4
TFT_D1
DB1
P25
23
TFT_D2
DB2
P26
22
TFT_D3
DB3
P27
21
TFT_D4
DB4
P28
29
TFT_D5
DB5
P29
18
TFT_D6
DB6
P30
17
TFT_D7
DB7
P31
26
TFT_RST
LCD_nRESET
P32
3.3v
P33
3.3v
P34
Ground
P35
(Not Connected)
P36
(Not Connected)
P37
(Not Connected)
P38
(Not Connected)
P39
(Not Connected)
P40
(Not Connected)
user_setup.h
#define ESP32_PARALLEL
#define ILI9341_DRIVER
// ESP32 pins used for the parallel interface TFT
#define TFT_CS 27 // IO7 LCD_nCS - Chip select control pin
#define TFT_WR 12 // IO9 LCD_nWR - Write strobe control pin - must use a pin in the range 0-31
#define TFT_DC 14 // ?IO8 LCD_RS - Data Command control pin - must use a pin in the range 0-31 (possibly Register Select)
#define TFT_RD 13 // IO10 - LCD_nRD
#define TFT_RST 26 // IO31 - LCD_nRESET - Reset pin
#define TFT_D0 16 // Must use pins in the range 0-31 for the data bus
#define TFT_D2 23 // so a single register write sets/clears all bits
#define TFT_D4 21
#define TFT_D6 18
#define TFT_D1 4
#define TFT_D3 22
#define TFT_D5 19
#define TFT_D7 17
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
#define SMOOTH_FONT
The IM3 IM2 IM1 IM0 should be set to 1001 for D[17:10], but they're shown as set in the above post to binary 0001 which would use D[7:-0] for registers and D[15:0] for data.
